Old Jan 28, 2013, 05:41 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Originally Posted by MCrites View Post
I saw on the spreadsheet most people with Cutoff = Off, Timing = Medium, Startup = Normal, Battery = NiMh
Awhhhh man..
still have the same problem...motors just click not turning
I'm about to cry lol
v00d0o is offline Find More Posts by v00d0o
Old Jan 28, 2013, 05:43 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Time to try different things... change timing to slow.... then to high.... not working change back to medium and change the startup to soft... repeat.
MCrites is offline Find More Posts by MCrites
Old Jan 28, 2013, 05:54 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I think I'm going to go crazy from these beep codes.
Still didn't work
I tried all startup modes and timings...
Very strange.. Nothing worked
Old Jan 28, 2013, 05:55 PM
MCrites is offline
Joined Jan 2012
Now cry... sounds to me to be the wrong ESCs. Check through your Naza Assistant, make sure the low voltage cutoff isn't on. Go through all of the ESCs again... triple check all wiring. Make sure your flight mode stuff and VU is working properly (lights on the VU).
Old Jan 28, 2013, 06:00 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I wasn't using the NAZA at all this whole time.. Just connected each motor straight to the Transmitter.
All my wiring for the ESCs are soldered connections with tightly wound wire and heatshrink/electrical tape. All connected to a "power spider."
How good is hobby king returns?
Old Jan 28, 2013, 06:32 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
So that video you posted was with the ESC directly connected to the rx? And this happens with all four motors? If so, the last thing I can think of is a bad solder joint in your power spider. Maybe its not getting enough current. You gotta rule things out one at a time, even if that means unsoldering your connections.
Cervanchez is offline Find More Posts by Cervanchez
Old Jan 28, 2013, 06:38 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Yes..only to the Rx
One motor works perfectly. 3 don't ...they just glitch/stutter out.
What do you mean not getting enough current?
I have a 10 AWG wire power spider...and that just branches off to each esc/ vu/ and battery. Is there something wrong with this setup?
Old Jan 28, 2013, 06:43 PM
Cervanchez's Avatar
Joined Dec 2011
Yes..only to the Rx
It was just a thought that a bad solder joint could act like a current limiting resistor. But since one of your motors works fine that eliminates the power board. So, when you say one motor works fine can you switch that motor to a different esc or vice versa and see if you can pin it to the ESC or motor? Or did you already do that?
Old Jan 28, 2013, 06:44 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
good thinking :P... let me try that out.
Old Jan 28, 2013, 06:59 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Well...by the looks of it...Something is wrong with the motors!
Whats the next step?
Old Jan 28, 2013, 07:05 PM
Cervanchez's Avatar
Joined Dec 2011
Ok, so to confirm, you can use any ESC with that good motor and it works fine. But if you swap motors only one works? If that is so, then I would say you've got some bad motors. I would return them. Which sucks if you got em from HK
Old Jan 28, 2013, 07:10 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I got them from hobby king... 3 of them are BAD?!@$?
I swap motors and the ESC works.
I swap ESC on the one motor that works...and it works!
How bad is their return policy?
No hope?
Old Jan 28, 2013, 07:15 PM
Cervanchez's Avatar
Joined Dec 2011
No hope?
I don't know I've never returned, I was just saying because it takes so long. Unless you got it from the US warehouse.
Old Jan 28, 2013, 07:20 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Well this sucks...I just sent in a refund...Don't know how that will turn out.
I'm going to try and re-solder connections just to make sure.
Old Jan 28, 2013, 07:24 PM
Cervanchez's Avatar
Joined Dec 2011
Actually just remembered. Chinese new years about to hit so your not gonna get squat for a while.
Just to be sure we're not missing something. You haven't told much about your setup, unless I missed it. Like what kind of motors, battery, power distribution. pics or a video wouldn't hurt. Maybe we can see something else.
edit: nm, i just saw your videos. hmm can't think of anything else right now...
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
