Old Aug 31, 2012, 01:35 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
xxxxxxxxxx
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Aug 31, 2012, 02:36 PM
STORMYWEATHER is offline
Find More Posts by STORMYWEATHER
United States, NV, Nye
Joined Jun 2012
Can someone with a good stable flying dji Naza / gps on a FW450 stock dji motors and esc's running 3s with 10 inch props please post your PID'S AND SAVE ME ALOT OF TUNING.
STORMYWEATHER is offline Find More Posts by STORMYWEATHER
Old Aug 31, 2012, 02:48 PM
sundust is offline
Find More Posts by sundust
Türkiye, Ankara
Joined Nov 2009
Originally Posted by gww528 View Post
It is working correctly...
Manual version 2.1 page 21
Notices:
When switch to Manual Mode or Atti. Mode, MC will disengage enhanced failed-safe mode, you can re-gain
control of multi-rotor.
Figured it now... thanks
sundust is offline Find More Posts by sundust
Old Aug 31, 2012, 03:03 PM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
I am running evething close to default 110,110,135,100,90,90 but I run on 4S and 9X5X3 props and weight of 2Kg with 5000mha.
Mauro
mauromassari is offline Find More Posts by mauromassari
Old Aug 31, 2012, 03:13 PM
Joined Mar 2012
xxxxxxxxx
Gundy is offline
Find More Posts by Gundy
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
I am running mine with the default settings. No TB effect. great GPS lock. running a very heavy quad. GoPro, pan and tilt, landing gear, fpv gear and a 5000 battery.
I have now switched to the Graupner Props and have not changed any settings. it is more sluggish with the new props.
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Aug 31, 2012, 03:36 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
frsky failsafe
Regarding FRsky RX on Futaba 9c, how do you make it work?
You bind this with radio in PPM (FM) but ther is no failsafe on FM menu. Will rx still work if you switch to PCM menu?
I pressed fs button on RX but did not get blinking green light
u2builder is offline Find More Posts by u2builder
Old Aug 31, 2012, 04:26 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
New Problem
My quad was working this morning. I decided to install the FRSKY RX.
I used the individual wires for each channel connected as before.
I did the binding and range check all OK. I connected to assistant and made sure all the sticks moved properly.
The GPS, atti and failsafe lights all work in the field but the stick command where I put the sticks in the corners does not start the motors.
What am I missing here or fogetting to do???
Old Aug 31, 2012, 04:46 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Is the transmitter turned on? hehe
viper522 is offline Find More Posts by viper522
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Csc
More than likely it's your travel limits or trims on your transmitter.
Don't forget that trims with Naza are a no-no...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Aug 31, 2012, 06:04 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thanks. Close! I forgot to recalibrate the sticks when I put on new RX. Duh
Old Aug 31, 2012, 06:06 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Just about as bad! No recalibration done. I looked at assistant but didn't even notice sticks were not going to limits. Look and no see. Dumb de dumb dumb
Old Aug 31, 2012, 09:11 PM
Joined Jun 2012
I cant get my compass to calibrate I get the yellow light do my 360 degrees and the green ligh comes on then I hold it vertical and do my 360 degrees one two three till I am dizzy stop still green light flip my mode switch till I get back to normal unplug battery and it all again still no go after 5 times. I went ahead and flew it like that and was honestly surprised at now well it flew. But I have to get the calibration problem solved inorder to do home lock and all it did well with gps atit lock hoovers in a really close area even with the wind we are having.
Old Aug 31, 2012, 09:50 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
Mine is on air again. Its quiet windy this morning but it flew quiet nicely on default (all 100%....myb later Im going back to my ori setup (140/140/120/130/120/120) and awith the latest update (1.8 assist/2.02 naza). Yup ...its the FC wrong mounting orientation that caused the flipping. Now its a good time to go-Pro.....and still waiting for my GPS module ......well all is good again.....
CPMBOY is offline Find More Posts by CPMBOY
Old Aug 31, 2012, 09:58 PM
Joined Jun 2012
Any suggestions or tricks I need to know about. How long does it take to calibrate the Vertical procedure normally .
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 11:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
