Old Jan 14, 2013, 02:06 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Originally Posted by alwaysconfused View Post
From the video it flies nicely, GG
My 2 cents about safety, I made a transport box that also doubles as a safety box, every time I'm doing stuff on the quad with the LiPo plugged in, in the software config, etc, it's in the box, it will prevent any unwanted rotation. And even for normal flying at the field I plug the battery when it's in there. Few days ago my quad made a light contact on my roof, luckily it did not go down (the quad, not the roof ;] ), but that made a small dent in a shingle, the concrete kind, so I have absolutely NO DOUBT it can cut a finger clean.
Also, IMHO a neck strap is a real plus about safety, can handle things with both hands if needed, and still have the TX within reach...
Olivier_C is online now Find More Posts by Olivier_C
Old Jan 14, 2013, 02:50 AM
Av8Chuck is offline
Find More Posts by Av8Chuck
Av8Chuck's Avatar
USA, CA, Thousand Oaks
Joined Feb 2010
Anyone using these props?
http://www.rcdude.com/servlet/the-24...tirotor/Detail
Av8Chuck is offline Find More Posts by Av8Chuck
Old Jan 14, 2013, 05:22 AM
lakis21 is offline
Find More Posts by lakis21
lakis21's Avatar
Greece, Makedonia Thraki, Nikiti
Joined Dec 2006
Originally Posted by Av8Chuck View Post
Or anyone tried any of these on a f550? (compering to Graupner 9x5)
http://www.goodluckbuy.com/9047-9x4-...r-2-pair-.html
or
http://www.rctimer.com/index.php?gOo...4&productname=
or this
Stock motors+ Dji Esc+ GPS + Jakub Gimbal + go pro h2 + 4s 5000
Thanks in advance
lakis21 is offline Find More Posts by lakis21
Old Jan 14, 2013, 05:48 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by T J Gilbert View Post
Unless you're expecting that damn thing to fly itself, it appears your problems are over!
That grin on your faced when you goosed it also makes me think that all of your original thoughts of hara-kiri are gone.
I'm sure if you still want to sell it, my friend Goldsworthy will make you an offer...
I will bid $200.00 firm!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Jan 14, 2013, 07:31 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Overheating
Be careful with the props restrained and motors energized.
It only takes a few seconds to burn out an ESC or start a battery fire.
T J Gilbert is online now Find More Posts by T J Gilbert
Last edited by T J Gilbert; Jan 14, 2013 at 07:32 AM. Reason: Overheating & Short Circuits
Old Jan 14, 2013, 09:16 AM
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
Thats a very cool transport and shop work station/carry box
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jan 14, 2013, 09:19 AM
Joined Dec 2012
lol if I were selling it even at the height of my frustration I that would get you the FC and a piece of candy...lol
Old Jan 14, 2013, 09:23 AM
Joined Dec 2012
Im not interested in getting one but why is the wookong so much more expensive and what can it do that other mid ($50-$400) systems that come with GPS do?
Old Jan 14, 2013, 09:26 AM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
or
or this
Thanks in advance
If you weren't around a few pages ago (this thread moves fast!) I posted some bench testing results and included the 10" version of the GF woody. You can see my wiki pages here:
http://itsqv.homeserver.com/wiki/ind...%22_Quad_Props
and
Cheers!
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Jan 14, 2013, 09:28 AM
Joined Mar 2012
Originally Posted by always confused View Post
I'm not interested in getting one but why is the wookong so much more expensive and what can it do that other mid ($50-$400) systems that come with GPS do?
TYATS a EASY question to answer even for me! its because all the work has already been done and all you have to do is put the quad together and fly!. The other method requires months of programing and code writing that even Einstein would have trouble with!
Old Jan 14, 2013, 09:33 AM
Empire Support
Joined Feb 2009
Wk
If you research it, you'll see that it's for larger airframes.
(Naza has flown ~ 100cm).
It offers way-point navigation.
There are a few more adjustment parameters available.
(OSD, FC off center, better gimbal to name some off the top of my head.)
Suggested for commercial use.
Etc.
Bottom line = Naza is quite a bargain...
Old Jan 14, 2013, 10:30 AM
BerndM is offline
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
Yes, I have a set and these are currently my mounted props on my F450 quad.
I was using the Graupner 10x5 e props which are great, but I've always liked the look of the wood ones.
I seem to be getting better flight times with the wood probably due to their wider paddle blades. They also seem quieter to me.
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x4 Gemfan Woodies Props / GoPro HD2
Fat Shark Predator V2 FPV
AUW 3S-4000mah = 1585g
Spektrum TX DX-7 (original) / Spektrum RX AR6200
BerndM is offline Find More Posts by BerndM
Old Jan 14, 2013, 01:05 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Etc.
I would add to this that because DJI calls this their "Proffessional" control system you would likely get a much higher level of service from them. It probably uses higher quality components and has undergone more burn-in testing to prove it is worthy prior to testing as well. As TJ says it offers many more features as well however many of these features are available in other controllers for much less money (now) and as GW says there is a bit more technical knowledge needed. (I think that's what he said?!)
And, yes, Naza IS a bargain!
Old Jan 14, 2013, 01:06 PM
Joined Dec 2012
Etc.
So then when I get to the point of actually making money off of using this thing for a platform for photo and video it might eventually be a good idea? Sounds reasonable
Old Jan 14, 2013, 01:07 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
If you are in the US, it may be a while as it is illegal to do so at this time.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
