Old Jan 08, 2013, 10:22 AM
Chewwy00 is offline
Find More Posts by Chewwy00
Chewwy00's Avatar
Joined Aug 2012
Originally Posted by T J Gilbert View Post
When you say that after you do the F1/F2 reset something asks you to recycle the power of the Naza, how are you seeing that if you can't connect to the Assistant?
Was the solder connection to the VU broken or melted?
Broken = impact strike
Melted = current overload
Either way, I think that the USB connection on your VU may be damaged.
FWIW, a VU is cheap.
Hope my "speculations" help some...
Thanks for the help.
The soldering that connect the VU to the power distribution board was broken (not melted). It was weak before the crash (should have been more carefull on that one)!
When I do the F1/F2 trick the USB connection is Ok and I get the steady green light. Then after the update Naza assistant asks me to recycle the power on the NAZA. When I do it, I'm in the same process of having the green LED for 2 secs then normal start sequence...
Chewwy00 is offline Find More Posts by Chewwy00
Old Jan 08, 2013, 10:25 AM
Chewwy00 is offline
Chewwy00's Avatar
Joined Aug 2012
Originally Posted by Cervanchez View Post
Also, you can try a different startup sequence. I believe I always plug the naza in to the flight batt first, wait for the startup sequence LEDs, then connect the USB, then start the assistant sw. I know others have various sequences, but that has a lways worked for me. But first thought would be that VU connection like TJ says. When you say the soldering was broken, do you mean your soldering to the power source? Or internal soldering? If it was your soldering, I assume you repaired that and have a good connection there. In that case it may be the internal connection.
Soldering to the PWR source. I repaired it and now I'm having these USB connection issues. Tried to start my TX, power ON the NAZA, then connect the USB cable and there, nothing happens, it just goes through the normal startup seqeunce with the different color LED.
Old Jan 08, 2013, 10:26 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Connection Sequence
From Cervanchez: "I believe I always plug the naza in to the flight batt first, wait for the startup sequence LEDs, then connect the USB, then start the assistant sw."
That is the sequence I use, and a different one might be worth trying.
I've even done it with the Assistant already running on the PC.
I think TahoeEd posted back when I was trying to fix my broken in the box Naza that the sequence is not supposed to matter.
Just "speculating"...
T J Gilbert is online now Find More Posts by T J Gilbert
Old Jan 08, 2013, 10:39 AM
moti is offline
Find More Posts by moti
israel
Joined Jun 2003
Maybe I put my question in the wrong thread so i ask it again
Thanks for your help
I flew the naza many hours with no problem and it really fly great I made failsafe with mixer switch on Futaba 9C and it also works great. I never try to check the failsafe by close the Tx and I don't intend to do it. my question is when I make the failsafe with the switch orange led blink that is OK. but when I close the Tx I stay on the last function, so what will happened if I loose connection during flight, should the naza take command and bring it back home or.....who knows.
Have a nice day
Moti
moti is offline Find More Posts by moti
Old Jan 08, 2013, 10:53 AM
Empire Support
Joined Feb 2009
Answered...
Have a nice day
Moti
I answered your question over on the GPS thread...
Old Jan 08, 2013, 01:28 PM
kallend is online now
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
Originally Posted by MCrites View Post
I will fully refund the money you spent here. Have a good day and I hope you find help elsewhere.
Well, you can't say fairer than that!
kallend is online now Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Jan 08, 2013, 01:36 PM
kallend's Avatar
Joined Sep 2004
I do it in the exact reverse order from you, with no problems.
Old Jan 08, 2013, 01:48 PM
Mike Freas is online now
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
This past weekend while flying FPV with my F450 I experienced an odd reaction to control inputs. I was at the extreme end of my A9 radio range. I had turned the 450 around facing the launch point and pushed the control stick forward to start heading back to me but the quad went backwards. I tried several times to get it to go the right direction but it did the same thing each time. I then flipped the switch for the “smart orientation” and it flew correctly.
This isn’t the first time this has happened and I assume the radio Rx is losing packets and going in and out of failsafe?
Mike Freas is online now Find More Posts by Mike Freas
Old Jan 08, 2013, 01:50 PM
Empire Support
Joined Feb 2009
Edge Of Range
Your conclusion about intermittent trans/rec communication sounds logical to me...
Is tightrope walking your other hobby?
Old Jan 08, 2013, 02:10 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I don't own any Bushmaster products... but Beretta, Winchester, Colt, Kel-Tec, S&W and Daisey have all received my money recently.
Whoa, you must be "loaded for Bear". Prolly don't have bear in Texas though. Nope, only about 50 Black Bear in the whole state. Oh well, loaded for sompin anyway. LOL.
u2builder is online now Find More Posts by u2builder
Old Jan 08, 2013, 02:16 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
To continue MCrites' and TahoeEd's viewpoints...
We throw out read the manual and follow instructions as a "tried and true" thing that we choose to rely on.
I think we all agree that the Naza Manual is pretty accurate if you can understand it.
I think this really sums it up for some of our posters in response to RTFM. Not everyone totally understands it for one reason or another hence the posting of questions on the forums. Some people really aren't good reading technical (even basic) things yet are great hands on learners. Sometimes threads get way to long and the search function is really limited. I've only been flying multi rotors for a few years and am not a really technical person. I did however help put together a manual online with another person to help new people setup and fly a particular Quad that was being sold a couple years ago. We did this on our own to help others when the seller didn't respond often for help. Then came the talk of Naza and I was in touch with them weekly (china) not US dealers. Finally I backed off from posting for my own reasons.
What I'm getting at is that I too read the manual in the beginning and some of the stuff didn't gel in my brain. I'm just your common working non college person trying to enjoy a hobby. Financially I can't afford to experiment with too systems but I will jump in an try what I can and share. I go against the rules a lot (how you should build etc.) but geesh sometimes it just works. So again there are many in this hobby that aren't technically orientated. They may need a little help. How many want to post they RTFM but can't understand it?? That shouldn't mean they can't have a quad/hexa etc. I think you guys are great for helping on here. We're dealing with a whole lot of different people with different abilities. It doesn't mean they're lazy or stupid.
seadog1967 is offline Find More Posts by seadog1967
Old Jan 08, 2013, 02:20 PM
seadog1967's Avatar
Joined Nov 2010
He's ready for zombie chipmunks. You know how bad they can be up in NH. hehe
Old Jan 08, 2013, 02:29 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I KNEW IT WAS TRUE! Damn yankee zombie chipmunks gonna take over my land! BRB, gonna go make sure my tip wires are all still set....
MCrites is offline Find More Posts by MCrites
Old Jan 08, 2013, 04:07 PM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
Yeah I pushed it a bit this weekend. New personal goal of one mile FPV.
Old Jan 08, 2013, 04:10 PM
Empire Support
Joined Feb 2009
NAS Control by FAA
I'm through passing judgement on what you guys are doing.
Try to be careful, and enjoy it while you can...
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
