Old Feb 04, 2013, 09:42 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Uncontrolled actions (moving forward without stick input and then moving back other times) is normally from RF interference. I spent more time this weekend testing RF interference and hope to make some videos about it soon.
MCrites is offline Find More Posts by MCrites
Old Feb 04, 2013, 09:48 AM
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
Just flew about 9 minutes (average time I spend per flight) and landed nice and smooth. Battery warm warm. Not hot just warm...again..average. But now when I set it on any of the two chargers it gives an error...hmmm
Oh and if any one has a naza they wat to sell I am open for negotiations...lol need one for my other multi!
alwaysconfused is offline Find More Posts by alwaysconfused
Old Feb 04, 2013, 12:52 PM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
I read that DJi is coming with an Update for NAZA.
Is there a chance that it might support Tricopters also?
teopbako is offline Find More Posts by teopbako
Old Feb 04, 2013, 01:03 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
how low did you run the battery? just wondering if that was a factor
CrashAffinity is offline Find More Posts by CrashAffinity
Old Feb 04, 2013, 01:08 PM
Joined Dec 2012
I ran it about 9 minutes...
I try and stay short of the flat out drain to keep the battery as healthy as long as I can. I never run them for a total of 9 - 10 minutes (up and down time total not just flight time)
They are too expensive to ruin..lol
Old Feb 04, 2013, 01:15 PM
Canada, AB, Calgary
Joined Nov 2012
do you check your battery voltage after flight? I make sure mine don't get below 11.2 these days, that's about 10-15% left i think, to make sure i don't kill the batteries.
Old Feb 04, 2013, 01:53 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Ok, so is there a way to run the assistant without an account or creating one? If not, will it at least run after I log in once with an account even if I don't have internet access?
techspy is offline Find More Posts by techspy
Old Feb 04, 2013, 02:46 PM
Olivier_C is offline
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Where did you see that, any intel on whats inside ?
I only found a 1.04 version for the Naza-H version.
Olivier_C is offline Find More Posts by Olivier_C
Old Feb 05, 2013, 01:01 AM
teopbako is offline
Ikaruswannab
Joined Sep 2009
Actually i was told so by DJI in an email.
They told me that in few weeks there will be an update for NAZA that was a couple weeks back.
I thought that you guys might be informed about it.
Old Feb 05, 2013, 07:27 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
As above there was a recent release for Naza-H but not Naza-M (yet).
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 05, 2013, 07:39 AM
Jmm_jammy is offline
Find More Posts by Jmm_jammy
United Kingdom, England, Cambridge
Joined Aug 2012
Question about Gains and remote gains via a dial.
I have my gains set as follows for my TBS Disco
Basic: pitch-165% Roll-134% Yaw-131% Vertical 179%
Remote adjust X1 X1 INH INH
Attitude gain 185% 173%
Remote adjust
X1 X1
Whenever I flip the gains switch in my TX this happens..
Basic: pitch-312% Roll-253% Yaw-131% Vertical 179%
Attitude gain 351% 328%
Remote adjust
X1 X1
The quad hovers and shakes violently and nearly flipped itself until I flicked the gain switch back to off!
None of my dials on the TX make any difference with the gain switch on or off, and also in the Naza software turning dials does nothing switch on or off. Also all settings which are X1 when changed to X2 automaticly change strait back to X1. However they will change and stay on INH.
I have used the Turnigy ER9X template from Polakium engineering
http://polakiumengineering.org/?s=Er9x
(scroll down for settings on link)
All I'm trying to do is change my gains from my TX so the quad is more sluggish and smooth for video, instead it almost shakes itself it the sky
Jmm_jammy is offline Find More Posts by Jmm_jammy
Old Feb 05, 2013, 08:13 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
@Jmm_jammy
I am not familiar with your transmitter.
There are others here who will chime in if you tell us you are not as well...
Here is a basic transmitter programming logic sequence:
You presently have X1 on a channel controlled by a switch.
If it's a 2pos switch, you get what you're seeing. ( = off or whatever the other switch limit is set to.)
That's why your activated gains nearly double when you throw the switch.
If you want the X1 to be on a dial, you either need to change the channel X1 is on to a dial.
Or, you need to set up a mix so that the switch activates the dial you prefer.
This is how you'd do what you desire with almost any transmitter.
How you do it is transmitter specific.
If you don't follow me, go back to my second sentence.
Post that you need Turnigy ERX9 transmitter programming help, and wait for a reply.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Feb 05, 2013, 08:21 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Remote adjust
X1 X1
Remote adjust
X1 X1
From that link you posted, the tx was setup to have two sets of gains but with no adjustment. It says one setup is for low gains, while the other is for high and that is initiated with the toggle switch on the left. So, you need to figure out which channel your dial is on or learn how to program it to a channel, because it looks like in the link the tx is not even setup to use the dials.
Now, if X2 keeps changing back to X1 it sounds like X2 is unplugged or something, but again from your link, the tx was setup for X2 to enable Course Lock, so your going to have to again figure out which channel your other dial is on or program it to one.
So, basically you need to research how to program your Tx and verify all the dials and switches are corresponding to the assistant sliders with the props off before flying.
Cervanchez is offline Find More Posts by Cervanchez
Old Feb 05, 2013, 10:40 AM
minizoom is offline
Find More Posts by minizoom
minizoom's Avatar
United States, CA, Yorba Linda
Joined Sep 2011
Last Sunday's flight
Valley of Fire, Nevada (2 min 37 sec)
minizoom is offline Find More Posts by minizoom
Old Feb 05, 2013, 11:13 AM
Joined Aug 2012
Thanks for the info guys, I might copy my profile on my TX so I can mess about it with and figure it out. I just don't get why the gains go up when the switch is flicked but the dial does not work.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
