Old Jan 28, 2013, 04:10 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
After calibrating the ESCs you may need to go into the Assistant and set the idle speed to HIGH. Some ESCs require that to be changed.
MCrites is offline Find More Posts by MCrites
Old Jan 28, 2013, 04:18 PM
v00d0o is offline
Find More Posts by v00d0o
v00d0o's Avatar
United States, VA, Fairfax
Joined Dec 2012
How do I calibrate these ESCs?
I have no idea how to do it!
v00d0o is offline Find More Posts by v00d0o
Old Jan 28, 2013, 04:21 PM
MCrites is offline
Joined Jan 2012
http://bit.ly/116Cy6y
Old Jan 28, 2013, 04:24 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Calibration
Originally Posted by v00d0o View Post
Ok I got one of 4 motors running
HOW EXCITING!
one seems to be stuttering...? The others aren't moving for some reason
http://www.youtube.com/watch?v=I6F6VCvVoKU
I haven't done ESC calibration...I think I may try that right now.
I set up the switch. Manual and Attitude modes. (I was out of the house for 2 hours..but Now I'm back and ready to get this thing in the air)
Here's a recent post on ESC calibration.
http://www.rcgroups.com/forums/showp...ostcount=17071
You might want to do a little research of your own.
I think the Turnigy Plush (looks like what you're using) brochure has a similar procedure outlined.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 28, 2013, 04:32 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Thank you TJ.
Here is a video of the main problem I'm having.
VID_20130128_162611.mp4 (0 min 24 sec)
Do I need to get rid of these bullet connectors?
I could just solder directly
Old Jan 28, 2013, 04:35 PM
Empire Support
Joined Feb 2009
Calibrate First
Thank you TJ.
http://www.youtube.com/watch?v=KABNUQia53E
That's not what a faulty bullet connector/motor behavior looks like.
Are those ESCs stock or re-flashed units?
The motor timing is all screwed up.
Try the ESC calibration.
Old Jan 28, 2013, 04:38 PM
MCrites is offline
Joined Jan 2012
Clicking = motors not in sync with the ESC.
Old Jan 28, 2013, 04:48 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Stock ESCs...
I'm not sure if I'm calibrating these correctly.. I still have the same problem..
Old Jan 28, 2013, 04:55 PM
Empire Support
Joined Feb 2009
Do Your Share
Stock ESCs...
I sent you a link, and I told you to fish out the ESC brochure.
You need to educate yourself.
We'll help/teach, but you need to help/learn.
We're not in the business here of thinking for you...
Take us through your "calibration" procedure as you understand it...
Old Jan 28, 2013, 05:04 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
I go through the exact process...and I've read the manual which talks about Throttle range setting.
I switch on transmitter with full throttle.
Then after full throttle, I wait two seconds for the two beeps.
At that point, I move throttle stick all the way down. But then it doesn't make the 3 single beep tones... it goes straight into "programming mode"
Old Jan 28, 2013, 05:05 PM
MCrites is offline
Joined Jan 2012
Do you have any trims set on your TX?
Old Jan 28, 2013, 05:09 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
No.
They are set as so:
AIL 001<001>
ELE 001<035>
THR 001<014>
RUD 001<120>
Old Jan 28, 2013, 05:16 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
try this
power the ESCThen after full throttle, I wait two seconds for the two beeps.
At that point, I move throttle stick all the way down. You have to move it down quickly or it will enter programming mode. But then it doesn't make the 3 single beep tones... it goes straight into "programming mode"
did you power the tx, then full throttle, then power ESC? Your post isn't clear
Cervanchez is offline Find More Posts by Cervanchez
Old Jan 28, 2013, 05:22 PM
v00d0o is offline
v00d0o's Avatar
Joined Dec 2012
Power on TX with full throttle stick.
Turn on ESC.
Wait for 2 second beep.
Move stick down.
After that, it still doesn't seem to be calibrating.
Old Jan 28, 2013, 05:25 PM
Cervanchez's Avatar
Joined Dec 2011
Turn on ESC.
Move stick down.
Sorry I didn't catch which ESC's you are using? I've ran into some that don't work with the standard calibration procedure.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 11:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
