Old Feb 17, 2012, 08:24 PM
badbill is online now
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
Originally Posted by Tahoe Ed View Post
Are you using a Naza flight controller? If not, you might be better served by posting on the Witespy thread.
Pretty sure Witespy has switched to the NAZA controllers now.
Bill Davenport
AMA 28141
badbill is online now Find More Posts by badbill
Old Feb 17, 2012, 08:25 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Don, nice video of a scenic location. Not far from me, just down the hill. I am going to do some A/P this weekend up at the Lake.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Feb 17, 2012, 08:32 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Bill Davenport
AMA 28141
Thanks, Bill. He was always a big supporter of the MultiWii platform. I guess I missed the change to Naza.
Site Sponsor
Old Feb 17, 2012, 08:38 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Originally Posted by Ls2.350z View Post
I had a question I just purchase one of the witespy quads and IV been flying it around and I wanted to know how to get it to auto stabilize is it one of the switches? I have the dx6 TX .
Have you set up your Naza using the Assistant software? You can assign a two position switch to move between Manual and ATTI, usually your gear switch. What receiver are you using?
Site Sponsor
Old Feb 17, 2012, 09:17 PM
Ls2.350z is offline
Find More Posts by Ls2.350z
Joined Feb 2012
Yes naza witespy quad and dx6 TX. Sowhat do I do to stabilize it? Is it one of the switches I see that one does auto land.
Ls2.350z is offline Find More Posts by Ls2.350z
Old Feb 17, 2012, 09:23 PM
Ls2.350z is offline
Joined Feb 2012
I purchased it rtf and its the dx6 TX.
Old Feb 17, 2012, 09:48 PM
johnnycat500 is offline
Find More Posts by johnnycat500
Riverside, Ca
Joined Oct 2006
Here's a few pics of my quad that started out as a 1000mm MTM. I have a gaui 500 that I have the gopro on but wanted to custom build a bigger one to lift a DSLR camera. I ended up cutting it down so now it is a 770mm MTM. It was sluggish as a 1000.I have fine tuned the gains to my liking. Going to try her out at the field tomorrow morning...can't wait
johnnycat500 is offline Find More Posts by johnnycat500
Old Feb 17, 2012, 09:56 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
You're probably better off asking Witespy. Unless someones bought one of his setups the folks here don't know how he configured the transmitter. He's likely set up a 2-way switch...or perhaps a 3-way if the Dx6i has a 3-way. He set it up so he's the one that can best answer.
Vantasstic is offline Find More Posts by Vantasstic
Old Feb 17, 2012, 10:19 PM
Ls2.350z is offline
Joined Feb 2012
ok thanks ill give him a call tomorrow!
Old Feb 17, 2012, 11:22 PM
bendicks is offline
Find More Posts by bendicks
bendicks's Avatar
USA, CA, Pollock Pines
Joined Jan 2011
Thanks Ed...I work down there but actually just 40+ miles west of Tahoe over in Pollock Pines. I am either headed up to Loon lake or back over to Hope Valley/Kirkwood area tomorrow, was over there last weekend, light snow, no wind.
-Don
bendicks is offline Find More Posts by bendicks
Old Feb 17, 2012, 11:34 PM
scphoto is offline
Find More Posts by scphoto
living the dream
scphoto's Avatar
United States, NJ
Joined Apr 2011
should be set to go into ATTI by means of the "gear" switch. Check Naza assistant to see if the gear switch moves from M to A on each side of failsafe. Also - the VU should blink orange slowly when ATTI is engaged
scphoto is offline Find More Posts by scphoto
Old Feb 18, 2012, 12:20 AM
Ls2.350z is offline
Joined Feb 2012
Here is the Quad i have (for all the info on what it came with) http://witespyquad.gostorego.com/qua...ames-only.html
when i was flying it today i hit the gear switch and didnt notice anything i know that one of them on the top right did my auto land. how hard is it to set up the position switch if i have to do it?
Old Feb 18, 2012, 12:51 AM
FrankenQuad is offline
Find More Posts by FrankenQuad
where things come alive!
FrankenQuad's Avatar
United States, NJ
Joined May 2011
Im sure your mode switch is on the gear channel ....
FrankenQuad is offline Find More Posts by FrankenQuad
Old Feb 18, 2012, 01:44 AM
Brombo is offline
Find More Posts by Brombo
Sardinia Multirotors
Italy, Sardegna
Joined Nov 2011
Hello all,
i'm having some problems with my new F330 with NAZA...
i just built it as normal all by default Kit but ESC that are HobbyWing Skywalker 20A, i made all the things :
1) Calibration ESC one by one with all 3 wires plugged in the connector,
then unplugged the red wire due to the ESC have the BEC built-in
2) Upgraded Assistant Software to the last release
3) Upgraded the Naza with the last Firmware
4) Calibration of the Transmitter, i have Futaba T8fg and i reversed 2 ch as normal.
5) Tested all the channels in the TxCali and all works fine
6) Assigned FailSafe to a 3 switch channel, up MANIUAL - middle FAILSAFE - down ATTI
7) Tested FailSafe and other with LED and all works,
switch down ATTI mode - Slow yellow LED
switch middle FAILSAFE mode - fast yellow LED
switch up MANUAL mode - no LED
All work in the config, BUT when i unplug the usb and plug the battery to start the motors i have a persistant BEEP like the video and it never stop to BEEPS until i unplug the Lipo 3S 2200..
Any suggestions? What i can do to solve the problem and start the motors?
Please Help!!
This is the video
http://youtu.be/qCVDDa4whtE
and this with the Config
http://youtu.be/gaonOc6rp_Y
Brombo is offline Find More Posts by Brombo
Old Feb 18, 2012, 01:51 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
This might be silly but, power Naza first before the ESCs. Apparently DJI still hasn't figured out what "1000us" means in LPC clock cycles.
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
