Old Aug 12, 2012, 04:59 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by AceMigKiller View Post
On the XL90?? Not sure.
I wasn't there for all of them so I cannot say 100% what happened.
- I know of one that crashed because the hinges were not glued well enough in place (due to the factory not putting wood in the stab properly)--- that kind gentleman posted pics and vid and I believe he got put into contact with Robert @ EJF right away.
- I know of another that crashed due to an Elevator servo letting loose because it was improperly and insufficiently glued in place.
- And of course, the original Prototype that I crashed at the bottom of a huge power dive when I ripped the stock cloth hinges out... which of course prompted me to recommend everyone either double-check or use beefier nylon hinges.
It's a shame my 4.1kw Sniper isn't flying anymore, but I havent' even bothered justifying the original elevator design anymore. The flying and tunnel tests proved their value... (and would bust many egos if they were present, but that's not what I was aiming for anyways)
Nonetheless, I hope the new Stab/Elevator combo is what the people are looking for!
I'll be getting my hands on one and flying them with all of ya too. I've even got some more ideas I wanna try on this bird...
Ace. Can u do a guesstimate on top speed with your setup?
I also got a 4kw setup that i might use.
pavcon is offline Find More Posts by pavcon
Old Aug 12, 2012, 11:53 AM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Straight/Level at WOT was definitely at/above 150mph... I believe some people watching this thread were at LA Jets earlier this June and can verify that.
Out of dive, it's easily 165+mph. I will admit that it seems to hit a speed barrier right around 165-170mph; likely due to the oversized and non-optimized intakes... still pretty fast though!
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old Aug 12, 2012, 12:50 PM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
Doesn't phase me. I build'em right and they work.
Only problem is I'll probably do another custom scheme.
Brent,
Do you need any parts to get yours airworthy again?
I built mine right and if the wood have been in the right place for the hinges im sure it would still be here now lol.
Pav u should get one of these planes sure worth the money fly great straight and true
alanjets is offline Find More Posts by alanjets
Old Aug 14, 2012, 01:55 PM
vengame is offline
Find More Posts by vengame
Joined Aug 2011
Good evening all
little video of my SUPER SNIPER
very good top speed for my config light (6S 5000 MAH + MOTOR HET 650-58-1970) 2 40
34 flights!
test vitesse de pointe du SUPER SNIPER le 14.08.12.MOV (4 min 26 sec)
vengame is offline Find More Posts by vengame
Old Aug 15, 2012, 09:21 PM
johnny_0 is offline
Find More Posts by johnny_0
Canada
Joined Dec 2005
Wow the XL version flys nicely on 6s?! Im shocked! very nice!
johnny_0 is offline Find More Posts by johnny_0
Old Aug 15, 2012, 11:01 PM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
Doppler at 70 deg F
2:40 -- 124mph
3:40 -- 120 mph
G-Forse is offline Find More Posts by G-Forse
Old Aug 15, 2012, 11:33 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i Saw Vic's Snpier at LA jets ...it was a good 160 ,a tad faster than C/N's 8s set up ...so yeah i think the air frame reaches a point where way more power is needed to go any faster ...but man 140- to 160 thats fast enough i'd say
AIR SALLY is online now Find More Posts by AIR SALLY
Old Aug 16, 2012, 12:02 AM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
is he running 10s? 160 is good! would 12s get this baby to 190 - 200?
evo101 is offline Find More Posts by evo101
Old Aug 16, 2012, 10:59 AM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
U would need lots of power to get through 190mph more than 12s i think Ali Machinchy is flying a ultra flash with a merlin 160 with 40lb of thrust in it and he's trying to get through the 300 mph .He's only managed 288mph so far and this airframe will need a 50lb + to get it there and this airframe will fly's nice on a 18lb thrust, lots of alterations have all ready been made to the airframe its on the limits now.
Air sally's right u would need lots to get it there fresh air is pretty thick!
Old Aug 16, 2012, 11:04 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
redoing the inlets and ducting would make a huge differance. ive been thinking of doing it to mine. a foam core wing and stab would drop a pound off this model too. the wing/stab layups are pretty damned heavy, but the fuse is super light weight.
corsair nut is offline Find More Posts by corsair nut
Old Aug 16, 2012, 08:54 PM
Joined Jul 2004
I was running 12s on the HET 9305V2 using their 700-68-1200kv motor.
Nice setup for 4.1kw. Wicked fast acceleration and just about unlimited vertical.
Old Aug 17, 2012, 01:11 PM
heychas is offline
Find More Posts by heychas
"My grandma wants to fly jets"
heychas's Avatar
Richmond, VA
Joined Feb 2008
Vic - thanks for the tip about the naca scoop. I used it on another bird and its made a big difference w/ cooling.
I was currious if you've decided which 8s combo you might go w/ for your next bird. I'm assuming you will stay w/ a het fan, which appears to load differently than the jetfan. So I was curious which Kv motor you think would work best for the HET fan on 8s. Thanks for any thoughts.
Charlie
heychas is offline Find More Posts by heychas
Old Aug 17, 2012, 03:35 PM
tehachapi, CA
Joined Jan 2006
1600 is a great kv for the het fan on 8s. 1500 works well too if you want to keep the load nice and low
Old Aug 17, 2012, 04:02 PM
Joined Jul 2004
+1
I'm going to go the 1600kv route and use "throttle management"... maybe.
Old Aug 18, 2012, 03:42 AM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
Had an offer of a plane from Het they have given me a new motor and the plane for $250.I still think that the plane would of still been here now if the wood had been in the right place for the hinges.
dont think its a good deal realy as the plane cost well over $1000 distroyed everything retracts,esc,batterys,servos,but suppose thats how people do business now .Still love this plane though but a little diapointed with het
first and last flight Het super sniper xl (2 min 29 sec)
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
