Old Feb 03, 2013, 01:07 PM
jasper7821 is online now
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
Finally got everything on my new FPV TBS Discovery working good. First I had good GPS lock but horrible video signal. Then I got decent video but the GPS or compass wouldn't hold.
I now mounted the video TX on an arm with the antenna pointing down and the GPS puck back on the mast. It would get a good lock but the Dragon GPS took a few minutes to lock when the GPS puck was directly on the frame close to the Dragon GPS.
Now everything is working perfectly. The GPS holds about as good as it's going to get and I flew down to the end of the street and had perfect video signal and quality.
DJI NAZA GPS hold test (0 min 31 sec)
jasper7821 is online now Find More Posts by jasper7821
Old Feb 03, 2013, 01:14 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
I think seadog started this spreadsheet. The only thing that is now missing is the version of the software being used.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Feb 03, 2013, 01:22 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
7th column over is listing for firmware version. Very few people enter it though?
seadog1967 is offline Find More Posts by seadog1967
Old Feb 03, 2013, 01:23 PM
seadog1967's Avatar
Joined Nov 2010
I take that back some are entering the firmware No.
Old Feb 03, 2013, 01:26 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Thanks, Seadog, I missed it and did not enter either.
Site Sponsor
Old Feb 03, 2013, 03:11 PM
SeniorSpan is offline
Find More Posts by SeniorSpan
SeniorSpan's Avatar
Colorado
Joined Nov 2004
Venom93cobra,
Exactly; thanks much for your time.
Cheers
SeniorSpan is offline Find More Posts by SeniorSpan
Old Feb 03, 2013, 06:24 PM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
Some problems with the Gains
Hello Everybody,
I'm having some problems with the gains since day 1, with the default settings didn't worked, and with more 3 or 4 settings from YouTube, no luck!
I must confess that I'm not very comfortable with the PID or gains... but this is the "prince".
I need to give input all the time to maintain the quad near me, normally if I leave the TX the quad goes forward and sometimes up, and this in the GPS mode.
I really would appreciate some help.
The compass calibration is made and the TX is also calibrated and using PPM.
Please check the video, some feedback is appreciated.
Quad450 (1 min 39 sec)
All the Best,
Geotete
geotete is offline Find More Posts by geotete
Old Feb 03, 2013, 09:25 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
She flies!
Firstly, I want to thank everyone who has helped me. I have learned a lot and I still have a long way to go I will continue to tune my quad and eventually, get the GPS! I have FPV equipment, but I need to get more comfortable with flying.
My next step is to finish my camera mount/skids and also convert my power supply into a 12v charger for my Turnigy Accucel 6 Charger. (without it; I can't charge anything )
She Flies!!! (1 min 1 sec)
Light-weight skids to match my motor booms!
I will be attaching a GoPro between the skids.
Not sure what to use for the actual skid bars...recommendations?
v00d0o is offline Find More Posts by v00d0o
Old Feb 03, 2013, 10:20 PM
Joined Mar 2008
Originally Posted by geotete View Post
Hello Everybody,
All the Best,
Geotete
Something is not right. Don't know what, your gains look fine. I made a quick clip of mine in GPS mode and it sits fairly still even in the little wind that was blowing. It was all over the place and barely flyable but I had the GPS puck close to the battery. I moved it back onto the mast and it works great now
Old Feb 03, 2013, 11:56 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Todays flight with NAZA and QAV 500.
QAV 500 Winter FPV (3 min 16 sec)
m_beeson is offline Find More Posts by m_beeson
Old Feb 04, 2013, 12:24 AM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Hello Everybody,
http://youtu.be/Q-5dQyV4dVc
All the Best,
Geotete
Hey Geotete,
I'm sure we can help get this sorted out but first, we need to know something about what you know and something about your rig.
So, on the what you know part, have you read the manual, cover to cover and have you performed the setups from start to finish with complete understanding? If not, can you tell us what you may have had trouble with?
On the gear, can you post a picture or two of your Quad and tell us what is on it?
-Frame
-Motors
-Props
-ESC's
-TX/RX
-Battery
-FPV (if any)
-Telemetry (if any)
On set up there are a couple things you should know that aren't in or clear in the Manual so check the first page of this thread, TJ's Blog and read through the Naza Gouge.
Lastly, and to start, make sure your endpoints are set to at least 100% and use no trim whatsoever.
mark
mark_q is online now Find More Posts by mark_q
Latest blog entry: X-UAV Mini Talon #2
Old Feb 04, 2013, 03:03 AM
geotete is offline
Joined Mar 2011
Originally Posted by mark_q View Post
Hey Geotete,
Cover to cover more than once, checked everything in the first page of this tread watched some tutorials in YouTube, and also watched Community Build Blogs, from this page, different frame but same principals.
-Frame
-Motors
-Props
-ESC's
-TX/RX - Turnigy 9x with ER9X and Dragonlink
-Battery
-FPV (if any) NO
-Telemetry (if any) NO
Check images.
mark
All the answers in Blue.
Also I'm sending the GPS settings, in the image attached.
Geotete
Old Feb 04, 2013, 07:35 AM
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
Geotete
Not 100% positive but I think I remember that the x and y placement is meant for the controller...not the gps.
I would change those settings for the controller and see what happens.. Just a thought...
And have you pointed the GPS in the right direction? The WIRE should be pointing forward and with the correct declination...or what ever it is called. Go here to find your declination: http://www.ngdc.noaa.gov/geomag-web/#declination
alwaysconfused is offline Find More Posts by alwaysconfused
Old Feb 04, 2013, 07:41 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
No the X,Y,Z coordinates are for the position of the GPS/compass unit relative to the CG.
The main unit is meant to be mounted on the CG (or as close as possible). There is no way to define an offset for that (there is with the Wookong though).
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 04, 2013, 09:31 AM
geotete is offline
Joined Mar 2011
As per the manuals you are correct and that is like I did my configurations.
And the GPS is pointing to the front.
Geotete
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
