Old Aug 30, 2012, 03:08 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Sounds like you got it!
MCrites is offline Find More Posts by MCrites
Old Aug 30, 2012, 03:42 PM
STORMYWEATHER is offline
Find More Posts by STORMYWEATHER
United States, NV, Nye
Joined Jun 2012
Something else I have forgot after running so many other control boards. When linking up with the assistant software do I need the battery hooked up to the aircraft powered up and yes props are removed.
STORMYWEATHER is offline Find More Posts by STORMYWEATHER
Old Aug 30, 2012, 03:48 PM
MCrites is offline
Joined Jan 2012
Yes, the FC needs power. Don't forget to click "Write" on each screen as you make changes. This puts the info on the FC.
Old Aug 30, 2012, 03:52 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
Also shut down assistant when your done writing if you have no more changes before you disconnect. Another thing is save you settings to your desktop since when you upgrade the software it doesn't save the settings.
seadog1967 is offline Find More Posts by seadog1967
Old Aug 30, 2012, 05:04 PM
Joined Jun 2012
My MC OUTPUT ON is flashing red and I have no contact via the usb with the controler. Seems I had to do something weird when I loaded the assistant software on my first naza can someone fill me in and refreash my memory.
Old Aug 30, 2012, 05:10 PM
MCrites is offline
Joined Jan 2012
Without my laptop here in front of me (and honestly I have only used the software twice) I might not be any help here...
If I remember correct, this is the order I did things in...
Power Naza
Plug Naza into Computer
Turn on TX (THROTTLE DOWN EVEN WITH PROPS OFF!)
Start Up assistant.
If I remember right that MC OUTPUT ON flashes when the TX is off... but I am pretty sure that isn't right. Ummm... is this a fresh Assistant instal? Did it register the new Naza?
Old Aug 30, 2012, 05:17 PM
Joined Jun 2012
Power Naza
Start Up assistant.
I bought it already built and setup flighing perfect. I thought I would be able to dounload the assistant software and it would read what is already wrote on the board. I think its me I had problems on this computer with my first Naza I had to save the zip folder download on my desktop and forgot now had to go in to my prgram files and pull something out of the zip folder and put it into the dji that was in my program files. Wish I could remember how I did it I would be flying this evening.
Old Aug 30, 2012, 05:19 PM
indra9110 is offline
Find More Posts by indra9110
The Netherlands, ZH, The Hague
Joined Mar 2012
Did someone already upgrade fC to 2.02. is firmware is available on 30-08-2012... what is change?
indra9110 is offline Find More Posts by indra9110
Old Aug 30, 2012, 05:22 PM
seadog1967's Avatar
Joined Nov 2010
IMU calibration option
Old Aug 30, 2012, 05:34 PM
Joined Mar 2012
is only that? no other improvement?
Old Aug 30, 2012, 05:43 PM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
PPM Receiver Supported
Multi Gimbal Servo Output Frequency Supported
IMU calibration
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Aug 30, 2012, 05:47 PM
Joined Jun 2012
is only that? No other improvement?
ppm compatable
Old Aug 30, 2012, 05:49 PM
Joined Jun 2012
Step 4 Where is the driver instaltion manual located ?
Old Aug 30, 2012, 06:13 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Yes, I tried everything. Reinstalled software. Drivers. Tried new computer. DEAD. I hope nobody has an "interruption" during a firmware down load. It appears that it just wipes out all firmware or renders it unusable. Nothing at my end caused this. Computer was on. Really bummer. I contacted tech support at DJI but they were asleep. Probably is gonna have to go back though.
Originally Posted by dedfish View Post
Most likely you can't do anything to fix it and it will have to be sent back to DJI.
u2builder is offline Find More Posts by u2builder
Old Aug 30, 2012, 06:16 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Sure sounds like you will have to send it in. I bet they ship back fast though well, I gata go outside and practice my FPV good luck to you!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 11:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
