Old May 30, 2012, 08:24 AM
actionplus is offline
Find More Posts by actionplus
United States, CA, Rancho Cucamonga
Joined Mar 2005
Setup
Originally Posted by dslack67 View Post
I was having all kinds of problems flying LOS. I just couldn't get good orientation and was very inexperienced in changing my positional control swapping when the attitude was coming towards me, etc. Also, I was not happy having to stay so "close" to me all the time. All of my crashes have been during LOS flying. I switched to FPV after a few months of LOS and have never gone back.
With FPV, I can visibly tell exactly where I'm pointing, how much my stick movement is actually affecting the quad in real time, and best of all.... I feel like I'm actually in the copter "flying" in the air. I've flown with Hawks, chased Coyotes, aired it out next to Motocross riders hitting triple jumps, and viewed memorials from 300-ft up in the air.
Now, with that said, if I was an awesome 3D pilot like Warthox and others, then I would probably really enjoy LOS flying. But, I'm not. So for me... NOTHING ELSE comes even close to FPV'ing. ;-)
Here is my latest video of some practice sessions around the yard. Really focused on various different GAIN settings with my setup. All the flying in the video is in ATTI mode, not Manual. I've noticed a lot of posts about ATTI mode flying not responding well and overshooting, etc. In this video, I show the NAZA flying higher speeds with some good stops, direction changes, floats, great altitude holding, etc. All in winds that were gusting from 8-18mph over the weekend (notice my cabana and palm trees flapping in the wind as well as the jello effect from the CMOS shutter issue which the wind really impacts).
So, this is the NAZA in ATTI mode, flying pretty darn well, IMHO.
http://www.youtube.com/watch?v=A4Sg4Ri_6DA
Nice flying.
Any chance of some pics of your frame setup?
actionplus is offline Find More Posts by actionplus
Old May 30, 2012, 09:11 AM
Stupest is offline
Find More Posts by Stupest
Australia, WA, Perth
Joined Jan 2012
Yeah i don't think that i have it quiet setup right but at least i know that it heads for the ground if the trans signal is lost. I can live with running down a battery until the props stop.
I must says it flies like a dream
Stupest is offline Find More Posts by Stupest
Old May 30, 2012, 10:21 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Yes, the Naza controlled flight is very impressive. As for running down batteries, I've read of nitro heli pilots having to get a chair and sit while their fuel tanks emptied because they couldn't get the bird to shut off. Perhaps the low voltage settings on the Naza, working independently from a radio signal, will help slow down or stop the motors. I'm not interested in sacrificing a battery to test that, but one of our more experienced Naza pilots may know the answer.
T J Gilbert is offline Find More Posts by T J Gilbert
Old May 30, 2012, 10:27 AM
JJtr1954 is offline
Find More Posts by JJtr1954
NoLgs2StngArmsBigHeart!
JJtr1954's Avatar
USA, TX, Kilgore
Joined Apr 2010
If you want the motors to stop instantly when it goes into fail-safe, you can either do the Sticks like when you arm it or go into the assistant & go from intelligent shut -off to immediate shut off.....JJ
JJtr1954 is offline Find More Posts by JJtr1954
Old May 30, 2012, 10:28 AM
Empire Support
Joined Feb 2009
Failsafe throttle setting
I'm unclear on one thing about failsafe settings.
I've read on this thread somewhere that your failsafe throttle setting needs to be about 40%. That's about where I tried to set mine, and all seems well. Some other posts say it should just be above 10%.
Does this setting determine the throttle setting for failsafe/autoland, or does the Naza just slightly lower the atti mid stick setting to make the craft descend?
In other words, do you have the option of setting the rate of descent?
Old May 30, 2012, 10:31 AM
Empire Support
Joined Feb 2009
Failsafe = no radio signal
If you have lost radio signal, and the Naza is in failsafe, it will not recognize the sticks command
Old May 30, 2012, 10:41 AM
JJtr1954 is offline
JJtr1954's Avatar
USA, TX, Kilgore
Joined Apr 2010
I am speaking of the Futaba Radio settings...I know nothing about any other Radios...& Don't need to!....LMAO!....JJ
Old May 30, 2012, 10:53 AM
Empire Support
Joined Feb 2009
Futaba magic
Now don't think I'm trying to get into radio bashing...
I'm telling you that the sticks command is a radio signal.
If the radio signal is lost, the Naza will not recogonize the sticks command.
Last edited by T J Gilbert; May 30, 2012 at 10:58 AM. Reason: Took some out to keep from suggesting tests that might prove dangerous to some.
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
sort of ..... the rate of decent is determined only by thrust to weight ratio
over 10% is what is needed.....
Adidas4275 is offline Find More Posts by Adidas4275
Old May 30, 2012, 11:06 AM
Empire Support
Joined Feb 2009
So the Naza determines the thrust to weight ratio for your airframe based on the mid throttle hover setting and gives slightly less throttle to initiate descent.
This seems logical, and can be a little dicey in a wind:
A slow descent means a higher horizontal to vertical velocity ratio and a ground flip.
A fast descent means a lower horizontal to vertical velocity ratio and a harder plop onto terra firma.
Old May 30, 2012, 11:37 AM
JJtr1954 is offline
JJtr1954's Avatar
USA, TX, Kilgore
Joined Apr 2010
Radio Bashing...Never!
Sorry...did not mean that at all...No smilies in quick rely......JJ....
Old May 30, 2012, 12:03 PM
Adidas4275's Avatar
Joined Mar 2011
yeah it is not an intelligent decent..... it is just set to be under 50% no matter what the weight, thrust or anything else..
so if you have a fat rig it will FALL not descend.... and a super light right with a ton of power and it might not ever come down! I should try this..
put some strong motors that are over propped with 0 additional weight (like wood arms) and see if it goes up on failsafe
Old May 30, 2012, 12:19 PM
recep is offline
Find More Posts by recep
recep
recep's Avatar
Ankara, TURKEY
Joined Sep 2005
naza with y6
2012 BURSA IŞIKFEST (1 min 31 sec)
recep is offline Find More Posts by recep
Old May 30, 2012, 12:22 PM
Empire Support
Joined Feb 2009
Weight = rate of descent
My rig weighs ~3.5 lbs with GoPro, Servo City gimbal, 3300mAh 4c, & pool noodle gear extensions. I consider that about max for the flamewheel 450. I'm using APC 9x4.5 props. Failsafe descent is not slow, but gentle enough in low wind. If wind is over 7 or 8 mph, I need to take over landing and compensate for wind induced horizontal velocity. Otherwise its high stance causes a ground flip. Now that I'm over the novelty of auto-land, I rarely instigate failsafe with the transmitter switch. Knowing it's there is confidence inspiring though. When the GPS is received and installed, there will be more failsafe play. I think RTL will give me confidence to fly farther/higher to get better video. At 100 feet the little flamewheel 450 becomes a speck. The 20m (66') travel altitude for RTL (if it's the same as WKM) will also be nice as my field is ringed with medium height trees.
Old May 30, 2012, 12:58 PM
Boris B is online now
Find More Posts by Boris B
Boris B's Avatar
The Netherlands
Joined May 2012
Here is my flight with naza finally set up properly.
FPV Paradise (7 min 8 sec)
Boris B is online now Find More Posts by Boris B
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 08:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
