Old Feb 08, 2013, 12:49 PM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
Originally Posted by T J Gilbert View Post
Is the Dual Lock material flexible at all?
If so, do you think the GPS module minds this?
My gut tells me it's okay for GPS, but not for the Naza MC.
DJI does like the very thin double sided mount tape for everything.
I use the DJI stuff or its equivalent.
As an added safeguard, I run a small zip-tie over the GPS module and the MC.
Hey TJ
This stuff is totally solid. There is no movement like there is with Velcro.
It's available in different "strengths" and thicknesses. The stuff I have is about 1/8th" thick when snapped together. I have the 1" wide variety.
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x4 Gemfan Woodies Props / GoPro Hero HD2
Fat Shark Predator V2 FPV
AUW 3S-4000mah = 1585g
Spektrum TX DX-7 (original) / Spektrum RX AR6200
BerndM is offline Find More Posts by BerndM
Old Feb 08, 2013, 01:12 PM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by mark_q View Post
Based on "the numbers" the best prop out there today that I have tested (and I've done a lot of this ) are the Graupner eProp$. Based on cost + known reliability and balance-ability, I'd have to go with APCsf.
As far as CF props I have no experience with props of this size but on my 55cc Slick I have tried Xoar, Falcon and HK Carbon Fiber and can tell you the worst prop I've ever used on this plane is the HK CF. Even a cheap wood prop was better. The Xoar is excellent and the Falcon is even better. The static RPM difference between the HK and the Falcon is 550RPM (6450 vs. 7000). All props tested were 23x8, all on the same day. So, just because it has a swoopy looking CF fabric, there is no gaurantee it is any better than than any other prop. (maybe I'll test them in the future).
With regards to using a SF prop on a quad, according to APC these props are good to a maximum rpm determined by the following formula:
Maximum RPM=65,000/prop diameter (inches)
This is from the APC website - http://www.apcprop.com/v/html/rpm_limits.html
Below is the last test data set I did on 10" props and I can tell you the 9" props compare almost identically.
Have fun!
Nice work. Thanks for posting this.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Feb 08, 2013, 01:40 PM
Australia, VIC, Melbourne
Joined Mar 2010
Since you chose not to list your location, I had no idea that GotHeliRC might be a "foreign" supplier to you.
Sorry...
You guys really should disclose your locations.
I've always felt it should be a requirement to post.
I also think RCG should compare your IP address to the one you list.
I'm not interested in helping any terrorists...
And if that offends anyone...
That's my stand.
you americans are hillarious!!
Haych is offline Find More Posts by Haych
Old Feb 08, 2013, 03:17 PM
Bill Glover's Avatar
Bracknell, Berks, UK
Joined Nov 2000
Originally Posted by Seebodener View Post
Olivier,
maybe these european dealers have want you want:
E-store Rotterdam: http://shop.righthere.nu/
UAVshop UK: http://www.uavshop.co.uk/catalog/
qudframe.com: http://quadframe.com/
Flyduino Shop: http://flyduino.net/
Stein Webshop: http://stein-webshop.de/Shop/
BR Jörg
I would add quadcopters.co.uk to that list - great service and very competitive prices. I have no link to them - just a happy customer.
I have used Flyduino and uavshop UK too and would definitely recommend both of them as well.
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 08, 2013, 04:32 PM
Doing stuff since 1902.
France, RA, Grenoble
Joined Dec 2004
Thanks for the links, the order is now sent, went for MT2216 motors, with 4S its looking deliciously overpowered (at least on paper).
Olivier_C is offline Find More Posts by Olivier_C
Old Feb 08, 2013, 08:08 PM
3D Flash Mob Member
mark_q's Avatar
United States, WA, Kent
Joined Sep 2003
I use lot's of dual lock, have for years, it's my favorite way to stick things like VTX's, RX's, small ESC's, Hatches, in some cases batteries, etc. It can be a problem in some cases because it locks so well and the sticky part is so good, if you have it on balsa it could peel the balsa right up! It is solid, much more than Velcro but I would not use it on a flight controller as it will intensify any vibration that exists right into the FC. If not applied really well it can also cause what-ever you are mounting to not sit perfectly flat. I use a high quality servo tape which has a very thin layer of foam, much thinner than 3M foam tape.
mark_q is offline Find More Posts by mark_q
Latest blog entry: TESTING! 9x6 Props for Penguin
Old Feb 08, 2013, 11:30 PM
* fly fast - live slow *
Seebodener's Avatar
Seeboden in Austria
Joined Dec 2008
+1
I simply forgot to mention quadcopters.uk
Seebodener is offline Find More Posts by Seebodener
Old Feb 08, 2013, 11:54 PM
work all night and fly all day
DIG2fly's Avatar
USA, CA, San Fernando Valley
Joined May 2009
DIG2fly is offline Find More Posts by DIG2fly
Old Feb 09, 2013, 07:12 AM
United States, AZ, Tucson
Joined Mar 2012
Philips Portable DVD Dual Screen 9 inch ! PD9012/37 ! SLAVE SCREEN ONLY !
$29.99 And NO BLUE SCREEN! looks like he has LOTS of these. http://www.ebay.com/itm/Philips-Port...45310#viTabs_0
goldsworthy is offline Find More Posts by goldsworthy
Old Feb 09, 2013, 09:22 AM
China, Shanghai
Joined May 2011
Sorry...
That's my stand.
Right... Oh, by the way, I'm flying to another country on holidays. Do you think it's all right to use the forum since my IP will show that it doesn't match the country on my profile? You know, us "foreigners" are all suspect.
You've started me wondering about Olivier now. Probably won't bomb anyone with his bird, but you might be helping him spy on
the neighbours teenage daughter through the bathroom window. You know those French. Wait! Is he really French??? Could be tricking us, could be tricking us.....
gadorey is offline Find More Posts by gadorey
Old Feb 09, 2013, 09:28 AM
Fly High - Lake Tahoe
Las Vegas/Lake Tahoe
Joined Feb 2010
I think I have been trickled. I am so ashamed.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Old Feb 09, 2013, 09:44 AM
Joined Dec 2004
Hmmm I think we spotted 2 terrorists (and 3, counting myself), please stand still and hold your GPS above your head, and do not turn off your mobile phone, freedom missile incoming !
Old Feb 09, 2013, 11:40 AM
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Rebuilt and waiting for props..
(I saw microcenter had cheap 10x4.7 prop set for only $10 -- May have to pick some up for practice)
v00d0o is offline Find More Posts by v00d0o
Old Feb 09, 2013, 12:58 PM
Joined Feb 2010
Buy several, you will need them and nothing is worse that waiting for parts.
Old Feb 09, 2013, 01:58 PM
3D Flash Mob Member
mark_q's Avatar
Joined Sep 2003
Careful there GW! I've been through a couple of 9" displays and none yet compare to the 8" ReadyMadeRC unit. Yes, it is a hundred bucks but it has far more brightness than any other I have seen, it is crystal clear (with my Pixm Seawolf FPV camera) and it has 800x400 resolution. Philips shows their 9" monitor has 640x220 resolution which is pretty low.
I also looked at the 10.1" RMRC monitor and it wasn't nearly as bright as the 8".
Just sayin...
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 18053 Yesterday 10:11 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
