Old Jan 26, 2013, 12:55 PM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
POI Orbit
Hi guys,
I kind of like autonomous orbit or POI (Point Of Interest) orbit feature that some more advanced controllers have. I am not sure if I am the first one with this idea, maybe not, but one day I was thinking that if I preset certain fixed values for pitch, roll and yaw in my transmitter, then Naza with its altitude hold could nicely make a circle pointing its face to the center of the circle. So I tried that and it actually worked quite nicely.
Here is my first try. It is not perfect but good enough for the first try. My settings are in the description of the video. I think I should lower the roll gain from 40% to some 30% or so, because I think it circles too fast....
Autonomous Orbit Demo (2 min 13 sec)
I wanted it because when I try to do an orbit manually, it is not very good, it is not smooth. I think with some more tweaking it could really mimic POI Orbit
Enjoy!
alek3d is offline Find More Posts by alek3d
Old Jan 26, 2013, 01:44 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
I'm With You...
Originally Posted by kallend View Post
OK, I'll make a pitch again for using "HELI" rather than "ACRO" setup with a Spektrum TX. It is trivially easy to use the "pitch" channel for the "U" input, and set the three normal pitch curves to be constant (that is, flat and independent of throttle stick position) at the values needed for MAN, ATTI and GPS, and the "hold" pitch curve to the value needed for failsafe. No mixers needed, no subtrims needed, no endpoint setting needed.
I've always flown in Heli mode.
I'm actually uncomfortable giving advice for Arco setups because I don't have first hand experience...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 26, 2013, 01:50 PM
Empire Support
Joined Feb 2009
@alek3d
Most interesting thing I've seen done in a while.
If you get it refined to a tighter circle, keep us all posted!
Old Jan 26, 2013, 06:03 PM
tkeeg is online now
Find More Posts by tkeeg
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
A new Nano Copter
A friend sent me this link about a new, self video, Nano Copter coming to market early next year. It streams video to your smart phone or tablet and it supposedly does not require a remote control transmitter as it responds to voice commands & uses a "follow me" feature.
http://www.alwaysinnovating.com/prod...cam-photos.htm
tkeeg is online now Find More Posts by tkeeg
Old Jan 26, 2013, 06:13 PM
tkeeg is online now
Multi-Rotor Pilot
tkeeg's Avatar
Trenton, NJ
Joined May 2008
Originally Posted by alek3d View Post
Hi guys,
http://www.youtube.com/watch?v=zGFA804f4zY
Enjoy!
Great idea!
I use a switch with a preset yaw to slowly turn my quad for panoramic photos, but never thought of setting the mix that you did for the POI orbit.
Thanks for posting your idea!
Old Jan 26, 2013, 07:47 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
Mine are set up in ACRO and I use Aux 1 plugged into the U channel for FMode. My gear is for failsafe and my Aux 2 is for IOC.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Jan 26, 2013, 09:55 PM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
That's how I did mine at first. Then changed to the way I described as it seemed a more elegant solution.
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Jan 27, 2013, 01:32 AM
SCVJeff is offline
Find More Posts by SCVJeff
Joined Mar 2009
I like it! Can you share the basic values and directions as a quick start?
SCVJeff is offline Find More Posts by SCVJeff
Old Jan 27, 2013, 02:14 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Hi guys,
Enjoy!
Very nicely done
tech69x is offline Find More Posts by tech69x
Old Jan 27, 2013, 03:17 AM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
Shock ......horror.....RT*M .........??
jetstuff is offline Find More Posts by jetstuff
Old Jan 27, 2013, 06:48 AM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Is there a mix you set up to use Gear for fail safe? IE Gear to Aux 1?
If Aux1 is plugged into U then I do not know how to use Gear for Failsafe.
Just Learning.
Tim
w4yn is offline Find More Posts by w4yn
Old Jan 27, 2013, 07:32 AM
hoggdoc is offline
Find More Posts by hoggdoc
United States, CA, Huntington Beach
Joined Jan 2013
Very cool, can you post details of the steps necessary to accomplish the orbit. Also could the orbit be made a tighter circle and slower?
hoggdoc is offline Find More Posts by hoggdoc
Old Jan 27, 2013, 09:14 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
http://www.rcgroups.com/forums/showthread.php?t=1818134
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 27, 2013, 11:51 AM
lakis21 is offline
Find More Posts by lakis21
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Hello anyone tried any of those on a f550?
http://rctimer.com/index.php?gOo=goo...4&productname=
or
Are they balanced?
Thanks in advance !
lakis21 is offline Find More Posts by lakis21
Old Jan 27, 2013, 01:30 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
You know that you can manually set a new home point while flying? Then go out 10 meters from that new home point and and activate Home Lock. Rotate the copter to the face the HP and then rotate with your aileron stick. I have not tried this yet, but in theory and as stated in the manual it should work.
NOTE OF CAUTION!!!!! When you set the new Home Point, if you go to failsafe, that is the point it will return to. Just an FYI. Do don't blame me if something happens.
Site Sponsor
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
