Old Jan 29, 2013, 06:40 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
mauromassari is offline Find More Posts by mauromassari
Old Jan 29, 2013, 06:47 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Originally Posted by mauromassari View Post
Who was flying it
tech69x is offline Find More Posts by tech69x
Old Jan 29, 2013, 08:08 AM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Originally Posted by jetstuff View Post
Have you recharged your batteries ? after all the messing around, they could be low.....having a 'rest' gives them time to recover a bit.
I have a 3 cell and its still around 11V.
Its still charged up, I think.
Originally Posted by mark_q View Post
Couple more cents?
The video looks like a synch problem which would indicate an incompatibility between the ESC's and the motors or a bad connection. I've had the synch issue using Rimfire motors and Plush 60 ESC's and I actually cooked one of the Plush 60's on my bench tester when this occurred. The motor would occasionally start and run OK but then the jitters would start and finally...smoke. I bought a Scorpion ESC for , the Rimfire and no problems, ran like a champ.
So to add to what TJ said, I too have never had an HK motor fail (SK2 in my case) but I have had a Plush ESC fail.
On the HK returns, I have had no issues. I have returned several items including a Blue Series ESC that was DOA and a Compact Lipo that would not balance. I emailed them, got an RMA and was able to return these two to the USA warehouse even though they were purchased from China. Total turn around was about five days.
BTW - a very experienced friend bought 6 Turnigy Type TY-P1 and 4 of them smoked within 30 seconds of start up. Don't buy them!
Good luck!
Originally Posted by T J Gilbert View Post
It sounds like you have a bad connection of some kind.
MCrites ruled out a bad power distribution board when you told him one motor was working.
I don't know exactly what you meant by a "power spider".
If it's what I suspect, you butt-soldered several wires together to form a "spokes on a wheel" type thing.
I'm not questioning your soldering skills, but since you were going to do this anyway...
Desolder your ESCs from the "power spider" and set then up to test and run the motors and ESCs separately.
See what you get...
Another point of advice from someone old enough to be your grandfather....
You've been at this all day.
Your nerves (even though they are young) are probably frazzled.
Give this thing a rest.
It will be waiting on you tomorrow, and things might look much different in the light of a new day...
Thank you for that advice! My parents told me to stop too... give it a break and come at it again. One tip I've seen on this forum is "know when to walk away!"
I've just tested taking out a working motor without one of the bullet connectors attached, and I had the same issue. I'm positive now that somewhere between my ESCs and my Motors, there are quite a few bad connections. I plan on just getting rid of all these bullet connectors and splicing the wires directly to the ESCs
v00d0o is offline Find More Posts by v00d0o
Old Jan 29, 2013, 08:18 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Nice work v00d0o! Regardless of the outcome, think of everything you have learned in the process!
MCrites is offline Find More Posts by MCrites
Old Jan 29, 2013, 08:30 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Thank you!
You guys have been great help! I wish I could return the favor.
I'll be sure to help noobs when I become more familiar with the RC world
Old Jan 29, 2013, 08:35 AM
MCrites is offline
Joined Jan 2012
Video your flights... we like crash videos
Old Jan 29, 2013, 08:41 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Will do!
Old Jan 29, 2013, 09:46 AM
SeniorSpan is offline
Find More Posts by SeniorSpan
SeniorSpan's Avatar
Colorado
Joined Nov 2004
G;day all,
very interesting last page of posts, especially T.J.'s comments on motors.
Having read completely through this thread twice I'm under the impression the DJI NAZA is somewhat selective on what aftermarket ESC's are used, but almost does not care what aftermarket motors are used, is that a correct assumption, or did I miss it completely?
SeniorSpan is offline Find More Posts by SeniorSpan
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
Originally Posted by v00d0o View Post
Will do!
One issue I ran into with my first quad build: The wire going into the bullet connector from the motor sometimes breaks off!
You wont know it because of the shrink wrap.
You can test this with a multi testor and wiggle the wire or just feel it around the base of the bullet connector. The same can happen with a cold solder joint you made.
Those are the cheapest and fasted ways to test.
I had 3 of them (all on different motors) happen during the build processes and it was easy to fix. Just remember to re-shrink tube it.
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jan 29, 2013, 09:50 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Just buy the DJI stuff the first time and have fun flying instead of fixin!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 29, 2013, 09:55 AM
MCrites is offline
Joined Jan 2012
Naza talks to the ESCs, the ESCs talks to the motors. The Naza doesn't really know what is spinning the propeller... it just tells the ESC to make it spin faster or slower to keep level.
Naza needs fast ESCs but doesnt care about the motors.
Old Jan 29, 2013, 10:38 AM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Fixing is where you learn though.
If everything came too easy, it wouldn't be fun
Old Jan 29, 2013, 11:05 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
I Still Like Your Attitude!
If you don't lose your mindset, you are going to be very successful with this hobby.
(And, probably, life...)
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 29, 2013, 04:51 PM
BerndM is offline
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
Originally Posted by Old guy1 View Post
Bernd
How do you like the Gemfan 10x4 woodies? I just got some for my F450, but the weather is so bad, I have only been able to hover in the house (only while the wife is gone, flying something that big in the house would freak her out)
Gary
Hey Gary
I really like them a lot. They draw about 4 more amps than my 10x5 Graupners but they do provide some noticeable extra thrust. They are stiff like the groupners so nice steady video with my GoPros.
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x4 Gemfan Woodies Props / GoPro Hero HD2
Fat Shark Predator V2 FPV
AUW 3S-4000mah = 1585g
Spektrum TX DX-7 (original) / Spektrum RX AR6200
BerndM is offline Find More Posts by BerndM
Old Jan 29, 2013, 04:53 PM
Joined Mar 2012
This RC hobby seems to stress most wifes out! I cant understand it?.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
