Old Aug 30, 2012, 09:36 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by Exploding Fist View Post
If only this forum had an FPV section you could post questions like this in.
No, it's just getting really annoying watching you $#!+ up this thread.
I recommend 20mg valium
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Aug 30, 2012, 09:51 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
So, looking at pg 15 of the new manual it says "If you use S-bus/PPM receiver, the communication of A, E, T, R, U, X1 and x2 channels are all throught he D-Bus/PPM channel"
I assume this means the X2 input since that is where it shows the s-bus connection in the diagram on page 8.
The whole PPM thing is confusing because what they are really reffering to is combined PPM or PPM sum. The Naza already supports/supported PPM for each individual channel.
Cervanchez is offline Find More Posts by Cervanchez
Old Aug 30, 2012, 09:55 AM
The Recursion is online now
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Are you planning on playing with it today?
Let me know if you get it working. Getting rid of the gob of cables between the FC/Receiver would make everything so much cleaner, and allow for people to mount them farther apart. I'm really hoping this works well with the FrSky. I know that timecop has been trolling DJI for this support for the past year.
The Recursion is online now Find More Posts by The Recursion
Old Aug 30, 2012, 09:57 AM
Cervanchez's Avatar
Joined Dec 2011
Yes, hopefully I'll have some time to try it today (gotta newborn at home). I will post my results.
Old Aug 30, 2012, 10:14 AM
Cervanchez's Avatar
Joined Dec 2011
BTW for anyone that cares:
To make it even more confusing, the PPM that we are referring to is actually PWM. If you put a Rx output onto a scope, you will see the width of the pulse chages with stick input, NOT the position of the pulse. But for some reason in RC they call it PPM instead of PWM.
Old Aug 30, 2012, 10:18 AM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Thank you for explaining that to the masses. Now lets all get together and see if it works. My new Naza/GPS is on the ups truck for delivery. I really want to hook my 16 ch rx'er up in the PPM SUM configeration. That way I can use everything to it maximum potential.
kd4wen is offline Find More Posts by kd4wen
Old Aug 30, 2012, 10:23 AM
Joined Mar 2012
Originally Posted by kd4wen View Post
Thank you for explaining that to the masses. Now lets all get together and see if it works. My new Naza/GPS is on the ups truck for delivery. I really want to hook my 16 ch rx'er up in the PPM SUM configeration. That way I can use everything to it maximum potintal.
potintal?
Old Aug 30, 2012, 10:25 AM
kd4wen is offline
Just a yard bird
kd4wen's Avatar
Joined Mar 2007
Someone please refreash my memorey. Do I have to calibrate each DJI esc and motor to my tyx'er throttle. I was thinking that with the DJI ESC's you did not have to do this. Or did I just dream that up from wishful thinking.
Old Aug 30, 2012, 10:43 AM
kd4wen is offline
Just a yard bird
kd4wen's Avatar
Joined Mar 2007
Originally Posted by goldsworthy View Post
potintal?
Its a Southern thing did not expect you to understand lol
Old Aug 30, 2012, 11:04 AM
thepelell is offline
Find More Posts by thepelell
Italia, Piemonte, Biella
Joined Feb 2011
Originally Posted by David Bott View Post
Hi All...
I just wanted to share this video as a thank you to all of you for your help with suggestions etc in regards to the issue I was having with my X650 twitching. What I mean is, I know it has nothing to do with you all in regards to the video itself, but this is the type of video I will now be able to shot in our travels that I would not be able to before.
So, guys...thank you all for your help. (And note the onlookers in the video are behind a fence.)
Thank you.
what ATTI gain are you using? that video is sure wobbly.. was there wind ? i hope with the new fiw they have sorted out the wind wobbles a bit.
when you start gaining more confidence, start lowering your atti gains, the craft need to be more "relaxed" to get smoother video.. it won't hover in front of your nose and you will need to work harder to make it behave, but at least it won't be jerky.
thepelell is offline Find More Posts by thepelell
Old Aug 30, 2012, 11:11 AM
kd4wen is offline
Just a yard bird
kd4wen's Avatar
Joined Mar 2007
Ok would someone chime in here and help me get a quick start on setting up GPS. I have owned two Naza's in the past but its been sometime. I just need a little refreashing and then some help with the GPS setup. First question switch assignment do I need to assign two three way switches or one two way and one three way switch to activate all the modes. Someone please chime in and get me underway. My new Naza has arrived and wanting to get it setup. It is already built just need to setup my MX-20 and the GR-16 rx'er.I am going to calibrate the DJI ESC's to my radio's throttle first off.
Old Aug 30, 2012, 11:26 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
I found this article explaining the relationship between PWM and PPM. They explain it well and easy to understand.
http://www.endurance-rc.com/ppmtut.php
Buffythesaint is offline Find More Posts by Buffythesaint
Old Aug 30, 2012, 11:31 AM
kd4wen is offline
Just a yard bird
kd4wen's Avatar
Joined Mar 2007
Old Aug 30, 2012, 11:52 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Apology
Nothing but RC from here on...
T J Gilbert is online now Find More Posts by T J Gilbert
Old Aug 30, 2012, 12:13 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
20 minutes then a bump? Seriously? I am sorry the overpaid help isn't fast enough. If you are in that big of a hurry then do a forum search, you know that question has been asked at least once.
Aside from you just asking a minute ago, the reason it hasn't been answered is because that isn't a extremely popular TX/RX. I'm sure the manual tells you how it should be done in a very general way and when you look and play with the Assistant it becomes pretty obvious. I personally have ATTI/MAN/GPS all on a three way switch because I never plan to use the failsafe for anything other than an emergency. Some people put another switch on a mix to force a TX-ON failsafe so they don't have to turn off their TX off to initiate. This is a good idea if you plan on showing off how your Naza lands itself to friends... gives you a chance to regain control when something goes wrong.
MCrites is offline Find More Posts by MCrites
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
