Old Jan 12, 2013, 12:31 AM
1ooo0aks is offline
Find More Posts by 1ooo0aks
United States, CA, Thousand Oaks
Joined Oct 2009
Originally Posted by MTHead4u View Post
NO CALIBRATION needed for DJI ESC. Hence why you didn't see any info for doing so..
They are already setup for the Naza. That's only if you switch to different ESC (SimonK).
Sorry about bringing more confusion. You can skip the calibration. The next step should be checking if stick movements do what they supposed to do. You do not necessarily need to fly, but check if moving the aileron stick to right tilts the hex to the right and so on. Use manual mode for that. Watch the blades!
1ooo0aks is offline Find More Posts by 1ooo0aks
Old Jan 12, 2013, 12:33 AM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
Update to my Naza #3.
Issues were:
IMU locked at Y = -16.0
Motors will not run after CSC in ATTi/GPS
GPS will not calibrate in vertical position
No issues at all with the replacement Naza (#4).
Not 100% sure what about #3 was bad to cause all those issues. It connected and programmed fine.
All I got to say is the distributors that sell them REALLY stand behind them!!
Time for the Dome and some Props!!
MTHead4u is offline Find More Posts by MTHead4u
Old Jan 12, 2013, 12:48 AM
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
Ok so a question pertaining to props.. Mine came with 8 and 10 inch props. What is the better of the two for nice controlled stable flight on a F550?
Which one will give longer flights and such
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jan 12, 2013, 01:03 AM
Joined Dec 2012
So far it does all the correctly..its still the lazy throttle and the runaway hex that are driving me bonkers.
I am wondering if there is a calibration I am missing on the gyros or any other sensor.
Old Jan 12, 2013, 01:09 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Originally Posted by cquian View Post
Exactly!
I have 6 of them but his definition of cheap probably doesn't match what it would take for them to depart my possession
Well cheaper than retail lol. Also are they new or used?
flohio117 is offline Find More Posts by flohio117
Old Jan 12, 2013, 01:29 AM
1ooo0aks is offline
Joined Oct 2009
Again: which mode, atti or manual? In atti, throttle in the middle means 'keep height', more stick means higher less stick go lower. Depending on the atti gain it could be sluggish, but not in manual. Post a screenshot of the autopilot screen.
Old Jan 12, 2013, 01:40 AM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
use the 8 inch props if you're running 4s, 10 inch if you're running 3s. FYI, the 8 inch DJI props tend to explode, the 10 inch props are solid, even if unbalanced somewhat
edit: on the 10" props you should get 11 minute hover on a 5000 3s battery
CrashAffinity is offline Find More Posts by CrashAffinity
Old Jan 12, 2013, 01:46 AM
Joined Dec 2012
I need to add the props to see what it does. everything seems to be ticking along nicely
Old Jan 12, 2013, 01:59 AM
dedfish is offline
Find More Posts by dedfish
United States, FL, Tampa
Joined Apr 2012
How about a picture of the hex? How is the Naza mounted and where?
dedfish is offline Find More Posts by dedfish
Old Jan 12, 2013, 02:07 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Are the X1/X2 gain channels in use ?
If plugged and not properlly setup, maybe there's an extreme gain setting messing things ?
Some good photos of the machine may indeed help.
Olivier_C is online now Find More Posts by Olivier_C
Old Jan 12, 2013, 02:14 AM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Looking good!
Btw, are you flying Accro or heli?
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Jan 12, 2013, 02:17 AM
Joined Dec 2012
If plugged and not properly setup, maybe there's an extreme gain setting messing things ?
The plugs are in but not in use. Since they are a pain to reach I set them in but wont need them until the GPS is used.
Old Jan 12, 2013, 02:29 AM
Joined Dec 2012
some photos of the beast
yes that is a little bit of dust. It's cleaned out now but I live in the country and to get to my house includes turning onto the dirt road..lol
Old Jan 12, 2013, 02:32 AM
Joined Dec 2012
Originally Posted by mark_q View Post
Looking good!
I am on Accro (plane) mode.
Old Jan 12, 2013, 02:46 AM
Joined Dec 2012
Just took it out and ran it again to check some settings. it is still "bunny Hopping" on atti and drifting all over the place. Going to bed.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
