Old Jan 28, 2013, 04:27 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
Originally Posted by Cervanchez View Post
Sorry I didn't catch which ESC's you are using? I've ran into some that don't work with the standard calibration procedure.
I'm using a Turnigy Plush 25amp
No problem. I'm just trying to get this thing to work..So far, only one motor is working perfectly.
v00d0o is offline Find More Posts by v00d0o
Old Jan 28, 2013, 04:30 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Tahoe Ed has some Turnigy 25A.... not sure the type. Maybe he can help.
MCrites is offline Find More Posts by MCrites
Old Jan 28, 2013, 04:31 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
hmm..I don't understand why my calibration is not working. Should I post a video of my whole process?
Old Jan 28, 2013, 04:35 PM
MCrites is offline
Joined Jan 2012
ESC set to NIMH battery (even when using lipo from what I understand)? It is supposed to be. Medium throttle typically works.... no LV cut off...
Old Jan 28, 2013, 04:45 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Interesting. The ones I had trouble with were supposedly the same as urs, but they were unmarked. Never could get them to calibrate and eventually have up. I never used those with the naza. Are they on the compatible esc list?
Cervanchez is offline Find More Posts by Cervanchez
Old Jan 28, 2013, 04:47 PM
MCrites is offline
Joined Jan 2012
I checked the list for him and there are a couple of people using them. For some reason I thought there were two versions of those ESCs labeled the exact same with different insides (typical in Chinese goods). One would work, one wouldn't. There was a particular chip that was too slow.
Old Jan 28, 2013, 04:49 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Yeah they are on the compatiable esc. list.
I actually think I've calibrated them.. Still having the same problems though.
Old Jan 28, 2013, 04:55 PM
MCrites is offline
Joined Jan 2012
Throttle may be calibrated... what are the other setting set to?
Old Jan 28, 2013, 05:05 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
What do you mean set to?
Old Jan 28, 2013, 05:09 PM
MCrites is offline
Joined Jan 2012
ESC Calibration & Programming (2 min 29 sec)
1 Minute in... watch the entire thing though.
I'm not a pro at this... just helping. There may be a way to do it without a card.
Old Jan 28, 2013, 05:14 PM
MCrites is offline
Joined Jan 2012
HobbyKing Turnigy ESC - Throttle Stick Programming (2 min 43 sec)
This shows how to do it with the transmitter... the video above shows the settings for multirotors.
Old Jan 28, 2013, 05:15 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
http://vimeo.com/38798014
I'm trying to do the programming of ESCs now.
Do I need to reverse the throttle..I'm not entirely sure if my Turnigy 9x is set up correctly. Could you lead me to a proper guide?
Old Jan 28, 2013, 05:16 PM
MCrites is offline
Joined Jan 2012
Plug it into the Naza assistant... which way does the throttle move when you move it up and down.
Old Jan 28, 2013, 05:30 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I was mucking around inside the turnigy 9x.
I've OFFICIALLY set all the calibrations of the escs. FINALLY.
I heard the two beeps...moved the stick down...then heard the 3 beeps + 1 long beep. Thank you guys so far :P
Now that it is officially calibrated...I'm going to now try and program it. Are these the correct settings?
Brake: off
Battery Type: NiMh (even though I have a LiPo)
Cuttoff mode: reduce power
Cuttoff threshold: medium
Startup mode: soft
Timing: low? (or medium)
You all have been great help. Especially me being a royal pain in the a**
Old Jan 28, 2013, 05:34 PM
MCrites is offline
Joined Jan 2012
I saw on the spreadsheet most people with Cutoff = Off, Timing = Medium, Startup = Normal, Battery = NiMh
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
