Old Aug 28, 2012, 09:14 PM
kryptoknight is offline
Find More Posts by kryptoknight
kryptoknight's Avatar
Canada, MB, Winnipeg
Joined Aug 2011
I have a battery problem here guys. I have GEN ACE 4000 mAh 25C 3S lipo fully charged. It only lasted me 5 mins of hover time untill it began flashing it's red light lowbatt indication. I tried the other same 4000mAh 25C fully charged and it surprised me that it only lasted 2 mins of hover time. I swapped my 35C 3700mAh 3S KYPOM K6 pack and it lasted 10 mins of hover time. My quadcopter weighs approx 1200grams with gopro. Are my GEN ACE 25C not compatible with the NAZA or it's just that my GEN ACE are already dead even if I balanced charge it? It used to work fine on my OPENPILOT set up.
kryptoknight is offline Find More Posts by kryptoknight
Old Aug 28, 2012, 09:20 PM
BerndM is offline
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
Originally Posted by u2builder View Post
I decided I had better do a range check so I brought it back to the narrow place I launch from. I fired it up and all lights said GO. I don't know how to do a range check, so I decided to just turn the props on at idle and walk backward. Big mistake. I think I do have a range problem, because at about the same distance as before it spooled up and took off, again, out of control.
Once the sweating stops I guess I need to swap out the RX. But how the heck do you do a RANGE CHECK??? No ailerons or elevator or rudder to move.
The safest way to range check is with the PROPS REMOVED!!!!
On a Spektrum type radio you have to press and hold the Bind button and walk away 30 paces, about 75-90 feet. You have to have full control authority at that distance with the button held in. If you don't have a buddy to help you, you should still be able to hear the motors change pitch with throttle up/down. If all is good at that 75-90 foot range, you're golden at full range.
Regards
Bernd
Remember.....PROPS OFF.
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x5 Graupner Props /3S 2200 & 4000 Lipos / GoPro HD2
Spektrum DX-7 (original)
BerndM is offline Find More Posts by BerndM
Old Aug 28, 2012, 09:34 PM
STORMYWEATHER is offline
Find More Posts by STORMYWEATHER
United States, NV, Nye
Joined Jun 2012
Well I broke down and bought another naza this will be my third one. But my first with GPS. Just hope they get the code setup for PPM SUM soon. And hope it don't do what my second one did when it went rouge and MIA. And the failsafe was setup properly and working not 4 flights before she ran away it was tested and landed when the radio was cut off.
STORMYWEATHER is offline Find More Posts by STORMYWEATHER
Old Aug 28, 2012, 09:41 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
72 mHz
Oh yeah, this explains it. Naza and Futaba 9C/PCM do not work together properly. I had exactly the same thing happen: OK range check with all my RX connected to servos, but really poor range check when connected to the machine, and very erratic behavior when I go out of range.
May have to FrySky module.
2.4 Ghz is here to stay.
72 mHz is dead.
Why won't you guys just let it go?
I know it was great in its day, and that 2.4 has its problems.
But face facts...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Aug 28, 2012, 09:55 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
LOL. When you got 25 planes on 72 it is kind of expensive to switch. But I just ordered a 2.4 FRYSKY module for my Futaba 9c for when I fly the Quad. No other choice really.
u2builder is offline Find More Posts by u2builder
Old Aug 28, 2012, 10:10 PM
Empire Support
Joined Feb 2009
72 mHz Interference
Yeah, I understand, but with 72 mHz on the decline, systems might not even be designed with it in mind anymore.
I know DJI says Naza is 72 mHz friendly, but it appears to be otherwise.
Old Aug 28, 2012, 10:33 PM
pajonate is offline
Find More Posts by pajonate
pajonate's Avatar
United States, NJ, Fair Lawn
Joined Dec 2009
Which module have you ordered, the one with the LCD telemetry or the regular one. What about the Rx. Which ones you got? And from where?
pajonate is offline Find More Posts by pajonate
Old Aug 28, 2012, 10:35 PM
mark_q is offline
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Your batteries are likely done.
When Lipos get tired their capacity drops pretty quickly. I've got a pile of 2200 30C GA packs that last about 5 minutues on my Sniper (3D foamy). A new 30C SkyLipo goes a solid 9 minutes. The GA packs have somewhere between 150 and 200 cycles on them which for me is a pretty normal life. I balance charge 100% of the time and never above 1C. When they get this bad, I wire 4 or 5 five of them together in parallel and power my FPV base station.
mark_q is offline Find More Posts by mark_q
Old Aug 28, 2012, 10:36 PM
pajonate is offline
pajonate's Avatar
Joined Dec 2009
TJ, is the FrSky SPCM or PPM, do you have an idea? I am asking if the FrSky's can be set up for failsafe. I have JR 9303 with Assan module and Spektrum module.
With Assan module when I select a model, works only if I set modulation to PPM (no failsafe).
Old Aug 28, 2012, 10:40 PM
mark_q is offline
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
72 mHz is dead.
But face facts...
+1!
The last time I pulled out the old 72, I neglected to pull out the antenna (didn'nt like that plane much anyway...)
I bought into 2.4 when they first came out and have never had a (radio) problem.
Old Aug 28, 2012, 10:49 PM
mark_q is offline
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
There's been quite a lot about failsafe recently and I wonder if everyone has a real understanding of this important topic. Here are a few points to consider:
  • Every radio system deals with TX/RX failsafe differently
  • Most radio systems under 8 channels that have a failsafe feature do so on throttle only
  • Most radio systems which have a true multi-channel failsafe program, require separate menu selection or special bind requirement to make them work
I don't know all the differences, but I can tell you there are many so do your research!
I can speak to Spektrum a bit since it is what I use and I hear it mentioned a lot on this thread. Spektrum (& JR) have two different failsafe programs, "Smartsafe" and "Preset Failsafe".
Smartsafe is throttle only and basically remembers only the throttle position at bind so if signal is lost, the throttle goes to its bind position and all other controls do not change. Smartsafe is available on all AR receivers and is the default.
Preset Failsafe is where you can preset all control surfaces and swithces when the signal is lost. Preset Failsafe is available on AR7001 and higher receivers and is activated with a second special bind procedure (from the AR9001 instructions):
"During the binding process the bind plug is inserted in the bind port, then the receiver is powered up. The LEDs in each receiver should blink, indicating that the receiver is in bind mode. Now before binding the receiver to the transmitter and with the receiver in bind mode, remove the bind plug. The
LEDs will still be blinking. With the control sticks and switches in the desired failsafe positions, bind the transmitter to the receiver. Follow the procedures of your specifc transmitter to enter Bind Mode. The system should connect in less than 15 seconds. The receiver is now programmed for preset failsafe."
Keep in mind we are working with spinning samurai swords so be careful. It would be prudent to do your testing with empty servos plugged in to your receiver first then test on the multirotor.
Always keep it fun!
Old Aug 28, 2012, 10:59 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
I have a Frsky D8R Rx and it is ppm. The failsafe works with the Naza. I love my Frsky stuff. I have the DHT-U transceiver with telemetry (voltage, rssi, temp, rpm) with alarms, and all their stuff is super cheap.
Cervanchez is offline Find More Posts by Cervanchez
Old Aug 29, 2012, 12:11 AM
Joined Jun 2012
Always keep it fun!
Man now I know why I love my Graupner MX-20 Failsafe is Failsafe. It is all done via the setup menue on the ground radio. Just a matter of setting the switches for each channel you want to react it is that easy 12345 or more either you want the switch open or closed its your choice don't have to fool with anything like the binding nothing its that simple.Man a good radio is the first thing in making a good investment if your really into the hobby.
Old Aug 29, 2012, 12:14 AM
Joined Jun 2012
You folks are really confussing me now. How are you running PPM when the code for the NAZA board to do PPM is not yet implimented. Help me figure this out huuu.
Old Aug 29, 2012, 12:41 AM
pajonate is offline
pajonate's Avatar
Joined Dec 2009
Mark_q,
mine question was posted because I have Jr 9303 (72Mhz) with module for Spektrum and Assan. In the JR manual, under faisafe, there is requirement to set your radio to SPCM modulation. On the other hand, Assan manual, states that all their Rxs are PPM. So, if I set my radio to SPCM modulation, I get a menu Failsafe where I can set it up, but them the radio doesn't bind with the receiver.
I haven't tried the Spektrum module, since at this point I have only 4 channel Spektrum Rxs.
@Carvanchez,
what radio you have with your FrSky. I looked at the DHT-U unit, and it seems interesting, since it is a Tx module and telemetry in-one.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 08:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
