Old Oct 04, 2012, 10:49 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Watch the blanket!
Originally Posted by wazzer View Post
I was planning on staying clear of the water !
and i was planning on taking off and landing from a Blanket.
There's a lot of propwash off 4 props.
Weigh down the corners of the blanket so that they don't fly up and get sucked into the props.
Someone posted a few weeks ago about throwing a towel on an out of control Naza/Airframe to keep it from flying away. This is NOT a recommendation!
Also, check out pool noodle leg extensions as flotation devices...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Oct 04, 2012, 10:54 AM
Borneoben is offline
Find More Posts by Borneoben
United States, TX, Houston
Joined Jan 2005
Thanks for the advice TJ
I am very familiar with flying in sandy conditions I live in the Desert!!
Borneoben is offline Find More Posts by Borneoben
Old Oct 04, 2012, 12:17 PM
Empire Support
Joined Feb 2009
I've checked...
I see where you live...
You an expat or a native?
The blanket trick works anywhere, not just where it's sandy.
Tall grass and heavy dew can be just as annoying as sand.
Old Oct 04, 2012, 12:34 PM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
Originally Posted by T J Gilbert View Post
I'm sorry we're coming up empty.
If you'll keep trying...
And not go squirrelly on us.
We'll keep trying too!
Let us hear how the receiver test goes...
Well, here goes the saga...
1) Checked all ESC's and motors again and performed individual cals again.
2) performed complete cal with Assistant
3) replaced receiver with DX receiver - spins like a Whirling Dervish
4) replaced receiver with an AR 7500 receiver - still giving me the dreaded hi-speed spin.
5) Lightbulb comes on in my head (dim, but it's there)
6) I once again check cal in Assistant and note that I'm using the WRONG HEX SETUP!!! Hex I instead of Hex V!!! Aggggghhhh.
7) I click on Hex V and check cals...
8) take it outside and run it up - it's as solid as a rock and flies like a dream.
Trying to decide why this caused the spin I recall the discussion about "TBE". I never had an issue with this before but with the GPS antenna 30 degrees off in Hex I config it's no wonder it was spinning. The wobble occurred when I had the higher gains...the NAZA config fighting the GPS input. I now have the higher gains with no problem.
Sooooooo.....Next time I'll clear the plexiglass window in my abdomen so I can see more clearly. D'oh!
Thanks again for all the help, guys!
-bob
bobthenuke is offline Find More Posts by bobthenuke
Old Oct 04, 2012, 12:42 PM
70 is the new 50
bobthenuke's Avatar
Joined Feb 2005
Originally Posted by Tahoe Ed View Post
I have kids older than you. It is not the age it is the attitude. I think, and my wife confirms, that I am about 15.
The problem, as I see it, is that no matter how old you are chronologically, you'll probably always feel like you're still a teenager.
-bob (old guy)
Old Oct 04, 2012, 01:02 PM
Empire Support
Joined Feb 2009
Old =/= Dead
-bob (old guy)
First, I'm glad that you persevered, kept patient, and figured your way out of your problem.
Second, were you not an "old guy", First may not have happened.
Third, come back soon...
Enjoyed your blog, by the way...
And u2builder diagnosed what the problem was early on...
Last edited by T J Gilbert; Oct 04, 2012 at 02:20 PM. Reason: Gave u2 some credit! Us "old guys" have to stick together...
Old Oct 04, 2012, 02:06 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Bob, so glad you got it working. I wondered if that could be the problem,
Post 14563:
There are two hex configurations: perhaps you have the wrong one entered entered in Assistant?
Lesson for all of us is odd behavior like this is probably set up related and not the fault of Naza, unless of course the problem is followed by a hard crash!
u2builder is offline Find More Posts by u2builder
stefanoxjx is offline
Find More Posts by stefanoxjx
Italy, Veneto, Padua
Joined Mar 2008
Hello guys,
does anyone know if DJI goods (NAZA / GPS / WOOKONG) have CE certification (European certification)?
Thanks.
Regards.
stefanoxjx is offline Find More Posts by stefanoxjx
Old Oct 04, 2012, 02:39 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Well I did it my Naza is on its way
tech69x is offline Find More Posts by tech69x
Old Oct 04, 2012, 02:42 PM
Empire Support
Joined Feb 2009
Welcome
If you run into problems, we'll try to give you better than a -
"Take two aspirin and call me in the morning." answer...
Old Oct 04, 2012, 02:45 PM
70 is the new 50
bobthenuke's Avatar
Joined Feb 2005
Post 14563:
You were absolutely correct and I checked this, but my limited number of working neurons saw what I "expected " to see, not what was actually there, if you know what I mean.
In any case, you were the first with the correct answer and I truly appreciate it. Even retired engineers can be taught!
-bob
tech69x is offline
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Lol thanks I'm going to start reading all I can now
Old Oct 04, 2012, 03:48 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Ok guys I think I found the frame that I want to use for my y6 naza w gps fpv build. What do you guys think? http://www.vulcanuav.com/multiframe-Y6.html
flohio117 is offline Find More Posts by flohio117
Old Oct 04, 2012, 04:28 PM
Empire Support
Joined Feb 2009
Diy
A British seller wants almost $400 for that simple frame!
If you have tools, you can do that with G10 from McMasterCarr and aluminum tube from Lowes for less than $100...
Old Oct 04, 2012, 05:32 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
I thought the arms were made carbon fiber? The price I was quoted was $374 shipped but it comes with battery trays and all the necessary hdwr. It seems pricey but I'd like to use this frame for minor aerial photo flights. It seems plenty big enough.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
