Old Jan 25, 2013, 09:37 AM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
^^Proof I am too hot for Ed
MCrites is offline Find More Posts by MCrites
Old Jan 25, 2013, 09:38 AM
Flying R/C since 1964
kallend's Avatar
United States, IL, Flossmoor
Joined Sep 2004
Originally Posted by Olivier_C View Post
Plus if you set like aileron=0, rudder=0, pitch=0, throttle=40% so it goes back to the ground, it may be ugly when it touch the ground and the props keep turning. Whereas the Naza fail mode will (should) detect the ground contact and will stop the motors.
Tested mine before I had the GPS and it did indeed come down slowly, touch down softly, and stop the motors.
kallend is offline Find More Posts by kallend
Doing stuff since 1902.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
You shall not hurt lions.
Olivier_C is offline Find More Posts by Olivier_C
Old Jan 25, 2013, 09:51 AM
3D Flash Mob Member
mark_q's Avatar
United States, WA, Kent
Joined Sep 2003
I agree and would add that on some days failsafe auto-land does a better job than me
mark_q is offline Find More Posts by mark_q
Latest blog entry: TESTING! 9x6 Props for Penguin
Old Jan 25, 2013, 09:53 AM
Olivier_C's Avatar
Joined Dec 2004
The 1st time I tested the RTH, the auto-landing was so soft that the Naza didn't detect it, and it gently bumped 10cm, like 3 or 4 times until the bump was hard enough so it realized it was on the ground and stopped the engines :]
Or maybe it computed that it had already lost enough altitude, from the GPS or whatever...
Old Jan 25, 2013, 11:13 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by helifreak592 View Post
i am Not in , St peters burg FLORIDA right now i am in my country Guyana South America ,
That is definately too far to walk to from here
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Jan 25, 2013, 12:21 PM
Joined Dec 2012
Originally Posted by Tahoe Ed View Post
Volcano!!! I am not flying with you.
last time I flew into a volcano I found the keys to my truck I lost in '90
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jan 25, 2013, 01:03 PM
United States, NC, Charlotte
Joined Jan 2007
First Flight with out issue
Well I finally figured out I had gains all set to 100% and changed to factory recommendations for 550. Wow what a difference it almost flew hands off. I still have some drifting to work on I guess tweaking gains maybe, back to manual and this forum.
You gents (gals maybe) are the best, at least I out of starting blocks for learning curve.
It was so cold here I was flying from dinning room and negotiating trees (lots) in back yard and did not take any bark off!
Tim
w4yn is offline Find More Posts by w4yn
Old Jan 25, 2013, 01:13 PM
NoLgs2StngArmsBigHeart!
JJtr1954's Avatar
USA, TX, Kilgore
Joined Apr 2010
Guyana South America ???
I am sure you know better than I but I always thought Guyana was in Africa somewhere?....Not doubting You at all....JJ.....
JJtr1954 is offline Find More Posts by JJtr1954
Old Jan 25, 2013, 01:21 PM
United States, CA, Thousand Oaks
Joined Oct 2009
Ghana.
1ooo0aks is offline Find More Posts by 1ooo0aks
Old Jan 25, 2013, 02:57 PM
Joined Dec 2012
Ok so I flashed my 9x to er9x. It works but haven't flown it. Just hate that I am having issues with setting the 3 pos to go to manual mode. I have gps-atti-failsafe and I cant get it away from the failsafe. AARRGGHH! I would hate to think that I would be flying through trees or a building or under a flock of nearly extinct birds and I accidentally hit the switch al the way down and take out the last 3 birds of that species on the planet...whoa is me! lol
Old Jan 25, 2013, 03:06 PM
The Devil Is In The Details...
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Switch Centering
Here's what you do with a Spektrum/Jr or a Futaba transmitter:
I can't speak for one like yours...
On the 3pos switch Atti is center with GPS and Manual being at the ends.
Use subtrim for your switch channel to get Atti in the center.
It IS permissible to use subtrims on switches with Naza!
Then use travel adjustment to set the endpoints to GPS and Manual.
Do this while connected to Assistant and you can visibly see the correctness of your adjustments.
After losing Failsafe on the 3pos switch, you'll need to investigate a mix on another switch to force the U channel into Failsafe.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 25, 2013, 03:47 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
You don't need a GPS to get a soft NAZA controlled landing in the event of signal failure. All you miss without the GPS is the "return to home" feature.
Programming your individual aileron, rudder and throttle channels and circumventing the NAZA doesn't seem very sensible to me.
When my FM receiver (big mistake) lost signal at 100 feet out and 50 feet high and no failsafe available on the rX and none set on Naza the machine basically flew away at a pretty decent clip, maintaining altitude, till it ran into some trees about 400 feet away. If the trees hadn't been there it probably would have flown till the batteries wore out.
u2builder is offline Find More Posts by u2builder
Old Jan 25, 2013, 04:38 PM
Olivier_C's Avatar
Joined Dec 2004
In order, from the safest to the less, I'd say :
Naza + GPS + Good TX/RX + RTH failsafe
Naza + GPS + RTH failsafe
Naza + Receiver with failsafe + Auto-landing
Naza + Receiver with no failsafe + A good bike or running shoes, and good cardio
Old Jan 25, 2013, 05:04 PM
Joined Jan 2007
RX location on DJI 550
You all have convinced me to upgrade to AR8000 so I have fail safe.
On a 550 where is best place to mount RX and remote.
I am thinking RX next to Naza and remote on bottom side?
Tim
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 18177 Today 03:15 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
