Old Nov 09, 2011, 11:34 AM
dafremen is offline
Find More Posts by dafremen
Indoor RC Hotdog
dafremen's Avatar
Joined Aug 2011
Data
The great wall xieda 9958 reference list of everything we know so far
Any help would be appreciated in compiling a list of reference material for the GW Xieda 9958 Helicopter.
Since the main discussion thread is becoming a bit long and unwieldy for the initiate or modder looking for information on one aspect, problem or other, this thread is meant to be wiki-like in that its presentation and contributions should try to add to or edit this list.
This list is constantly under construction and any information which can be added, corrected, confirmed or completed would again, help a lot.
If you have data to add, mentioning the section number would be really helpful. Example:
(Subject Line) Section 2: GW-9958-001 Main Circuit Board
Then the body of whatever data you have in the post. Put links, comments, tips tricks to making things work..etc. Whatever you think is relevant. Together, we'll try to figure out how to fit all of the information into the various sections. Corrections are a good thing as long as they are accurate.
If you feel a new section is required, mention that in the subject line if you could, to make it easier to pick out. Finally, thanks in advance to all of you 9958 people(and anyone else who cares to contribute) for your help in making this a hot little helicopter to own, mod and fly!
Description:
ONLINE LOCATIONS WHERE GW XIEDA 9958s ARE SOLD
(Not an endorsement of the sites or vendors.)
(List updated as time allows, please submit corrections or additions.)
Focal Price (Great deals, but risky shipping):
Focal Price (Purple)
Focal Price (Black)
Focal Price (Red)
MyRCMart:
MyRCMart (Purple)
MyRCMart (Black)
MyRCMart (Red)
Helipal:
Helipal (Purple)
Helipal (Black)
Helipal (Red)
RC-711:
RC711 (Purple)
RC711 (Black)
RC711 (Red)
Hobby King:
Hobby King (HK-190 Red Only)
Recommended that you order the following spares, you decide how many of each based on your skill level. The list is in order of priority based on two criterion: likelihood of breakage and critical nature of the part
(a landing gear vs. a flybar for instance.)
Red is highest priority, green is lowest:
Main Blade - Flybar - Battery - Tail Rotor - Tail Motor - 4 in 1 Board - Landing Skid
Without further ado:
THE GW XIEDA 9958 REFERENCE LIST OF EVERYTHING WE KNOW SO FAR:
SECTION 1. Alternative re-brand models, so we can keep them all straight:
Great Wall Xieda 9958
Rebranded as:
Heliguy Atom FP
Jamara E-RIX 100
Hobby King HK-190
Lindinger Excell 200
Nincoair 190 EVO ONE
TJD Mini Twister Sport
SJ Technologies Hawk XS
SECTION 2. Compatible replacement, modification and/or upgrade parts:
GW-9958-001 - Main Circuit Board
Alternate Part Numbers:
Hobby King HK-190: HK1903025
Great Wall GT-9998 Coaxial: 9998-020
Proven Alternatives(Mod Parts):
Ninco Air 190 EVO ONE: NH90663(Includes Left & Right Servo)
GW-9958-002 - Servo (Left)
Hobby King HK-190: HK1903024A
GW-9958-003 - Servo (Right)
Hobby King HK-190: HK1903024B
GW-9958-004 - Main Motor
Hobby King HK-190: HK1903019
GW-9958-005 - Tail Motor
Hobby King HK-190: HK1903018
GW-9958-006 - Main Shaft and Main Gear
Hobby King HK-190: HK1902012
GW-9958-007 - Main Shaft Collar
Hobby King HK-190: HK1901020
GW-9958-008 - Bearing Set
Hobby King HK-190: HK1901035
GW-9958-009 - Swashplate
Hobby King HK-190: HK1901016
GT 5888 Coaxial:5888 (015) Universal Component
(Requires re-shaping or rebuilding of the servo arms and resizing of the swash ball links. Modify
to increase sensitivity, for better wind handling and more cyclic authority in all directions.)
GW-9958-010 - Rotor Head/Hub and Main Shaft Cap
Hobby King HK-190: HK1901013
Blade mCX/mCX2 Lower Rotor Head: EFLH2217
(Use Blade mCX/mCX2 lower blades with this mod for durability and weight reduction.)
GW-9958-011 - Linkage Rods (4)
Hobby King HK-190: HK1901014
GW-9958-012 - Servo Arm Set (2)
Hobby King HK-190: H1902021
GW-9958-013 - Linkage Rod Holder
GW-9958-014 - Screw Set
GW-9958-015 - Feathering O-Rings
Nine Eagles Solo Pro Canopy Grommets (set of 8): NEANE4260020
(Requires slight enlargement of canopy holes. Modify if you're tired of keeping track of o-rings.)
GW-9958-016 - Flybar
Hobby King HK-190: HK1902003
Blade mSR Flybar: EFLH3011 (slightly smaller ball links)
(This modification is for improved response and weight reduction.)
GW-9958-017 - Main Chassis/Frame
GW-9958-018 - Landing Skid
Hobby King HK-190: HK1901031
GW-9958-019 - Main Blades
GreatWall GT-9998: 9998-02 (Lower 'B' Blades)
Hobby King HK-190: HK1901017
Nincoair 190 EVO ONE: NH90669("Blade Set" includes Tail Rotor)
Blade mCX/mCX2 Lower Blades: EFLH2220
(either add spacers, or replace rotor head/hub with mCX/mCX2 lower head/hub for durability & weight reduction.)
GW-9958-020 - Tail Fin
Hobby King HK-190: H1901038(Standard Red)
GW-9958-021 - Canopy
GW-9958-022 - Battery
GW-9958-023 - Tail Rotor
Hobby King HK-190: HK1901040
GW-9958-024 - Tail Motor Set (Combines 005, 025 & 026)
Nine Eagles Bravo SX Tail Set: NE402320009A
(So far the most powerful alternative tail motor. Modify for more tail authority.
E-Flite Blade mSR Tail Set: EFLH3002(includes rotor)
Nine Eagles Solo Pro Tail Set: NE4260007(Red), NE4260016(Yellow), NE4260032(Blue)
(Nine Eagles Solo Pro Set also includes Tail Fin)
GW-9958-025 - Tail Motor Mount/Holder
GW-9958-026 - Tail boom
GW-9958-027 - USB Charging Cable
(WARNING: This charging cable has no protection circuitry.
DO NOT USE this cable with any but the 9958's Stock batteries
which have protection circuitry built into the battery.)
GW-9958-028 - 2.4 GHz Transmitter
SEE SECTION 3 BELOW
SECTION 3. Compatible Transmitters and links to their settings and/or manuals:
Turnigy 9x - Flysky 9x - Eurgle 9CH - IMAX 9x - Manual Here
Hobby King HK-T6A/FrySky FS-CT6A - Manual Here
Axion AX-4 CT
Jamara E-Rix 100 Tx (Part/Model No. Needed)
GT 5888 Coaxial Tx (Part/Model No. Needed)
GW 9998 Coaxial Tx (Part/Model No. Needed)
SECTION 4. Complete modification sets, results and/or performance data.
Review, Mod Blog, Reference Material & Video Links Go Here:
Trimming your Xieda 9958 by HeliPad and by Daryoon
Binding your 9958 to the Turnigy 9x by JohnnyRockets
Upgrading Your Turnigy/IMax/Flysky 9x With ER9X Custom Firmware
Daryoon hacks a DSM2 module into his Turnigy 9x
Wiring the E-flite MLP4DSM Module into the Turnigy/IMax/Flysky 9x (for compatibility with E-Flite 2.4GHz products)
Setting up Flying Model Simulator With Your Turnigy 9X (Battery Free) and HeliSimRC from Marksfiles
Daryoon's Carbon Fiber Main Shaft Mod
EQMod's Ball-Guided Flybar Mod
EQMod's Z-Bar Flybar Mod
The TWIST Mod - Improved Cyclics in Seconds
RCHOLIC's Shortened mSR flybar with accompanying video.
Replace Feathering O-rings with Nine Eagles Canopy Grommets
Inexpensive Rain-Resistant Tx Bag for Flying in the Rain
SECTION 5.Technical Specifications: Measurements and other numeric data related to stock performance.
>>>>ATTENTION: I no longer have a stock heli and the data varies wildly on the internet.<<<<
Please assist by posting whatever technical data you can.
Weight(grams, no battery): 27.7g
Stock Battery Weight: 4.76g
Nose to Tail Length(No Blades): 200mm
Overall Length (Tail Rotor Tip to Main Blade Tip): 232mm
Fuselage Width (at Widest Point): 43mm
Overall Width/
Main Blade Length: 179 mm
Main Blade Speed
(RPMs/full charge/full throttle/100% power): 3180 RPM (laser tach data courtesy of monkeyhanger)
Maximum Lift(grams): ??
Tail Rotor Diameter: 36mm
(Feel free to post any technical specifications you find missing or in error.)
SECTION 6.Trouble Log: Problems seen, studied and solved here:
Unresolved issues:
Issue:
No main motor cutoff on TX signal loss. (Helicopter flies away.)
Description:
Due to the relatively short range of the stock Transmitter, occasionally the 9958 can and does fly out of range of the transmitter signal. This is particularly likely if the batteries in the Tx are low. Once the helicopter is out of range, it no longer responds to commands, and if in positive thrust (high throttle), can fly off..lost for good. Throwing the transmitter high into the air with the throttle in the off position may save your helicopter. A longer range Transmitter masks the issue but doesn't resolve it. (The problem seems solved until the helicopter is out of range of the long range transmitter.) A solder in circuit to shut down main motor power upon Tx signal loss would be ideal.
Resolved Issues:
Issue:
Helicopter drifts while hovering and electronic trims are at maximum.
Description:
After adjusting the electronic trim to its maximum extent, the helicopter still drifts in the trimmed direction.
Resolution:
Manually trim the helicopter using these instructions.
Issue:
Stock charging cable has no built-in protection circuitry.
Description:
The USB charging cable provided with the Xieda 9958 comes with no overcharge protection circuitry, since this circuitry is built into the stock 9958 batteries. However, since the majority of manufacturers DO NOT build protection circuitry into their batteries, connecting any batteries but the stock 9958 batteries WILL result in puffing, battery damage, and more critically, extremely dangerous fire hazards.
Resolution:
Do NOT charge any batteries but the STOCK 9958 batteries if you are using the USB charging cable that comes with the 9958. 9958 stock batteries may be charged in ANY charger that accepts eflite/Ultra Micro connector type batteries. The batteries are universal, the USB charging cable is NOT. For peace of mind, it is recommended that the stock USB cable be tossed or stored away and that a standard charger be used instead.
dafremen is offline Find More Posts by dafremen
Old Nov 09, 2011, 11:48 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
unresolved issues: Heli will fly off when contact with TX is lost.
SoloProFan is online now Find More Posts by SoloProFan
Old Nov 09, 2011, 01:30 PM
jlk69 is offline
Find More Posts by jlk69
RC Aircraft Junkie
jlk69's Avatar
USA, CA, Chula Vista
Joined Sep 2004
SECTION 2. Compatible replacement, modification and/or upgrade parts:GW-9958-024 - Tail Motor Set (Combines 005, 025 & 026)
Proven Alternatives(Mod Parts): Bravo SX, Solo Pro and mSr tail sets are a drop in replacements with Bravo SX being the most powerful motor. Credit for this one also should go to Daryoon.
jlk69 is offline Find More Posts by jlk69
Old Nov 09, 2011, 01:51 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Cool! Thanks for starting this one up.
I thought my other helis fly off when the transmitter is turned off as well.
Daryoon is offline Find More Posts by Daryoon
Old Nov 09, 2011, 02:06 PM
helicopcat is offline
Find More Posts by helicopcat
helicopcat's Avatar
Joined Jan 2011
Section 1
Thanx for starting this thread.
I would suggest to add a list of online shops which sell the 9958 in every variation available, to assist new users who want to buy it.
helicopcat is offline Find More Posts by helicopcat
Old Nov 09, 2011, 02:19 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Daf, Thanks for taking the first step. This is great stuff. I move that we all Report this post to a Moderator and request this thread to be STICKY. Do I have a 2nd?
Proven Alternatives(Mod Parts): Solo Pro Canopy Grommets
Credit goes to Daryoon, who showed me how to do this simple mod. Instructions: Buy Grommets for Solo Pro. Use Xacto knife to slightly enlarge the existing canopy holes. Install grommets once and forget about it. Nice, tight fit, and never lose another O-ring ever again!
Heli Pad is offline Find More Posts by Heli Pad
Old Nov 09, 2011, 02:25 PM
jlk69 is offline
RC Aircraft Junkie
jlk69's Avatar
Joined Sep 2004
Yes, mods please make this thread a STICKY
Old Nov 09, 2011, 02:46 PM
dafremen is offline
Indoor RC Hotdog
dafremen's Avatar
Joined Aug 2011
Thanks guys. I was hoping this would be useful to everybody, now and down the road. Up front there is a lot of legwork to do to fill out these parts lists. Can anyone find some time to get the alternative part numbers from nincoair and any of the other rebrands so i can just cut and paste them in?
Which swashplates have been tried that are drop-in replacements? Which require minor modification, but work?
Are there part numbers available for the 5888 and 9998 remotes? Whgat do we know about that Jamara remote? I know there's a solo pro upper swash mod you did Dary. I also know someone did a shortened mSR flybar mod at one time.
Etc. ETc.
helicopcat: We should probably stick with vendors we know are stable, and will continue to support this model. I'll list links as you guys provide them. If we can take turns checking the links once every few days or so then we can keep the list fresh, and I'll update as you guys provide corrections.
daf
P.S. I have had short term memory issues for a couple of years now, so your posts are imperative to keep me on track.
Old Nov 09, 2011, 03:00 PM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
THanks for starting this.
Many of EQMod's & related MSR mods can be adapted & applied to the 9958.
http://www.rcgroups.com/forums/showthread.php?t=1276901
http://www.rcgroups.com/forums/showp...10&postcount=3
Brosol is offline Find More Posts by Brosol
Old Nov 09, 2011, 03:11 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Charging: Do not use the USB cable that comes with the RTF kit to charge any other battery than the stock lipo! It has no charge control logic, this is built into the stock battery. After market cells usually don't have this, and rely on the charger to monitor the charging progress.
Old Nov 09, 2011, 03:24 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Daf, Recommended batteries section? I've been using Turnigy Nano Tech 160mAh 25-40C.
Old Nov 09, 2011, 03:31 PM
helicopcat's Avatar
Joined Jan 2011
+1
Please....
Old Nov 09, 2011, 03:47 PM
helicopcat's Avatar
Joined Jan 2011
online locations
MyRcMart (black)
MyRcMart (purple)
MyRcMart (Red)
HeliPal (black)
HeliPal (purple)
HeliPal (red)
I would suggest to specify that at FocalPrice there is no mode1/mode2 selection available when ordering... you can only send a message after...
Old Nov 09, 2011, 03:49 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Guys, don't just tell us that you want this thread sticky. Please tell the mods by clicking on the link "Report This Post to a Moderator" in Post #1. You could then select "Sticky this Post", and if you feel inclined, write to the mods why it should be sticky.
Old Nov 09, 2011, 03:56 PM
jlk69 is offline
RC Aircraft Junkie
jlk69's Avatar
Joined Sep 2004
Thank you for the great idea!
Done.
New Product GW Xieda 9958 Frank_fjs Micro Helis 7500 Jan 06, 2015 11:20 AM
Discussion 9998 Xieda Great Wall Toys Super Uncommon! FreakFlow Coaxial Helicopters 39 Dec 05, 2013 05:45 PM
Mini-Review GW Xieda 9958 - Review Frank_fjs Micro Helis 10 Nov 24, 2011 09:38 AM
