Old Jan 30, 2013, 08:08 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
450mm vs. 500mm
Originally Posted by v00d0o View Post
Just out of curiosity..would a 450mm frame be less stable than a 500mm?
I'm rebuilding my quad arms so I was wondering if I should change it to save weight.
My quad's main purpose is to film with a go pro. Thanks!
500mm =~ 20"
450mm =~ 18"
I don't think you'll see much difference.
I have an F450 and a Phantom (350)
Stability difference is not discernible.
My F550 (6 motors) = really stable.
As a result, the F550 has earned first string as camera ship.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 30, 2013, 08:31 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Despite a *lot* of tweaking I've never managed to get my F550 to be quite as steady as the 450 quad I had the same gear in before. Particularly when the wind blows a bit. Quite possibly a 4S setup with smaller props would have been better on the F550.
Anyway I'm going to put everything into a Y6 frame which arrived today. The Y layout is meant to be more stable in wind than a flat hexa, and has decent redundancy if you lose a motor/prop/ESC. Against that they are slightly less efficient.
Oh and the size ... it's a "900" (in fact 880mm) I chickened out of getting the 1200 version
Fingers crossed ...
Bill Glover is online now Find More Posts by Bill Glover
Old Jan 30, 2013, 08:37 AM
hoggdoc is offline
Find More Posts by hoggdoc
United States, CA, Huntington Beach
Joined Jan 2013
Originally Posted by alek3d View Post
Guys,
I am really glad you liked the idea. I did the second take the last weekend trying to make a tighter circle. It is actually not a big problem, one just needs to play with roll, pitch and yaw constants. Tighter circle means increasing them all a bit.
Ok, what I made in my ER9X was that I added extra mix for roll, pitch and yaw. Each of the mix is activated by some (the same) switch, in my case I mapped Elevator D/R switch.
For e.g roll I added a mix, source is Full, weight is 40, switch is ELE and it does the Replace (you can Add, Multiply or Replace the value). Same for pitch and yaw
Roll 40% to the right
Pitch 50% forward
Yaw -15% to the left
So, when I flip the switch my stick values are replaced by constant values above. I can control throttle only. Maybe I will try "Add", insteaod of Replace, so I would be able to control the copter or make some manual adjustments.
My second test showed that when it's windy it's bad because it blows away the copter and it ends up in a spiral, not a circle. I'll post the video soon.
So this works the best when there is no wind.
Just for the reference, this is what we talk about
Being very new to the RC hobby I'm not sure if I'm ready to try this, but thanks for the details. I'm curious do you think if you had GPS with course lock turned on it would correct for the wind issues you spoke of.
I'm just learning about all this stuff so don't be too critical of my questions....
hoggdoc is offline Find More Posts by hoggdoc
Old Jan 30, 2013, 08:42 AM
Empire Support
Joined Feb 2009
3S vs. 4S
Fingers crossed ...
Should have noted:
F450 & F550 have always been 4S
Phantom is staying stock = 3S
Old Jan 30, 2013, 08:49 AM
hoggdoc is offline
Joined Jan 2013
Originally Posted by Old guy1 View Post
Don't know about Newton's 3rd law, just know throttle % needed to hover went from 55% to 52%. Took a little more weight off of her, hoping next hover will be at 50% where I want it to be. The lift is not higher (would be the same amount needed to move the weight - my misstatement), just throttle needed to produce it is lower, which is what I wanted
Gary
I'm curious, how are you determining what percentage of throttle is being used?
Old Jan 30, 2013, 09:17 AM
Empire Support
Joined Feb 2009
50%?
I would be too.
AFAIK the Naza places hover at 50% LH stick regardless of the variables...
Old Jan 30, 2013, 09:25 AM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Las Vegas/Lake Tahoe
Joined Feb 2010
The only way to really determine how much throttle you are actually using is to fly in Manual mode. This is why you have to adjust your throttle curve in Manual so that you don't rise or fall when switching from ATTI to Manual and back.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Jan 30, 2013, 09:41 AM
Empire Support
Joined Feb 2009
Good Point!
I overlooked the Manual option.
Old Jan 30, 2013, 09:53 AM
Tahoe Ed is offline
DJI Support
Joined Feb 2010
I challenge myself occasionally with Manual. That is why I still fly my Single Rotor Helis. It is funny, we all consider Manual like an uncontrollable mode but 2 years ago we were thrilled to have the stability of gryos and accelerometers. How quickly this sport has changed.
Site Sponsor
Old Jan 30, 2013, 09:57 AM
Empire Support
Joined Feb 2009
Still Got Mine
I find a regular heli easier for me to fly than a multi in Manual.
My orientation with the multi gets scrambled rapidly.
On a heli, the tail is the tail.
I'm kicking the dust off my heli skills due to the fact that a friend is interested in helis and needs an instructor...
Old Jan 30, 2013, 10:03 AM
Tahoe Ed is offline
DJI Support
Joined Feb 2010
Fly the disc.
Site Sponsor
Old Jan 30, 2013, 10:25 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I had only begun to learn to fly a heli when I got my multicopter so its not like I could make a comparision. I tried a little manual with my multicopter before I put a lot of expensive FPV gear on it. I could "hover" it and move it around face out sort of OK but the problem is that as I got any distance away orientation really complicated the picture. In the Atti or GPS mode when I lost orientation I could relax and rotate it until I saw the lights or whatever or used the home lock. In manual if I lose orientation and I don't know what I am doing I am likely to have an expensive crash.
I have been flying mostly FPV except when I take off the goggles to land, and it is I can notice my LOS skills to be not as sharp when I pull off the goggles as it used to be when the entire flight was LOS.
I think I save "manual" for my heli practice next summer.
u2builder is online now Find More Posts by u2builder
Old Jan 30, 2013, 12:15 PM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
Fixing is where you learn though.
If everything came too easy, it wouldn't be fun
You have a good attitude.
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Jan 30, 2013, 12:23 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
I removed the "manual" mode since day #1 if I wanted to have a hard time I would have bought a KK board instead of a NAZA. For me easy is more fun!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 30, 2013, 03:45 PM
mikemijal is offline
Find More Posts by mikemijal
Westland Michigan.
Joined Jan 2012
I second that GW
mikemijal is offline Find More Posts by mikemijal
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 11:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
