Old Aug 29, 2012, 11:13 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Tornado warning issued in southern Mississippi A tornado warning has been issued in southern Mississippi as Hurricane Isaac hits Louisiana and Mississippi with high winds and drenching rains.
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Aug 29, 2012, 11:15 AM
Joined Mar 2012
Originally Posted by jasper7821 View Post
I've been sneaking into your garbage for months now and with all the parts I've collected I now have enough to build a 2nd quad
No wonder the dogs have been barking so much at 2 am
Old Aug 29, 2012, 11:24 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Originally Posted by shadowless View Post
Regarding my battery connector issue, what is a good replacement for the deans plugs?
Do you go for XT90 or HXT4mm plugs?
I switched to Anderson Power Poles after reading up on them. Seeing some large scale 3D plane pilots swearing by them sold me. I also like the fact they are crimp on, less of a chance for a bad/cracked/cold solder.
MCrites is offline Find More Posts by MCrites
Old Aug 29, 2012, 11:36 AM
shadowless is offline
Find More Posts by shadowless
Joined Mar 2004
Really Anderson power poles? They are only 30-45amp isn't it?
shadowless is offline Find More Posts by shadowless
Old Aug 29, 2012, 11:39 AM
Joined Mar 2012
Anderson power poles NO SOLDERING! that sounds like a product a guy like me could really use!. What a unique and new product designed for the lazy!. I think I will order a couple hundred!
Old Aug 29, 2012, 11:51 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Deleted
T J Gilbert is offline Find More Posts by T J Gilbert
Old Aug 29, 2012, 11:56 AM
dedfish is offline
Find More Posts by dedfish
United States, FL, Tampa
Joined Apr 2012
I'm using XT60 based on the recommendation on the website about batteries I posted above.
dedfish is offline Find More Posts by dedfish
Old Aug 29, 2012, 12:03 PM
Joined Mar 2012
(This guy uses Sunny Sky motors)-http://news.yahoo.com/bigfoot-hoaxer...121533221.html
Old Aug 29, 2012, 12:52 PM
MCrites is offline
Joined Jan 2012
Here are just a few examples I found in one thread here on RCG. I have them on my F550 with a 45C 4S 5000mah battery. No problems to report so far. BTW if you go this route, don't buy knockoffs and buy the crimper they sell... I switched over my heli and 5 batteries in a matter of 15-20 minutes.
Originally Posted by Mike_Then View Post
Oh boy, another one of these posts... in trying to answer your question without starting an argument from the APP or Deans crowd, I use APP connectors on everything I own... from my 3-cell 20-amp T-28 to my 10-cell 75-amp biplane to my 6-cell 100+ amp heli. I've never, ever, ever had a problem with APP connectors. I've been using them since the mid-80's when they were known as Litespeed connectors and they have served me well.
I have recently bought an APP crimper and I no longer solder APPs unless I have to. Haven't had a crimped connection fail, either.
Honestly, it's a matter of preference. Use whichever is best for you.
Originally Posted by slipstick View Post
Do you really think NASA and the entire aerospace industry insist on crimps on all power connections because they're trying to save a dollar or two ? Nope, it's because crimps are harder to get wrong than soldered joints and they're more reliable.
Steve
Originally Posted by mrforsyth View Post
Many have successfully used APPs at up to 200 amps. The 'rating' merely denotes the maximum suggested sustained load for the wire size that the APP contacts can accommodate. Hobbyists routinely exceed the wire load ratings on a routine basis with no ill effect.
The 15, 30, and 45 contacts all have the same effective mating surface area so voltage drop of each of these is basically identical.
The crimpers will only work with the 15/30/45 contacts.
Mark
Old Aug 29, 2012, 01:50 PM
Joined Mar 2012
British Boy Stumbles Upon Extremely Valuable Vomit The vomit, which weighs a little more than one pound, could be worth as much as $63,000. http://www.thepostgame.com/blog/anim...le-whale-vomit
Old Aug 29, 2012, 01:55 PM
RolandGarros is offline
Find More Posts by RolandGarros
Peter
Sweden, Västra Götaland County, Gothenburg
Joined Dec 2011
I don't like the XT cause you heat up the plastic during soldering.
With these you solder first, then add the plastic cover:
http://www.hobbyking.com/hobbyking/s...%5Fset%5F.html
RolandGarros is offline Find More Posts by RolandGarros
Old Aug 29, 2012, 02:18 PM
dedfish is offline
Joined Apr 2012
That could be a concern depending on your soldering iron and skills. The plastic is actually a nylon and takes quite a bit more heat than other connectors.
Old Aug 29, 2012, 03:27 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
+1
For battery connectors these are all I use
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Aug 29, 2012, 03:35 PM
STORMYWEATHER is offline
Find More Posts by STORMYWEATHER
United States, NV, Nye
Joined Jun 2012
Could you provide a link for these and the crimpers
STORMYWEATHER is offline Find More Posts by STORMYWEATHER
Old Aug 29, 2012, 03:44 PM
MCrites is offline
Joined Jan 2012
http://www.powerwerx.com/powerpole-a...-contacts.html
Got my powerpoles here too. Quick shipping!
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
