United States, OH, Cleveland
Joined May 2012
Basically you have to install them, program the ESC and see if they run in reverse. If you have the motor run in reverse simply swap two of the three wires around. There is no wrong or right way for reference on wiring these and it won't burn up the motor when doing this.
I understand about the cooling too so a pump would be a good idea no matter what. I also agree this setup does need gearing in order to help with run time and lower operating temperature. |
United States, NY, Babylon
Joined Feb 2012
Hi band1
The wires can go in any order. If the motor is turning in wrong direction just swap any two wires on the motor and it will go in other direction. I just wanted to say you are doing a fantastic job building the donzi! It is beautiful!!!!! I'm afraid that the motor choice might destroy all of your hard work. James should have given you lower kv motors around 600-700 out runner motors. They have more bottom end power. Just my two cents. Keep up the fantastic work. I am looking forward to the rest of the build. Doug |
United States, NY, Pawling
Joined May 2007
Hi Paul,
Below is a picture of my water cooling pumps for reference. I think I mentioned these to you at the Christmas party. The pumps are in place but I don’t have them hooked up yet. I’ll be sure to post an update on them. For the Donzi all he needs is 1 or 2 at most. My cooling system is a bit extreme and is mostly for aesthetics for anyone wondering why I have 4 pumps... I’m running these on a single servo controlled switch so that the system can be turned on/off on demand so that they don’t waste too much power. I will likely run those 2 minutes on, 2 minutes off, etc but enough to whisk away and manage the heat. I don’t know how much he could get away with that setup. They might need to be on all the time but having the pumps servo controlled should be helpful to prevent over discharging the batteries. -Rich. |
Joined May 2007
Hey captains,
With all that Donzi talk...Looky here: http://www.ebay.com/itm/110986832373...84.m1423.l2649 -Rich. |
| Thread Tools | |
| Discussion Could a Single Marine Unit Destroy the Roman Empire? | Big Foot 48 | Life, The Universe, and Politics | 162 | Nov 07, 2011 05:47 PM |
| Gallery North Shore Model Mariners | charlie eaton | Dock Talk | 106 | Jun 22, 2011 09:30 PM |
| Empire Mine State Park - Bourne Cottage | MX | Aerial Photography | 9 | Feb 17, 2004 04:31 PM |
