Old Oct 09, 2012, 10:04 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by T J Gilbert View Post
No picture, but the answer is yes.
It should be easy as most rec I've seen have the antennas attached right out on the edge of the PCB.
You might discover some adhesive helping hold the wire to the PCB.
Cut that away, and replace it (if you want) after you're finished with something appropriate.
Use a low wattage PCB iron.
It'll be like soldering the ESC wires to the Naza bottom plate in minature...
So since there is no loose rattling sound coming from the receiver I will assume the clip if there is one is still in place on the board. The end of the wire that came out looks like it just separated from the inside. This receiver has 2 antenna wires so I bet it still is flying using the still attached antenna wire. I will open the case and see if I have the skills to re solder the wire to whatever it was connected to. If I need adhesive I guess I could just use my hot glue gun.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Oct 09, 2012, 10:09 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
GW what are you doing?! Are you sick?! You do know you can buy them in bulk HERE.
MCrites is offline Find More Posts by MCrites
Old Oct 09, 2012, 10:36 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Futaba = Easy
Originally Posted by 320pilot View Post
usually these antenna wires are attached to a clip, that is a press fit to the motherboard.
Open up the case, and have a look inside, here is a picture of the inside of a Futaba Rx . You can see the two antenna wires, and the metal clips at the end that are a press fit onto a male pin on the circuit board.
If the clip receptacle is broken or damaged, you need a new receiver. If the wire is just broken, you might be able to order a replacement antenna wire?
Man, the Futaba attachment looks really user friendly (+1 for Futaba).
If Futaba is what GW has, he might not even have to solder.
I know that the Spektrum antenna wires are soldered to the board.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Oct 09, 2012, 10:39 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
+1 on that
Mauro
mauromassari is offline Find More Posts by mauromassari
Old Oct 09, 2012, 10:40 AM
Joined Mar 2012
Dont be a wise a%&^! Thanks for the link I just orderd 6 at that great reduced price!
Old Oct 09, 2012, 04:35 PM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
Georgian Peaks FPV
I was at the Georgian Peakss ski club with my Naza TBS Disco for some FPV fun. I hooked up with the boys from TBRC, Zoltan from NGHobbies, Greg from Fatshark and a few more fellows. Lots of flights from wings to multis. Here are a few pics and my two flights.
Geogian Peaks FPV #1 (11 min 5 sec)
Georgian Peaks FPV #2 (10 min 26 sec)
Buffythesaint is offline Find More Posts by Buffythesaint
Old Oct 09, 2012, 05:13 PM
Hkubota is offline
Find More Posts by Hkubota
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
Originally Posted by goldsworthy View Post
Here is a photo of the type receiver I use showing the 2 antenna wires. Thanks!
I got the RX 802 and it has the "normal" antenna sockets. For 2.4GHz stuff you rarely see something else. Any replacement antenna should work. I ordered some from HK which are originally for FrSky.
Hkubota is offline Find More Posts by Hkubota
Old Oct 09, 2012, 10:29 PM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
Here is a screenshot of the Naza Manual where DJI does not recommend the Naza FC for more than 650mm.
Your link does show the FC on a larger frame.
Draw your own conclusions...
Experimenting is what a lot of this hobby is about.
Let us know how it goes if you decide to try it!
TJ, Don't you remember? You helped me get this beast going. It's 110cm (1,100mm) M to M.
http://www.youtube.com/watch?feature...&v=r2lbfIvDevs
mikemijal is offline Find More Posts by mikemijal
Old Oct 09, 2012, 10:40 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
There is at least one person using a Naza with GPS on an S800 frame.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Oct 09, 2012, 10:44 PM
Westland Michigan.
Joined Jan 2012
Tahoe Ed , You were a big help for me also !!!
Old Oct 09, 2012, 10:48 PM
Empire Support
Joined Feb 2009
I do now! You're a fellow 62 yr old!
I'm sorry.
After a while, all the posts and issues sort of swim together or fade to gray.
I think you probably understand that...
Like wazzer and I were saying, it should work, and your success proves it!
Thanks for the reminder...
I'd also forgotten how impressive the video was! Went back and watched it again. You're setup must be near perfect to achieve such steady results. I sincerely doubt anything I posted caused your craft to fly that well. That credit goes to you as the builder/pilot. Kudos!
Thanks for sharing it again.
BTW, what ESCs/motors make up your powertrain?
Brand and size, if you don't mind...
Last edited by T J Gilbert; Oct 09, 2012 at 11:30 PM. Reason: Watched the video again...
Old Oct 10, 2012, 03:17 AM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
That's a relief, as I've just built a quad that's only 690mm motor to motor and have not tried it yet until the 2nd Naza arrives.
http://www.rcgroups.com/forums/showt...7#post22960454
john
jetstuff is offline Find More Posts by jetstuff
Old Oct 10, 2012, 07:30 AM
Empire Support
Joined Feb 2009
Sorry, Guys....
john
I didn't mean to lead anyone to think that Naza can't handle larger airframes.
Being the cautious fellow that I am, I just was insinuating that experimenting into unrecommended areas requires extra attention to details, trial & error work, and more knowledge.
Also, since most posters are here to air problems, the few success stories that are posted get covered up and forgotten. I honestly had forgotten mikemijal's success story (back in August & 2000 posts back on the GPS thread)...
Old Oct 10, 2012, 02:30 PM
Maxedout is offline
Find More Posts by Maxedout
Maxedout's Avatar
New Zealand
Joined Dec 2011
It works fine on my 1000mm MTM Quad.
Maxedout is offline Find More Posts by Maxedout
Old Oct 10, 2012, 02:35 PM
Joined Mar 2012
Your slipping TJ! I guess you must be getting old! Happens to the best of us I guess
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
