Old Dec 19, 2012, 11:02 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Originally Posted by Bill Glover View Post
We could start with RTFM
MCrites is offline Find More Posts by MCrites
Old Dec 19, 2012, 02:13 PM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
Originally Posted by T J Gilbert View Post
Page 14 relates pulse width to throttle position with a formula based on the pulse width output of your particular transmitter.
I don't think it helps your problem.
The irregular start-up seems to just be an annoyance.
(As previously posted by several.)
Always keep your trims at zero.
The reasons why are back in the threads for your searching.
There's some stuff about trims on my blog...
Thanks TJ ...do you mean zero or middle?
jetstuff is offline Find More Posts by jetstuff
Old Dec 19, 2012, 03:13 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Zero Trim
Technically, zero trim is middle on all your stick's trim levers.
Even Throttle is zero = middle on my JR9303H...
Theoretically, you need negative throttle (provided by trim) to make a gas or glow engine cut off. There's no need for that with electric stuff. So, if you choose for zero throttle trim to be all the way down, and you calibrate it that way in the Assistant, that's where it will be. Just remember to leave it where you calibrate it to be zero.
T J Gilbert is offline Find More Posts by T J Gilbert
Last edited by T J Gilbert; Dec 19, 2012 at 04:02 PM. Reason: Explanation & risking saying too much which could = confusion
Old Dec 19, 2012, 08:49 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Sooo, I've been wanting to do this since day one of flying the naza, and I'm finally getting around to doing it but I don't want to spend a lot of time on this if its already been done:
The plan is, tie the quad up on strings, mount an accelerometer, and log the accelerometer voltage on my Eagle Tree data logger for a range of gain settings, for each flying mode, with a step input (full stick to neutral or vise versa) so we can finally quantitatively define the gain effects. I could overlay all the graphs to get a good look at the relative effects.
I did step one tonight and the results were very enlightening. I tied up my quad so that it rotates about the roll axis. I programmed the basic roll gains to a slider on my tx and put the attitude gains on a second slider. I spooled up in attitude mode and I found that if the basic gains were too low, it would drift from level, raise it and it would level out. Previously I could never notice the effects of changing the basic gains. The effect of varying the attitude gains were similar, meaning if it was too low it would drift, but the attitude gains had a larger affect on how quickly the quad responded to stick inputs. So, this corresponds with TJ and TE's explanations, but being an engineer I'm not satisfied with qualitative observations. I need data.
So, I have the accelerometer on the way so I could probably knock this out this coming week as I'm on vac, but please let me know if anyone knows of a similar study already done, because its a bit of a project.
Cervanchez is offline Find More Posts by Cervanchez
Old Dec 19, 2012, 11:55 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I got in a flight tonight.
FPV Japan stopped recording, so all I have is this footage.
I was testing a low output IR LED.
I've got some High Output IR LED's on the way.
FPV Hexacopter Night Flight (3 min 26 sec)
m_beeson is offline Find More Posts by m_beeson
Old Dec 20, 2012, 05:26 AM
jetstuff is offline
Joined Jun 2004
What are you hoping to illuminate with your infrared LED's?
Old Dec 20, 2012, 06:55 AM
Empire Support
Joined Feb 2009
@Cervanchez
I've not seen any test data on gains like you are proposing to collect.
Thanks for making the effort.
Since you're after hard data, be sure to document your findings.
I'd love to see them added to the beginning of the thread, and I'll gladly post them in my blog...
Old Dec 20, 2012, 07:48 AM
Cervanchez's Avatar
Joined Dec 2011
Ok then, that's the plan, video and graphs...
Old Dec 20, 2012, 07:52 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
New Quad Frame Landing Gear
Here are some pics of the new "short" Quadframe landing gear. I replaced my outboard "legs" with this gear. I like it much better as the legs tend to catch on the grass and make takeoffs a bit more shaky.
The new gear is nice and very stable and the CG is nice and low. The GPS coordinants are 0,0,0. There are no legs in the way of the prop blast or the camera.
I like running two 2200 mah batteries in parallel, and like them mounted on the legs as the wires are out of the way of the props.
It is available here: http://quadframe.com/collections/qua...e-landing-legs
Not inexpensive, but very nicely made.
I have the much taller 155mm version on my hex and it has also been great.
u2builder is offline Find More Posts by u2builder
Old Dec 20, 2012, 08:04 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Very nice! Are those the legs you were telling me about? What are you using for anti-jello for the GoPro?
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Dec 20, 2012, 08:28 AM
Empire Support
Joined Feb 2009
Wow!
You are THE MAN!
Old Dec 20, 2012, 08:32 AM
Empire Support
Joined Feb 2009
Me Too...
I like it too!
You've done a great job of getting a bowl of spaghetti under control...
Old Dec 20, 2012, 08:42 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Yes Mike, these are the new legs. Took a while to get here from Poland. I don't know if they are stocked in the US yet; weren't when I ordered them.
I haven't flow the GoPro yet, but it is mounted the same exact way as before, under the front lip. I tried various methods of isolation and found that NO isolation gave me the best picture. I think the GoPro can get some type of secondary harmonic when on its own isolation. I really wasn't getting any Jello with the rigid mount.
Also at one point I put little foam balls on the bottom of my old legs. This made a lot of Jello. I think that the propwash hitting the balls on the legs created the problem. I took the balls off the legs and it went away. By this logic I think no legs are the brest option.
I think a nice stable platform with smooth props such as the Graups and low CG should not have a lot of vibration. I also shoot 720 x 60 fps which probably helps.
BTW, I mounted the new gear a bit differently than the designer intended, and I think better. The designer intended for it to attach to those slots in the lips of the quad bottom plate. I put about five thin washers between the black frame and the aluminum angle that attaches to it, to located the aluminum a few mm closer to the center of the frame and allow the aluminum angle to be attached by two of the same bolts that hold the bottom frame of the quad to the quad arms. This takes stress off of the those lips and gives a very solid mounting in my opinion.
Old Dec 20, 2012, 09:51 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
The camera is IR sensitive, so I am hoping to iluminate the ground and objects in front of me, with the IR.
Old Dec 20, 2012, 10:00 AM
Empire Support
Joined Feb 2009
Ir led
I didn't know that they had IR LEDs that could shine that far.
If a conventional LED is any indication, the brightest I've found shines about 15' to 20'.
I wonder if a reflector might help?
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20278 Jul 17, 2016 12:38 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
