Old Jan 14, 2013, 01:14 PM
lakis21 is offline
Find More Posts by lakis21
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Originally Posted by mark_q View Post
If you weren't around a few pages ago (this thread moves fast!) I posted some bench testing results and included the 10" version of the GF woody. You can see my wiki pages here:
http://itsqv.homeserver.com/wiki/ind...%22_Quad_Props
and
Cheers!
Hi Mark!
Thanks for your reply!
I have seen you tests! And they are very important for all of us. But I don't if any of those Carbon propellers are good and if the are better that graupners e-prop.. In your test there aren't any propellers of the carbons from GLB or rctimer.
Thank you once again!!! Which one are you prefer from your test?
Regards from Greece!
lakis21 is offline Find More Posts by lakis21
Old Jan 14, 2013, 01:20 PM
Av8Chuck is online now
Find More Posts by Av8Chuck
Av8Chuck's Avatar
USA, CA, Thousand Oaks
Joined Feb 2010
and
Cheers!
Thanks Mark.
I have seen that chart before, quite helpful and it looks like the wood props do fairly well. I guess I should also be a bit more specific with my questions.
Although efficiency and thrust are important, flight characteristics are as important, if not more, for me. How difficult are they to balance? How smooth and quite are they, etc..
I only fly multi's for aerial video so a hex that flies really smooth for five minutes is a lot more interesting to me than one that is not nearly as smooth but flies for 10 minutes.
So I'd like to hear anyone experiences at using these, or other wooden props, for AP.
Av8Chuck is online now Find More Posts by Av8Chuck
Old Jan 14, 2013, 01:39 PM
Av8Chuck's Avatar
Joined Feb 2010
I would add to this that because DJI calls this their "Proffessional" control system you would likely get a much higher level of service from them. It probably uses higher quality components and has undergone more burn-in testing to prove it is worthy prior to testing as well. As TJ says it offers many more features as well however many of these features are available in other controllers for much less money (now) and as GW says there is a bit more technical knowledge needed. (I think that's what he said?!)
And, yes, Naza IS a bargain!
I always try to stay out of this debate, so to speak, but a complaint that I have expressed to DJI is that as this industry gets more users it becomes increasingly important that they sort out any issues with the NAZA like light sensitivity and inconsistencies with the manual that lead to prolonged aggravation.
I would buy a Wookong-M at tomorrow if I thought the customer support and quality of the product was dependable, but my experience with the NAZA actually discourages me from making the upgrade.
There are things that I really like about the NAZA but I don't trust it yet, so I certainly don't believe that the Wookong-M is more dependable and worth the additional expense. Unfortunately for DJI I think the NAZA is a great sales tool for the Hoverfly Pro.
Although I have a Hoverfly Pro I'm still holding out hope that DJI will get it together. Not that this opinion means much to them, the NAZA is a great value and I'm sure they're selling a ton of them.
Old Jan 14, 2013, 01:54 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Originally Posted by alwaysconfused View Post
Im not interested in getting one but why is the wookong so much more expensive
Apart from the things already mentioned ... it supports a bigger range of frame type (octos etc.), you can manually edit the motor mixers IIRC, failsafe and battery protection are more sophisticated (you can have RTH on low voltage, set the return altitude), it handles loss of a motor with flat hexa and octo. Probably other stuff. The manual is on the DJI website.
Bill Glover is offline Find More Posts by Bill Glover
Old Jan 14, 2013, 01:58 PM
Olivier_C is offline
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Originally Posted by T J Gilbert View Post
Be careful with the props restrained and motors energized.
It only takes a few seconds to burn out an ESC or start a battery fire.
Agreed, fully, but I made the counts, and between few euros of hardware, and my health, or moreover my kids health (got 2 boys, they like to be around my toys when its live), it's an easy choice
About this Wookong, I don't know the specs inside, but hell it so looks like a Naza with a better software... same as most of electronics are today... same core, enhanced software, sell these few extras features 5 times more...
Or more likely, the other way, the Naza is a castrated Wookong.
As sample, the RTH mode, somewhere in Naza's code the value "20 meters" for "altitude climb in RTH" is written, same as in the Wookong. I mean, the altitude it climbs, the speed its going back home, how long it will wait, how fast it will land, etc, its already there, it's just about drawing the line who can change it or not...
Anyway, this Naza is definately a bargain :]
Olivier_C is offline Find More Posts by Olivier_C
Old Jan 14, 2013, 03:11 PM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Props Off...
Just remove the props.
It's easy...
T J Gilbert is online now Find More Posts by T J Gilbert
Old Jan 14, 2013, 03:38 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
It's easy...
Unless you balance your motors dynamically (with props on).
MCrites is offline Find More Posts by MCrites
Old Jan 14, 2013, 03:46 PM
Empire Support
Joined Feb 2009
Index The Prop...
I have my props numbered.
It would be a simple matter to mark the prop hub and the top of the motor in a manner to ensure things get back together as before.
Sort of like the tire guy does when he fixes a flat...
I presently have not gone to that degree of balancing, but might.
Old Jan 14, 2013, 03:52 PM
MCrites is offline
Joined Jan 2012
Yeah but when the marker ink dies then my props will be out of balance! [/sarcasm]
Old Jan 14, 2013, 03:53 PM
Joined Nov 2000
Wookong hardware is different ... separate units for flight control and sensors (with Naza it's all in one box). GPS/compass unit looks similar but is not the same. Wookong only works down to -5C (-10C for Naza), but has slightly better position hold accuracy (both vertical & horizontal). Naza has a bigger tilt angle limit (45 degrees vs 35 for the Wookong).
Old Jan 14, 2013, 04:29 PM
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
[/brainexploding]
AARRGGHH! lol maybe buying a premade system thats been bound to a Tx would be best lol.
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jan 14, 2013, 04:39 PM
Joined Dec 2012
So I have a question... is the spektum Tx and good? I see so many people using them and how awesome it is. Just wondering if I should upgrade and send my current Tx and Rx to my plane.
Old Jan 14, 2013, 05:13 PM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
I have a DX8 and AR8000 and have never had a problem
jasper7821 is offline Find More Posts by jasper7821
Old Jan 14, 2013, 05:20 PM
rmorhan is online now
Find More Posts by rmorhan
rmorhan's Avatar
wasaga beach ont canada
Joined Jan 2004
kallend, the newer ( marked bat-data) spektrum ar7000 rxs have the preset failsafe option as well. these are now replaced with the ar7010 but the newer 7000s work fine. .might want to add those to your list...rob m
rmorhan is online now Find More Posts by rmorhan
Old Jan 14, 2013, 05:26 PM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Well I just got a email from Robert at UAV products my Naza was bad he put me a new one in the mail today good customer service makes this hobby much more enjoyable
tech69x is offline Find More Posts by tech69x
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
