Old Jan 24, 2013, 11:38 AM
helifreak592 is offline
Find More Posts by helifreak592
United States, FL, Hollywood
Joined Nov 2010
Originally Posted by T J Gilbert View Post
I'm afraid if you start yet another thread, no one will bother to post on it.
You're better off searching (and posting) here for help.
I put "DX7 setup" into the search blank and turned up lots of information.
There might not be a "How To" that tells you everything, but you can piece together what you need from several posts...
To be successful here, you need to learn to use the search function.
FWIW, mauromassari uses an DX7 I believe.
PM him if you have specific questions.
He's a fellow helper here.
Do your share of the work now, we won't spoon feed you...
i thought this tread is about helping people and not embarrassing people , i ask for help , if nobody can well don't help , they is no where on the net about
Spectrum DX7S and naza wiring Using A orange receiver and as i said i am new ,
helifreak592 is offline Find More Posts by helifreak592
Old Jan 24, 2013, 12:30 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Orange Receiver
No one is trying to embarrass you.
I was only explaining that you need to search and learn.
I can't learn for you, but I will search...
1. The Orange Receiver is a Spektrum knock-off.
http://www.hobbyking.com/hobbyking/s...Sat_Port_.html
So treat it like a Spektrum 6 channel and follow the Naza Manual for channel assignments.
2. Once you get the Naza and the Orange Receiver (and your airframe) setup, follow this video.
DJI Naza Assistant Set Up on DX7 and F450 (12 min 19 sec)
The searching I did took less than 2 minutes.
If that doesn't embarrass you, well.....
T J Gilbert is offline Find More Posts by T J Gilbert
Old Jan 24, 2013, 12:31 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
He wasn't trying to embarrass you, just helping you to help yourself. You aren't the first person that has been new, not the first person that has asked about the DX7, and not the first person to use a orange RX. That means most of the topics have been covered before (most a few dozen times) and the search function is MUCH faster than typing out a long question then waiting for us to respond. What I like it when you are looking for the answer you will find other fun stuff you didnt know about buried in the forums.
I did exactly like TJ suggested... forum searched "DX7 Naza Setup" and this was second result
http://www.rcgroups.com/forums/showt...p#post22969819
MCrites is offline Find More Posts by MCrites
Old Jan 24, 2013, 12:33 PM
Joined Nov 2010
http://vimeo.com/44257191
i have that video already and some others that i have found on YOUTUBE
That is for a dx7 and not for the dx7s it has a big different and i was looking for a starting point NAZA and not NAZA with GPS
Old Jan 24, 2013, 12:40 PM
Empire Support
Joined Feb 2009
Search!
http://lmgtfy.com/?q=DX7+vs+DX7S
There are probably some differences/improvements, but this search and your DX7s manual will settle them.
You need to know all about your transmitter.
If you have not read its manual, now's the time.
The Naza Manual explains setup w/o GPS.
Please read...
If you'll stop complaining and study, you'll learn that you can just skip the GPS parts...
Old Jan 24, 2013, 12:54 PM
Joined Nov 2010
Please read...
I already did that but it does not Have too much about Spectrum receiver
Old Jan 24, 2013, 12:58 PM
MCrites is offline
Joined Jan 2012
What exactly do you need to know about the receiver? Channel assignments will be exactly the same as the DX7 (like in the video). Now how you program them might be slightly different (more like the DX8 from what I understand) but it will get you all of the channel assignments.
From there just wire the channels on the RX to the corresponding spots on Naza per the Naza manual.
Old Jan 24, 2013, 01:01 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Carefull now! you dont want to upset MCrites !
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 24, 2013, 01:03 PM
MCrites is offline
Joined Jan 2012
I don't get upset, just hunting for clear specific questions versus "I need a step-by-step of how to setup everything so I don't have to learn this new stuff".
Old Jan 24, 2013, 01:09 PM
Empire Support
Joined Feb 2009
RC Receivers
You can probably look at the Spektrum Information sheet for a 6ch receiver.
It won't say much because there's not much to tell.
A receiver is not very complex compared to the transmitter.
The "brains" of the organism rest in the transmitter.
Just pay attention to the channel/plug assignments on the receiver label.
The Orange 6Ch Receiver probably does not have a preset failsafe feature because none of the Spektrum 6ch receivers do (kallend & dedfish, correct me here if I'm wrong).
You will be fine with a 6ch receiver and no GPS.
To enjoy all of the Naza + GPS features, you need 7ch and preset failsafe.
Preset failsafe allows the Naza to go into failsafe mode when trans/rec communication is lost.
Invest some time and study up!
Good luck.
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
New here also and DX7 AR600 setup.
I have all set up except IOC. On my screen the IOC is grayed out and I can not change. I would like to use X2 inpit connected to 2 position gear switch. Also I see X2 change in TX calibration screen but not for IOC screen. In auto pilot all the gains are set to INH not X2 so I do not see reason for X2 not working for IOC.
Tim
w4yn is offline Find More Posts by w4yn
Old Jan 24, 2013, 01:11 PM
MCrites is offline
Joined Jan 2012
Tim
Do you have GPS and is it plugged into the Naza? Can you put the flight mode in GPS?
Old Jan 24, 2013, 01:18 PM
Empire Support
Joined Feb 2009
Autopilot Screen
Tim
In Naza Assistant, are you saying that on the Autopilot screen, IOC is grayed out?
Have you connected the GPS?
Have you chosen an Enhanced Failsafe Method?
I think you need to do these things for the IOC to become selectable...
Old Jan 24, 2013, 01:20 PM
Joined Nov 2010
I 'm not trying to upset nobody , i am new , just trying to get some help , every body have to start some where , nobody does learn by them self in this world ,
Old Jan 24, 2013, 01:25 PM
Empire Support
Joined Feb 2009
Learn
No one is upset.
We'd quit answering your posts if that was the case.
Actually, learning happens when you accept teaching.
And many things are self-taught.
Many of us accept our own teaching best.
Learning is something you do.
Someone else can't learn for you.
We are busting our butts teaching.
Help us help you...
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 11:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
