Old Jul 11, 2012, 10:01 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
I've got a sorta good shell to work on for the coming winter. That's about it. Maybe the new elevator will be out before then..
Michael Paxton is offline Find More Posts by Michael Paxton
gbmoore is offline
Find More Posts by gbmoore
Colorado Springs, Co
Joined May 2002
Originally Posted by falconjet50 View Post
I<SNIP> Also, the magnets only on the canopy for a jet that could go over 150MPH??
The instructions do recommend a latch of sorts as the magnets are not enough.
I like the Jet Hangar variety, BVM also makes excellent latches.
Greg
gbmoore is offline Find More Posts by gbmoore
Old Jul 11, 2012, 10:08 PM
Nashville TN.
Joined Mar 2006
ARF-ARI Almost Ready to Fly-After you Redesign It.
Old Jul 11, 2012, 10:13 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
lmfao!!!! but that is a lot of the fun sometimes
jcdfrd is offline Find More Posts by jcdfrd
Old Jul 11, 2012, 10:23 PM
Nashville TN.
Joined Mar 2006
Agreed. I just keep running into every little bit of "Oh....Well that's not gonna work..."
Had 3 days off recently. Managed to get new hinges installed in the flaps, and figure out the servo placement and linkages for the wings.......I should have had the thing built by today!!
But instead I'm sifting thru drawers of parts trying to find stuff that will work.
Not to mention the extra money I spent to have it sent here fast......Could have walked/swam to Hong Kong and picked it up in person and been no worse off build wise.
Old Jul 11, 2012, 11:17 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Oh you guys are young and spoiled. It was just a few years ago that most kits not only needed the re-design, but they were not even engineered for anything electric.
I won't bother to go into how we had to walk miles through the snow to get to school stories. But man, these ARFs are so easy to build, modify, and get into good flying condition. God forbid that assembly should tax our brains.
I don't even do build threads anymore because the assembly and modification of ARFs is so beginner as far as the hobby goes. If you can't do it, then just be the test pilot.
I used to love the build much more than flying, but now it's baby stuff when you consider the improvements, the parts, the landing gear etc. The flying is simply verification of the build.
You know what I do when I get a new ARF? I open the box, unpack it, and make a decision as to whether the plane is worth adding servos, motor and electronics to it. If the answer is NO, it might go directly into the big trash pail. Why waste time on building junk. I give lots of planes away rather than put money into something that I determine is below par.
You each have to make the same decision, but if you keep it, don't complain after.
You guys would have laughed your asses off at some of my build threads. Chit, I spent hours and hours on a giant B25 kit, tons of money on the motors, batts, gear. 1 hour from finish,the freaken thing fell 2 feet off the stand and did major damage. The cheap wood was imitation plywood, soft, fragile, junk. Good thing I found out before flying it. I took a video of me trashing the junker to finish off the build thread. Now I learned to look before building and ask myself the question before moving forward. Is it worth me spending the time and expense? My time is valuable, isn't yours.
SCALEFAN is offline Find More Posts by SCALEFAN
Old Jul 11, 2012, 11:29 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I admire your mentalism to knwo if something flies ok just from the kit stage
pavcon is offline Find More Posts by pavcon
Old Jul 11, 2012, 11:58 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
well when you've been flying and building for very long peroids of time you can look at a kit and tell if its good.
hey Al can I be on your plane giveaway list
Old Jul 12, 2012, 09:54 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
No genius needed to inspect the plane right out of the box, and I never said that I determined in advance how a plane flies. Heck, they all will fly.
My comments only concerned the build. If the plane passes the build test, then we go to step two. What needs to be changed/modified to make it airworthy. (this is personal, we all have different definitions) Is it worth the time and effort? After that, step 3, who is going to shake it down after completion?
Certainly, you don't try to fly the wings off on your maiden flight.
This XL is a cheap plane, so it will need some work to make it the way you want it. Don't bitch, just do it and talk about it. Just like Ralph is doing.
Carry on Ralph.
Old Jul 12, 2012, 11:50 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Carry on Ralph.
Right On Brother!
Knife Liddle is offline Find More Posts by Knife Liddle
Old Jul 12, 2012, 01:11 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
More build
Canopy:
I guess that’s why they improved on the canopy, when I received mine last month, it came with the canopy already cut out and mounted on the frame, plus I also had a spare that came with my kit. Two things to keep in mind are:
1. This is HET biggest Jet, so I think they don’t have the High Speed Experience just yet, they are used to making 70MM Jets. The original Sniper 90MM was not much bigger than a 70MM plane, that’s why I, along with some of you have provided feedback, and I would have to say they are making changes to the plane and incorporating some of those changes already.
2. Most manufacturers in the East make the planes so that fly around, meaning they are able to take off, do the pattern a couple of times and Land, They do not have Victor (AceMigKiller) or other Pilots like him in mind that will push the plane past the 120MPH. I could swear they all think a 90MM plane should fly on 6S.
Anyway, for my piece of mind, my canopy has the hatch latch on the back and will have a Hook/Pin in the front to keep it secure. I didn’t get much done last night, work and real life got in the way. I only glued in the horizontal Stab to the fuselage and added the Dragon decal to the Right hand side. Set the plane on top of the wing to get some inspiration.
@Brent and @Vic
Where did you mount your ESC? Got any pictures?
Ralph
I, agree with that. The canopy alone took me around four hours to fiqure it out with out cutting the black lines over the canopy. I had to be very careful about cutting the clear milar, good luck getting a replacement cover. Also, the magnets only on the canopy for a jet that could go over 150MPH??
CRCJA is offline Find More Posts by CRCJA
Old Jul 12, 2012, 02:34 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
Ralph,
You were lucky with that canopy. Mine came with two mold lines, and both were wrong. Thank goodness I was able to get it glued to the frame after I cut it using the inside line..
There is no air running through the fuse, cooling the ESC could be a problem, thus, my ESC is soldered to the motor wires and is inside the thrust tube.
Al
Old Jul 12, 2012, 07:44 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
ESC Placement
Yo Ralph,
This is how I mounted mine. It's a flat 100amp HV from HET.
It gets four screws into two pieces of wood, the wood pieces are then glued directly to the side of the Fuse right above the trailing edge Wing Mount on the left side.
Cooling is provided by a NACA-type intake from ParkFlyerPlastics.com; always comes down nice and cool.
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old Jul 12, 2012, 09:12 PM
cquian is offline
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Originally Posted by AceMigKiller View Post
Yo Ralph,
Vic
Not sure where your batteries are, but with this ESC placement, do you need to add capacitors if this requires longer battery wire runs?
+1 on the NACAs from ParkFlyerPlastics.
cquian is offline Find More Posts by cquian
Old Jul 12, 2012, 10:03 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
Those scoops look neat, but man, I have experienced some 120A controllers overheat with more air than those scoops will provide. That is why Tam does what he does with his. Ace, are you just gettng ram air or are you letting the fan draw air in?
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 08:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 12:37 PM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 12:10 PM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 09:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 10:17 PM
