Centreville,VA,USA
Joined Apr 2001
Thanks Billy.
No Jay, I enlarged the paper plan to a 14" WS then trace the cut out parts on to the 2 & 1 mm Depron with an Ultra Fine Point Sharpie. Though it could be done. Mark Millers drawings have shadows in etc that wouldn't work besides I do like to airbrush on the colors and make my own decals. Pete |
Centreville,VA,USA
Joined Apr 2001
Yes BS here's where I'll be posting on the build.
I cut out out some of the traced parts and test fit taped them together. I needed to adjust the front cockpit top pattern cut off about 2mm on each side due to the 2mm thickness of the depron. Also found a nice paper LeRohne motor front for inside the cowl. I don't like the Depron cowling and think I'll make a mold and vac form one. I think a good cowling on this bird is key. I thinking on using a PZ servo for the ailerons placed far forward as that will give me additional nose weight since the nose area is so short I think I'll need all weight close to the front to get the CG. I will redo the bottom wing as a one piece both wings will have a small CF rod as well for additional strength. All LE & TE's will be tappered. Pete |
Centreville,VA,USA
Joined Apr 2001
Thanks Jim, I hope to make some new castings and get them out to you.
I shaped the cowling mold from blue foam. I'll cover it with 5 min epoxy then use it to vac form a styrene one. I made some sanded clear plastic wing struts I will change them to 1/32 ply, I just wanted to see how it would go together I may adhear the plastic to the ply for added strength. I used sand paper around a marker to make groves on the tops of both wings and sanded all LE & TE's It's starting to look the part. If I can get the CG without adding the extra PZ aileron servo I'll skip the ailerons as I want to get this bird done doing the ailerons right will take time. Pete |
Yes. Get her done..... then send her to me
![]() Awsome build. Just awsome. My opinion on the Ailerons is keep em out, i think these birds fly much nicer when the pilot do not have access to Ailerons. (Thou I feel handicapped without them too) I wonder if they sell time as LHS. I need loads of it. I want to build these little gems too *almost crying* Keep up the good work. /Ulf |
Centreville,VA,USA
Joined Apr 2001
Thanks Methuso...
I only wanted to do the ailerons in this bird because of the way they are in the top wing with the cut outs and control horns sticking out it would require some tinkering using the PZ aileron. Camboui, I'm using enlarged paper model plans and as I wrote I use a Utra Fine Sharpie Permanent Marker to make all panel lines etc. I do this by tracing over the paper template with a ball point pen. It will dent the foam enough to see then use the Sharpie. I also use wax paper to trace needed lines as you can flip it and see through it. You do the lines before bending the foam. I also use clear packing tape on most builds before bending the foam that keeps it from cracking, I then remove it that usually requires doing the lines again and I may or may not need to do them again after painting depending on how much of the lines I want. It's pretty easy it just takes time. I've done tons of how to's in this forum and over in the War Birds and Micro Jet forums just do a search for mtflyr. I think when I built my Micro Spitfire, P-47, Mosquito FB and Micro P-38's I posted all the how to's you would need to see how it's done. Just do a Google search for paper model Nieuport or whatever plane you want and you should be able to find the plans. I'll post the ones that I used. They are good some are too detailed and do not make good conversions others are too simple and also don't convert well. I always do a sized up paper mock up first to see where problems might be to make any needed changes. I also do some research to add or change panel lines to be more scale. Lots of paper plans are off on proper panel lines etc. WWI birds are relatively easy WWII are a little harder. It depends on the plane. I shop around to find the best plan. Pete |
Centreville,VA,USA
Joined Apr 2001
Thanks Methuso...
I only wanted to do the ailerons in this bird because of the way they are in the top wing with the cut outs and control horns sticking out it would require some tinkering using the PZ aileron. Camboui, I'm using enlarged paper model plans and as I wrote I use a Utra Fine Sharpie Permanent Marker to make all panel lines etc. I do this by tracing over the paper template with a ball point pen. It will dent the foam enough to see then use the Sharpie. I also use wax paper to trace needed lines as you can flip it and see through it. You do the lines before bending the foam. I also use clear packing tape on most builds before bending the foam that keeps it from cracking, I then remove it that usually requires doing the lines again and I may or may not need to do them again after painting depending on how much of the lines I want. It's pretty easy it just takes time. I've done tons of how to's in this forum and over in the War Birds and Micro Jet forums just do a search for mtflyr. I think when I built my Micro Spitfire, P-47, Mosquito FB and Micro P-38's I posted all the how to's you would need to see how it's done. Pete |
Minneapolis, Minnesota
Joined Jul 2007
A-ha! I remember your P-38's, amazing finishing skills! I'm generally happy when something I build flies generally the way I expect, I've never put a lot of time in to the fine detailing - and my fine vision fades with each year. I did pick up a couple of airbrushes and propellant cans to play with during the long cold building season.
Jay |
| Thread Tools | |
| Question BUSA 1/6 Nieuport 17 Plans / Instructions Question | Thermalin | The Builders Workshop | 15 | Jan 08, 2012 10:03 AM |
| Discussion BMI Nieuport 17 - 1524mm wingspan | zaguruinzasky | Scale Electric Planes | 8 | Oct 10, 2011 07:19 PM |
| Sold EFlite Nieuport 17 250 ARF NIB | rcsoar4fun | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 04, 2011 10:11 PM |
| For Sale VK models Nieuport 17 nib 70's | L brown | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jun 10, 2011 11:54 PM |
| Discussion E-flite Nieuport 17 | enemyace19 | Parkflyers | 1 | Jun 10, 2011 11:01 AM |
