Old Jun 21, 2012, 05:10 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
No the wood blocks have been fitted inside the stabs in some, and in the elevator in others, solid strip in one side or the other, and the slots for the hinges have been cut in a position that misses the wood blocks completely which exacerbates the issue of the stab. Its also not stiff enough and the tips being wider than the root causes all these mistakes to add up and induce failure.
That said there are Snipers flying without issue, whether these guys figured out the hinge issue or not, changed hinges, changed LE and TE materials, fact remains they are flying and flying well from the videos.
And just to reitterate my views as I dont want to see another flame war in here; Personally I think HET needed to change the design back in the old sniper, I have posted up ideas for a new stab in here, many pictures, and I am not defending the current stab at all, I refuse to sell any snipers until things are sorted.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 21, 2012, 05:48 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by Lojik View Post
Didn't want to stir any s%^t in the thread sorry
I was just saying what I was told, we have allot of snipers in AU flying, some have the elevator flutter, some don't, the supposed reason was pre-drilled hinge holes missing the mounting blocks
Sorry, nothing against you Mate. I'm just an unsatisfied victim of Sniper flutter
Just once would like to hear some straight talk from HET. Like that's ever going to happen.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 21, 2012, 07:33 AM
falconjet50 is offline
Find More Posts by falconjet50
United States, FL, Coral Springs
Joined Jan 2007
Originally Posted by CRCJA View Post
@falconjet50, man that Bird came out really nice, I am going to have to step it up a notch. Are those eflite retracts? What struts did you use?
@Scalefan. Hey AL, I got sidetracked on my build and just glued in the rudder and put in some lightning holes in the wings and rudder.
Ralph
Yes they are the Eflite retracts with Tamjet upgraded trenion and trail-n-link gear. I upgraded them my self with his instruction manual. They are very nice and buying from him was great. He actually answered the phone when I called to ask questions about the upgrade. He said the gear is good up to 11Lbs with the upgrade. Gear doors where made from some heavy duty plastic. They where spacers for a drawer I bought for my RC truck parts.
falconjet50 is offline Find More Posts by falconjet50
Old Jun 21, 2012, 03:33 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
You xan check rc lander full metal retracts at hobbyking. They will handle the plane just fine. Thereare also available as retracts only without struts...
In the new items there are also some new ones with 4mm pins and metal trunion..
pavcon is offline Find More Posts by pavcon
Old Jun 21, 2012, 10:42 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Wings Man
@Lojik, I don't know what would give you that Idea, I am working on the Sniper XL right now, oohh look shiny. OK, I am also finishing my C-17, Mirage, making missile rails for the F-16 and last but not least making a new canopy/cockpit for my Bobcat 50, so this week, I've had my hands on 5 planes so far. Got to keep it interesting.
I am working on the wings tonight, I can't stress enough, how much time you will save yourself by pulling the cables though the wings before you glue the wings together. I always keep a Ny-Rod around to fish cables out, I used it this time to put in the three extensions on the wing and two air lines. (Two servos per wing, one for the lights. One air line for retracts (air up, Spring Down) and one airline in case I add brakes). It was a warm day so at 8PM it still registered 106 and the Garage about 10 degrees hotter, the one thing I notice is that I used the 24 hour Aeropoxy on the wings and it was starting to harden up in about 30-40 minutes, the heat activated the glue a lot faster. I used the 30 minute Aeropoxy and added a former in the forward part of the fuselage so that I could put in a pin/dowel to also hold the wing in place.
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Jun 21, 2012, 11:16 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Preeeetty sure I mentioned pulling all your cables through in one of my earlier posts... nobody pays attention these days
Also recommend you glass the Center Section of the Wing... you know... knowing how you fly...
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Jun 21, 2012, 11:39 PM
CRCJA is offline
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Yep
Vic,
I don't doubt you mention pulling the cables to save time, but this thread is 104 pages long and I rather build the plane my way then search all the pages. I am not glassing the wings since I am sticking to the 8S set up for now, if I decide to go ballistic, then I will glass it later, right now I am just trying to finish the plane.
Ralph
Vic
Old Jun 22, 2012, 02:43 AM
heliclown is online now
Find More Posts by heliclown
Australia, NSW, Hillsborough
Joined Feb 2008
Acemigkiller
Hi Ace
Would you mind telling me your flight times you and corsairnut ,are getting on your respective setups(from your video on pge 69) please?
Steve
heliclown is online now Find More Posts by heliclown
Old Jun 22, 2012, 03:46 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
5-6 min depending on how i fly, and that leaves a 20% backup in the packs for a extra go around if needed
corsair nut is offline Find More Posts by corsair nut
Old Jun 22, 2012, 01:06 PM
CRCJA is offline
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Sniper XL Drawing
Vic,
Do you have the drawing of the Sniper XL, in all white? I saw before that you had posted one with the Blue for your paint scheme and now that I want to add some decals to my plane, I can plan better if I had the drawing.
Ralph
Old Jun 24, 2012, 03:25 AM
Joined Feb 2008
Thanks Brent.
So do you reakon i could get 3 mins WOT using 4500mah 8s, Jetfan 90, with HET 700-68-1500?
Steve
Old Jun 24, 2012, 04:57 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Just work out the maths, divide the WOT amp draw by the pack size, then divide 60 by that figure.
So 87 amps running 5000mah packs = 3.43 minutes. Thats 3 mins and barely reserve for one mistake.
Using 4500mah packs will give you 3mins exactly, which means 2.5mins plus a little reserve.
Old Jun 24, 2012, 04:39 PM
Joined Feb 2008
Thanks Mark
But can you just expand on that, for i am still learning.Should i be calculating the run time on 80% of capacity,and not 100%.
ie 5000mah x 80% = 4000mah,so 87amps @WOT=2.75 minutes ??
and for 4500mah pack-x 80%=3600mah @WOT=2.48 minutes?
If that is the case, i think the 5000 packs would be the minimum.
I think i will have to forget about the 4500 pack i already have,and go bigger.
Steve
Old Jun 24, 2012, 06:28 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Yeah thats a good way to work it as you ideally dont want to be running your packs past 90% anyway regardless they are singles or in series.
80% means you have a margin for landing and a slow circuit if some issue arises on the field. You dont want to get caught out with an expensive composite model!
Old Jun 24, 2012, 06:35 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
If someone`s in the way you can always chop the power and call "Dead Stick", but then if you abort you might get some dirty looks. LOL
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
