Old Sep 03, 2012, 09:23 AM
pajonate is offline
Find More Posts by pajonate
pajonate's Avatar
United States, NJ, Fair Lawn
Joined Dec 2009
Originally Posted by antihero138 View Post
I will give it a try. I figured it was more about the prop resistance from the sound it was making while descending so that makes sense.I've also got it loaded down with the 468 gear/camera gimbal ,a gopro, 4s 4000 pack and soon to be downlink system. So I,m sure those props are doing some work.
What platform are you flying? F450 or higher. I think that F450 specs are: max weight 1600 gr or something around 3lb 8.44oz . If you are close to that weight, all the performance will be lesser than on a lighter F450.
pajonate is offline Find More Posts by pajonate
Old Sep 03, 2012, 09:40 AM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
Originally Posted by goldsworthy View Post
5 pounds does not seem heavy for a 550. you have 6 motors
Thanks.
Tony97 is offline Find More Posts by Tony97
Old Sep 03, 2012, 10:05 AM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
https://docs.google.com/spreadsheet/...ZbUhxZ3c#gid=0
CPMBOY is offline Find More Posts by CPMBOY
Old Sep 03, 2012, 10:14 AM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
hey guys (wt 10" graupner props),
do you guys use spacers on your props?
Old Sep 03, 2012, 10:21 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
1600gr =/= 4.7lb
Originally Posted by pajonate View Post
What platform are you flying? F450 or higher. I think that F450 specs are: max weight 1600 gr or something around 4.7 pounds. If you are close to that weight, all the performance will be lesser than on a lighter F450.
Check your conversion tables...
1600gr = 3lb 8.44oz
T J Gilbert is online now Find More Posts by T J Gilbert
Old Sep 03, 2012, 10:24 AM
Empire Support
Joined Feb 2009
F550 tow
Originally Posted by Tony97 View Post
Thanks.
F550 TOW = 2400gr = 5lb 4.66oz
Old Sep 03, 2012, 10:43 AM
naturecannon is offline
Find More Posts by naturecannon
United States, OR, Oregon City
Joined Jul 2012
9" graupners reamed to 8mm (stock motors). Using red DJI spacer on bottom of props and nylock nuts. Trouble free set-up
naturecannon is offline Find More Posts by naturecannon
Old Sep 03, 2012, 10:51 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Originally Posted by Atx_Heli View Post
Well ,I have tried the new NAZA with GPS after abandoning the original NAZA and F450 since I didnt like its feel and quirks in fast forward flight and was breaking DJI 10" props constantly in midair. I am very impressed with it...flies like its on rails...almost 100% of the time I stay in GPS mode for my FPV video flying now....great for following creeks through heavy woods, etc..and sustained fast forward flight doesn't have the pitch back quirks that the earlier versions did.
I started with a F550 running 4S and 8inch DJI props....but moved everything back to my F450 platform to get better duration...getting 7.5mins on 3300mah @ 1600g...seeking even more duration, I moved to 5000mah and got 9mins...but started breaking 8in DJI props...AUW 1780g....
consulting "e-calc" I found that moving to 10" props should give me 13.5 minutes...so I borrowed a friends set of Graupners....superbly stable flights of 13+ minutes....
BUT I CANT GET THE PROPS ANYWHERE!
has anyone flown the GemFan Carbon filled nylon props at loading of 450g/prop without midair breaks?I like GemFan props in general, but I know that the all nylon ones will break at that loading...I used the Carbon filled ones on my F550 at 300g/prop without any issues...
Here's a couple sources for Graupners:
http://www.rchobbyhelicopter.com/store52/agora.cgi
http://www.gothelirc.com/shopdisplay...Graupner+Props
@cpmboy: the second link has spacers, or try:
http://www.mcmaster.com/#nylon-spacers/=j4ruzk
Cervanchez is offline Find More Posts by Cervanchez
Old Sep 03, 2012, 10:54 AM
pajonate is offline
pajonate's Avatar
Joined Dec 2009
1600gr = 3lb 8.44oz
OOPS, I divided 56oz with 12 instead with 16. Apologies.
Old Sep 03, 2012, 10:56 AM
BerndM is offline
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
The Graupner 10x5 props are GREAT but the hub is a tiny bit too thin to fully allow the prop to tighten to the motor.
I use a thin 8mm stainless steel washer UNDER the prop so that the nut will allow me to properly tighten the prop.
Additionally, with the Graupners, I carefully sanded off the raised lettering on the top of the hub to allow the prop nut to FULLY contact the prop and not just the raised lettering.
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x5 Graupner Props /3S 2200 & 4000 Lipos / GoPro HD2
Spektrum DX-7 (original)
BerndM is offline Find More Posts by BerndM
Old Sep 03, 2012, 11:06 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
Disconnect the red wires from your ESC that go into your Naza. Also power up the motors first, and then apply power to the Naza. It may help. You can use the same battery, just split the cable to be able to power up the ESC separately from the Naza.
Hi Pajonate, after this new firmware this is not needed. I had to do that prior install it.
Mauro
mauromassari is offline Find More Posts by mauromassari
Old Sep 03, 2012, 11:08 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
I am so SUPRISED at you! I thought you were always mistake free!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Sep 03, 2012, 11:29 AM
Joined Jun 2011
I use a GWS 9X5X3 (3 blade prop) and it fly fine, just a little hard to balance then and use with 4S and my AUW is 2000g with 4S 5000mha. My flight time until autolanding is almost 12min but when it reaches 6min I bring it back home and have around 30% to 40% juice left. Hope it helps, they are cheap and never had then explode like other 10" that did a couple time to me.
Mauro
Old Sep 03, 2012, 11:31 AM
Empire Support
Joined Feb 2009
Tri Color LED
This article explains the VU's LED colors.
http://www.ledlights.org/tri-color-and-rgb-leds.php
After reading it, it's easy to see why some pilots see the yellow color as red.
If DJI had chosen a RGB LED, we would enjoy even more colors to discern...
Old Sep 03, 2012, 01:41 PM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Been fooling around with my Graupner failsafe to long and now its got me confuessed. Stupid question here now. When you flip your IOC switch to Home lock isn't that the IOC that tells the controler to RTH and return home and land all hands off sticks if so I found a work around the Graupner ppm failsafe bug.
kd4wen is offline Find More Posts by kd4wen
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 08:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
