Old Jan 31, 2013, 12:58 PM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
90% of all videos I have seen like yours is because of the male end having a bad solder. Resoldering normally makes the problem go away in most cases but i'd fly over grass for a little while. Also while you are doing it... might as well do all motors you have in case it was a batch problem from the factory.... and believe me, you aren't the only one having issues.
MCrites is offline Find More Posts by MCrites
Old Jan 31, 2013, 01:03 PM
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
Yes, my intention was to resolder all of the motors, I just didn't know, if I should check and resolder ESC's also.
Thanks again MCrites.
Drekavac is online now Find More Posts by Drekavac
Old Jan 31, 2013, 01:05 PM
United States, NC, Charlotte
Joined Jan 2007
Thermal imagers small enough to fit on key chain are cheap an an excellent tool for checking connections at the amps we draw. Will show up a bad solder joint or poor continunity across connection.
Tim
w4yn is offline Find More Posts by w4yn
Old Jan 31, 2013, 01:06 PM
The Devil Is In The Details...
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Test Fly Over Grass!
And like MCrites said, test fly over grass...
If you'd have been over grass in the video, you'd probably not have broken your props.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 31, 2013, 01:07 PM
Habitual Line Stepper
Cervanchez's Avatar
United States, CA, Orange
Joined Dec 2011
Tim
you have a link?
Cervanchez is offline Find More Posts by Cervanchez
Old Jan 31, 2013, 01:14 PM
Joined Jan 2012
Tim
For under $1500?
Old Jan 31, 2013, 01:18 PM
Cervanchez's Avatar
Joined Dec 2011
that's why I ask
For under $1500?
he said small and cheap, although cheap is a relative term..
Old Jan 31, 2013, 01:54 PM
Doing stuff since 1902.
France, RA, Grenoble
Joined Dec 2004
Its a bit sad that we have to doubt the quality of DJI links, they market themselves as a serious company, and its not like soldering was invented last week...
Olivier_C is offline Find More Posts by Olivier_C
Old Jan 31, 2013, 02:02 PM
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
I think I found the problem.
It was bad connection between male and female bullet connector.
Look at the photo, am I right?
Old Jan 31, 2013, 02:11 PM
Joined Feb 2009
Male Connector
Was the male connector loose in the middle female when you pulled it out?
There's definitely been some arcing or there's corrosion in the middle female.
Clean her up, test and/replace the male, and you should be okay...
Get that corrosion out. It's what's causing and exacerbating the poor connection...
Old Jan 31, 2013, 02:19 PM
QuaDreko pilot :)
Drekavac's Avatar
Slovenia, Kamnik
Joined Oct 2010
No, it was not loose. But the contact was bad.
I will clean it, or maybe replace it.
Old Jan 31, 2013, 03:35 PM
Joined Feb 2009
Connectors
Bad connectors cause 90% or more of electronic failures.
A cleaner/lubricant might be warranted for the environment where you fly, or the connector may have come to you dirty.
I use a connector lubricant and so does U2builder.
I'm not where I can get the name off mine, maybe U2 is at home?
Old Jan 31, 2013, 04:19 PM
Joined Dec 2012
I am using the contact grease for spark plugs on mine...call me crazy but...any how thats what I use especially since there is a lot of moisture and dirt where I fly so at take off I usually get a wet underside (also where the ESC's are) so the plug grease has stopped a lot of issues. Just dont over do it! Just enough to coat the male end with a light film!
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jan 31, 2013, 04:42 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
GB OX-GARD is a good product. It is available at most hardware stores. I believe it is a conductive grease with tiny metal particles. It is used to prevent corrosion in electrical connections. Do NOT use dielectric grease. That is an insulator.
I have adopted a recommendation on this thread, I think by Bill Glover, to replace all of the connectors with Protek bullets available from A Main Hobbies. These do not have the swivel cage, and but rather have a solid split male plug. They are also easier to solder because there is a little cut out in the side of the cup so you solder the wire onto the side of the cup rather than trying to "dip" it into a pool of solder. After several problems with connectors, some of which did not happen right away, I replaced all the connectors on my quad and my hex.
Read this and you will probably want to have a tube of OX-Gard on hand. It also explains why not to use dielectric grease.
http://www.olypen.com/craigh/oxgard.htm
u2builder is offline Find More Posts by u2builder
Old Jan 31, 2013, 09:15 PM
Joined Jan 2007
For under $1500?
Less than $100 Tim
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 18054 Today 03:58 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
