Old Aug 17, 2012, 01:59 PM
dedfish is offline
Find More Posts by dedfish
United States, FL, Tampa
Joined Apr 2012
Originally Posted by glmccready View Post
dedfish: I had a quad that would have a glitch every now and then. After much hair pulling I finally tracked it to a particular battery. I replaced the (factory installed) connector and the problem disappeared.
Had another that got occasionally twitchy after a crash. Tracked it to one ESC, nothing I could see. Just re-did the battery to ESC solder joints and that fixed it.
I'll start flying my batteries in a particular order just to see if there is a correlation. I'm going to head out in a few minutes to fly, part of me wants the problem to happen again so I can try and figure out what the cause is. I don't like problems that seem to randomly come and go.
dedfish is offline Find More Posts by dedfish
Old Aug 17, 2012, 02:10 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
"problems that seem to randomly come and go" Welcome to the world of NAZA!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Aug 17, 2012, 02:12 PM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Yep!
+1
Right you are...
T J Gilbert is online now Find More Posts by T J Gilbert
Old Aug 17, 2012, 02:33 PM
sirnumbskull is offline
Find More Posts by sirnumbskull
Joined Mar 2012
Originally Posted by T J Gilbert View Post
Okay:
I know it's hard to get a windless situation, but for tuning as accurate as you want, I'd recommend NO wind.
I fly from a windy hilltop, and usually have to be there at dawn to get ideal conditions wind-wise.
You need to not be having to input anything with your right hand for a few seconds to observe just how much yaw rebound, whatever, you're getting.
TahoeEd suggested for the F450 (which I have) that you start with:
140/140/140/140
100/100
Right now, I'm at:
150/150/150/150
100/100
I've read, I think, that the F550 requires even higher gain settings, but that might not be true for your airframe with the underslung gear.
Search for that or PM TahoeEd...
FWIW, your positioning is pretty good for Naza. That rebound could be the twitch you are supposed to see when a gain is a little too high. See what Ed thinks.
Good Luck
Thanks TJ. I've recently modded my craft, and the Yaw issue has all but abated.
sirnumbskull is offline Find More Posts by sirnumbskull
Old Aug 17, 2012, 02:48 PM
Empire Support
Joined Feb 2009
Glad You Succeeded!
You were already very close...
Have Fun!
Old Aug 17, 2012, 03:03 PM
dedfish is offline
Joined Apr 2012
It happened again. This time it hit the ground so hard that it ejected the battery and gopro. I'm checking the video now. I'm starting to really think it's a motor, the one on arm 1. I'm going to swap the front motors and see if the direction changes. I'm not sure if I have video of it, the file might be corrupt. The gopro was held on with a velcro strap that broke and when it hit the ground the sdcard ejected.
Old Aug 17, 2012, 03:08 PM
dedfish is offline
Joined Apr 2012
Nope that file didn't save right and it won't open. Unfortunately I couldn't check the receiver LED since the battery got disconnected.
Oh and I lost my moon gel!! It's the end of the world I tell you!!
Old Aug 17, 2012, 03:23 PM
Joined Mar 2012
WOW! sounds like your bad motor realy S$%^&D you well!. Lost your moon jell huh?. Well that would piss me off big time!. Motors are cheap order a new one today!
Old Aug 17, 2012, 03:24 PM
Empire Support
Joined Feb 2009
Don't go Mayan on us...
Sounds like you're at least down in one piece.
You're brave risking the GoPro in testing.
I have a dummy camera for test runs...
Have you ordered some spare motors?
Might need to consider it, if that's how you are thinking...
You'll still get a chance to check the LED just for safety's sake.
Old Aug 17, 2012, 03:25 PM
networkit is offline
Find More Posts by networkit
United States, CA, Walnut Creek
Joined May 2009
Naza in Nor Cal / Bay Area
Just checking to see who in Bay Area (Northern CA) may be flying naza and who may fly at baylands or similar on weekends. Looking for help/advice on my setup. Thx
networkit is offline Find More Posts by networkit
Old Aug 17, 2012, 03:50 PM
dedfish is offline
Joined Apr 2012
Yes, I need to order a new motor or two. I was hoping someone with an extra dozen or six would want to part with a few but I guess I'll have to order some at retail price.
Old Aug 17, 2012, 03:55 PM
Joined Mar 2012
Yes it sounds like you may have to. The good news is the dj motors are cheap! if ya shop around you can get em for close to $20.00 + shipping. Or you can do what I did order in bulk you get a discount when buying 50 or more at one time.
Old Aug 17, 2012, 04:02 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
50 at once? Seems excessive.
I suppose you could use the spares for other things. I've always wanted to build a high powered mini fan with one. 10 inch props at full throttle. Whoooosh.
The Recursion is offline Find More Posts by The Recursion
Old Aug 17, 2012, 04:03 PM
dedfish is offline
Joined Apr 2012
I guess I will have to order at retail. I can't afford to buy 50+ motors to get a discount. Are you sure you don't want to part with some of the 75 that you have?
Old Aug 17, 2012, 04:41 PM
Joined Mar 2012
If you swap the motors at least when it crashes again you will have matching dents!.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
