Old Feb 02, 2013, 07:16 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Originally Posted by Tahoe Ed View Post
Good that you found that. The Naza does not like trims to make it fly. You might as well check everything again.
Hmm...It spun around again. This time to the right...
Why is it that my idle speed is causing it to fly around already... I thought idle was supposed to be low.
Do I need to be adjusting gains?
v00d0o is offline Find More Posts by v00d0o
Old Feb 02, 2013, 07:32 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Lower your motor idle speed. If it is set on recommended then lower it a notch and go from there. The motors should spin not take off.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Latest blog entry: How to reload P3 firmware
Old Feb 02, 2013, 07:33 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I think I need to lower them in the ESCs too.. I tried the NAZA and it didn't seem to change anything.
Old Feb 02, 2013, 07:34 PM
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
That requires that you recalibrate each esc separately with your Tx and Rx only, no Naza.
Site Sponsor
Old Feb 02, 2013, 07:37 PM
dybbob is offline
Find More Posts by dybbob
United States, MI, Dansville
Joined Oct 2012
Originally Posted by jetstuff View Post
Yes, anywhere on the PCB that has direct + and - connection.... e.g. battery input or ESC power connector....just remember to do it before insulating all the soldered 'blobs' .....I use thin epoxy resin for that.
thank you sir and i plan on using shoe goo.
dybbob is offline Find More Posts by dybbob
Old Feb 02, 2013, 08:58 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Its still flipping... I have no clue what to do now.
I've calibrated all ESCs and made sure its spinning in the correct directions.
Also programmed lower idle and ensured the props spin the correct way.
I feel stupid now. After hours of trying to figure this out...I didn't read the manual.
It said.. mount the ESC section forward or else you risk your quadcopter of "roll-over"
Old Feb 03, 2013, 03:05 AM
Olivier_C is offline
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
It's still a bit worrying that you don't get any idle-speed, Naza reversed or not.
Also thats some huge props there, maybe you should try with smaller props (got the default DJI 8" ?), for less momentum, smaller cone of air and less thrust...
Olivier_C is offline Find More Posts by Olivier_C
Old Feb 03, 2013, 03:14 AM
cronalex is offline
Find More Posts by cronalex
Joined Mar 2012
Hello everyone I have a problem. I changed the radio I went from DX6i to a DX8 with Ar8000 receiver as the first receiver I used the ar600. I redid the calibration of the esc but with the Naza hours Idle speed motor I have to set the maximum ... first with the ar600 enough to leave in the middle why?
cronalex is offline Find More Posts by cronalex
Old Feb 03, 2013, 04:34 AM
ralfrcgroups is online now
Find More Posts by ralfrcgroups
ralfrcgroups's Avatar
Germany, NRW, Langenfeld
Joined Oct 2011
Originally Posted by v00d0o View Post
[STRIKE]
Buit you picture at post #17981 showed Naza's ESC section facing forward - or did I miss something?
ralfrcgroups is online now Find More Posts by ralfrcgroups
Old Feb 03, 2013, 08:57 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Confused
v00d0o:
In the image referenced your left index finger is pointing at the ESC section of the Naza.
The caption says "where I am pointing is forward".
Do you mean that your finger is pointing forward?
Or do you mean that the point you are pointing to on the airframe is forward?
See how easily you can miss-communicate?
T J Gilbert is online now Find More Posts by T J Gilbert
Old Feb 03, 2013, 09:46 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Originally Posted by T J Gilbert View Post
v00d0o:
I see where you guys got confused..
My finger is pointing in the direction of the aircraft forward not the ESC ports.
Anyway...I got it to fly! I will post videos later today. Its beautiful.
Old Feb 03, 2013, 09:47 AM
hamradioflyer is offline
Find More Posts by hamradioflyer
Madisonville, Ky, USA
Joined Nov 2009
naza flip on takeoff
True confessions, I have built 5 quads. The first flipped on takeoff because of reversed motors. Since then I have been very careful about such details and the next few quads went together fine. I was rebuilding one of my quads on a new frame. The naza/gps , motors , esc's , receiver from another quad that flew well.
I assembled a hoverthings fpv frame and placed my gear on it. It flipped on maiden. I was sure everything was correct. After hours of searching the web and forums and rechecking everything, I was about to strip everything off and build again with different motors and esc's. Then while staring at the motor diagram and my quad , I was shocked to find I had reversed motors 3 and 4 . Saved me several hours of work and frustration. I know I checked the motor connection and rotation a dozen times.
Lesson , if your multi flips on maiden , double check motor connection and prop orientation.
hamradioflyer is offline Find More Posts by hamradioflyer
Old Feb 03, 2013, 10:53 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Yes..the stupid detail always get ya!
I knew it was a rotation problem because I had checked the motor rotations and props at least 10 times. I also ruled out the ESCs because I had calibrated them and it was flipping both to the left and right. I noticed it seemed to be counteracting the wrong way...so I double checked the NAZA direction. Found out it was reversed, so I flipped the quad around and switched up the motors. Now it flies perfectly
Old Feb 03, 2013, 10:55 AM
SeniorSpan is offline
Find More Posts by SeniorSpan
SeniorSpan's Avatar
Colorado
Joined Nov 2004
G'day all,
I've managed to "misplace" the doc, posted some time ago, containing a collection of Gains settings used for the F450 and I think the F550 as well.
I would really appreciate the location of the doc vs. going through the 1200 pages of this thread.
SeniorSpan is offline Find More Posts by SeniorSpan
Old Feb 03, 2013, 11:51 AM
Venom93corba is offline
Find More Posts by Venom93corba
United States, OH, Sylvania
Joined Jan 2013
Originally Posted by SeniorSpan View Post
G'day all,
Not sure if your talking about this but this was posted a couple of weeks ago.
https://docs.google.com/spreadsheet/...3c&pli=1#gid=0
Venom93corba is offline Find More Posts by Venom93corba
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
