Old Aug 01, 2012, 07:32 AM
MIDNCOCO is offline
Find More Posts by MIDNCOCO
United States, CT, Glastonbury
Joined Feb 2010
anyone have any experience on which is better between the APM2 and the Naza?
MIDNCOCO is offline Find More Posts by MIDNCOCO
Old Aug 01, 2012, 07:38 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
Originally Posted by cruddbucket View Post
Men when I see the video header I was so mad, unbelievable images that you have, those scenes where amazing beautiful. Hope you get a new one and be a little more carefull but that is a part of the hobby, sometimes we loose. Really sorry for your loss. Hope see you soon.
Mauro
mauromassari is offline Find More Posts by mauromassari
Old Aug 01, 2012, 07:41 AM
Joined Jun 2011
Originally Posted by T J Gilbert View Post
2900g = 6lb 6.3oz
That's heavier than average.
Have you done some power calculations to determine if you are underpowered?
Is your ESC, motor, prop, battery choice in keeping with these calculations?
I know that you said temps were okay, but you might check your watts with a Wattsup Meter or something similar.
Along Mauro's line of reasoning, you might be able to go to 5S if your system can handle it.
Naza/VU can.
VU = 2S to 6S
Another option also is to increase your pitch if your ESC and motors can go with that too. See if you can go to 12X5 or 12X6, that is something that you will have to try out. That is a very heavy flying machine, be safe.
Mauro
Old Aug 01, 2012, 07:52 AM
KevinBuckley70 is offline
Find More Posts by KevinBuckley70
KevinBuckley70's Avatar
Oxfordshire, UK
Joined Jul 2001
That is such a fabulous video! I will look forward to the next installments.
I saw a video on another thread somewhere of a waterproofed quad going underwater & then resurfacing. Perhaps if you had set failsafe/RTH, your quad would have swum back to you! Although I guess by then, 'home' would have sailed on somewhat.
KevinBuckley70 is offline Find More Posts by KevinBuckley70
Old Aug 01, 2012, 08:09 AM
BillzillaAus is offline
Find More Posts by BillzillaAus
My cat moderates better
BillzillaAus's Avatar
Australia, QLD, Worongary
Joined Apr 2011
Great video, thanks for that.
Sorry to hear of the loss of your little four-armed mate.
BillzillaAus is offline Find More Posts by BillzillaAus
Old Aug 01, 2012, 08:40 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Naza vs APM2
I have both, but I have yet to fly the APM2.
Even with its Assistant, APM2 is much more of a "coder's or programmer's FC.
I read recently that the Arducopter code set a record sizewise for Arduino coding.
There are many people working together to write the "shared" code.
It's all freeware. And it's all beta testing so-to-speak.
It has a very broad range of capabilities including plank aircraft auto-piloting.
You need basic electronics and Arduino knowledge.
There are dozens of features and optional sensors that can be programmed into the APM2 FC.
The problems we address on the Naza threads are nothing compared to the work being done with APM2.
Picture the Naza as the result of work done with APM1 & APM2.
Naza is more turnkey (even then, as you can see, it's complicated).
T J Gilbert is online now Find More Posts by T J Gilbert
Old Aug 01, 2012, 08:42 AM
thepelell is offline
Find More Posts by thepelell
Italia, Piemonte, Biella
Joined Feb 2011
2900g = 6lb 6.3oz
Naza/VU can.
VU = 2S to 6S
my escs can't handle 5s, anyway in manual mode i hover just a tad over half throttle.
I made other 2 flights and had no problem...
Now i am trying to move the naza on another machine, a Y6 where i just removed a AQ50 pro board.
BUT i can't get it to work... when i do CSC sequence only motor #3 starts spinning, all others are still.. I tried recalibrating throttle ranges on escs and all went well, motors spin correctly when connected to RX... I have updated motor config in naza assistant. i'm quite puzzled...
thepelell is offline Find More Posts by thepelell
Old Aug 01, 2012, 08:49 AM
Oxfordshire, UK
Joined Jul 2001
This may be a 'dumb question' but the last time that happened to me, it was because I had successfully inserted 3 out of 4 of the ESC connectors into the NAZA upside down (having sleeved each cable to protect the BEC wire I had removed which hid the cable colours)
Old Aug 01, 2012, 08:50 AM
Empire Support
Joined Feb 2009
Rip
Man, I'm proud you're planning to stay with quadcopter flying.
Your videos have been awesome!
I use pool noodles for leg extensions to get camera gimbal clearance.
Not sure, but that might be your "parachute" or "lifeboat" for future escapades...
Old Aug 01, 2012, 08:51 AM
Joined Jun 2011
It could be your ESC that are not "talking" to Naza, try those arm sequency:
- Power Naza 1st then ESC
- Power ESC 1st then Naza
- Power both together in 1sec unpower ESC then wait for Naza to set then power again ESC (This was the only way that I was able to get mine to work)
Mauro
Old Aug 01, 2012, 08:54 AM
Joined Jun 2011
Hi TJ, his biggest problem is not to float in the water is to make a turn around in the big overseas ship.... And RTH with a ship moving will bring him to a spot in the ocean too.
Mauro
Old Aug 01, 2012, 08:56 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Mauro
^^this
His only option would be to have someone man a fishing pole and hope the props don't hit the fishing line... maybe a weight about 1ft away from frame to keep the line down...
He has no option but to run the risk.
MCrites is offline Find More Posts by MCrites
Old Aug 01, 2012, 08:59 AM
Joined Feb 2011
Mauro
hmm.. this is going to be tricky, i have all power wires on same power distro board.. only way is to power the naza with a different batt i suppose.
BTW i'm using turnigy plush 30 v3.1 escs...
Empire Support
Joined Feb 2009
Ghost In The Machine
You're going to have to do the basic troubleshooting routine even further than you have.
Since the components have worked before, it's probably some overlooked, basic thing.
Have you started with a defaulted or new model on your transmitter?
Recheck all your Assistant settings (are you using traditional or Dbus for receiver setting?).
Be sure to write each page.
Old Aug 01, 2012, 09:02 AM
Joined Feb 2011
sh**, i just saw on spreadsheet on first page, that plush 30 give no esc initialization with naza....
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
