Old Oct 17, 2012, 02:05 PM
MacManOhio is offline
Find More Posts by MacManOhio
Joined Oct 2012
Originally Posted by Av8Chuck View Post
I have moved my NAZA from my HEX to a Y6.
On the HEX I had:
RCTimer 30A ESC
Futaba 10 channel Rx
Avroto 2814 motors
11" props
On the Y6 I have:
Turnigy 25A Basic ESC
Futaba SBUS Rx
Avroto 2814 motors
11" props
I upgraded the Assistant Software to version 1.2 and the Firmware to version 1.4. I was able to calibrate the NAZA with the Tx OK, the first time I tried to Arm only one motor armed, they all twitched but only one beeped and spun up. With the help from FrankenQuad I figured out which motor port was arming on the NAZA and tested all of the motors one at a time connecting to that port. They all armed.
So I reloaded the firmware and tried again, this time two of the motors armed.
I'll email this to support, I was just hoping someone might know something that I'm missing. Any suggestions appreciated.
Can you or anyone else tell me where I can acquire or download the Assistant Version 1.2?
MacManOhio is offline Find More Posts by MacManOhio
Old Oct 17, 2012, 02:09 PM
tavares99 is offline
Find More Posts by tavares99
Joined Mar 2011
DJI F450 NAZA modo (A) (0 min 41 sec)
tavares99 is offline Find More Posts by tavares99
Old Oct 17, 2012, 04:21 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Why not use the latest software??
Bill Glover is online now Find More Posts by Bill Glover
mewert is offline
Find More Posts by mewert
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
Goldberry, You said you threw it away in the trashcan at the park!!
mewert is offline Find More Posts by mewert
Old Oct 17, 2012, 06:13 PM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Going Back = Difficult
And DJI pulls down the old software links from the internet except for the version previous to the current one.
I suspect they encourage their dealers to do likewise.
I've tried to help several posters looking to stay with or return to old software versions without much success...
If a new software version is not behaving, you'd better start figuring out what might be causing it other than the software.
T J Gilbert is online now Find More Posts by T J Gilbert
Old Oct 17, 2012, 07:39 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
GW your lipo is looking a little puffy.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Oct 17, 2012, 07:45 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
I havent noticed I guess it could be all the extra layers of protective tape I added to it. It ballences out and holds full charge.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Oct 18, 2012, 03:00 AM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
I put this up on the NAZA GPS site too but it might help someone else struggling with setups.....
Strung up my quadcopter using the NAZA controller, tethered testing to ensure all working OK and test of remote gain adjustments. aggressive control movements to check response. (AX2810 750KV motors, 40A HobbyWing Pentium ESC's (not flashed), 11x5 Graupner props)
When the gain adjustments (pitch and roll) are increased to 150 on the transmitter slide control and the attitude gains increased to 180 fast shaking can be seen....... Just testing the basic 'X' before adding the frame and camera etc. ...Testing on a string....it's GREAT! should have done this first.........
LARGE QUADCOPTER TETHERED TESTING ! (1 min 21 sec)
jetstuff is offline Find More Posts by jetstuff
Old Oct 18, 2012, 06:49 AM
windfou is offline
Find More Posts by windfou
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
This method as been use for a long time a ago by kapteinkuk and yes its can be good to use this method but the gain are different for each multirotor because they have different length and weigth
windfou is offline Find More Posts by windfou
Old Oct 18, 2012, 10:33 AM
godwisper is offline
Find More Posts by godwisper
Joined Aug 2012
Originally Posted by glmccready View Post
godwisper: I have my control mode to the gear output. On the DX8 I "channel switched" my Aux 2 to gear, for the three way switch. Guess you could just plug into Aux2 but I originally set it up on an AR6020, so I just kept it that way.
Ok connected control mode to aux 2 ....do I connect x2 to gear ?
Have another issue....have connected the 2 axis gimbal but nothing happens when I tilt or roll the quad...gimbal though moves when I put on to off in the menu.... My servos are the Es08d and tried already the various frequencies
godwisper is offline Find More Posts by godwisper
Old Oct 18, 2012, 11:25 AM
BerndM is offline
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
Cool demo Jetstuff! Thanks!
Nice lathe BTW.
BerndM is offline Find More Posts by BerndM
Old Oct 18, 2012, 02:15 PM
Joined Mar 2012
Here ya go TJ!!!!
Frank Sinatra - At Long Last Love (7 min 13 sec)
Old Oct 18, 2012, 03:49 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I use Aux 1 for the U channel and X2 for Gear. Mo mapping involved.
Site Sponsor
Old Oct 18, 2012, 07:36 PM
joeb56 is offline
Find More Posts by joeb56
Australia, NSW, Mt Hutton
Joined Jul 2007
I had an issue when I activated the gimbal controls where the F550 wanted to immediately roll to the right on lift off
Disabled the gimbals problem went away - might be the issue when I thought about it I suspected it could also be me taking off too soon - anyway decided to try and sort it out but ran into another issue
Both servo's are locked up solid (futaba S3156) even when they are completely disconnected
running a seperate BEC at 6v and at 200freq
any ideas on how to unlock the servos and or anyone else seen this happen
cheers
Joe
joeb56 is offline Find More Posts by joeb56
Old Oct 18, 2012, 10:25 PM
muduck is offline
Find More Posts by muduck
muduck's Avatar
Australia, NSW
Joined Apr 2004
Help
After you write in the setup program,& export, you then name the file..when I import, I don't see that file name??????what gives?
muduck is offline Find More Posts by muduck
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
