Old Dec 18, 2012, 05:45 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
I left mine in...
and I've left them in on my hex, too..(skywalker 20A escs)
havent had an issue...(that I can tell, anyway..)
(maybe Im just lucky..)
rcroadtrain is offline Find More Posts by rcroadtrain
Old Dec 18, 2012, 06:06 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
BECs
Originally Posted by rcroadtrain View Post
I left mine in...
You really never know.
Sometimes BECs play well together, sometimes they don't.
There have been many pages written about this.
From what I've seen, here's the bottom line:
If the BECs are not supplying identical voltages, it's like two batteries of slightly different voltage being in parallel.
An "average" or "leveled" voltage results.
Since the BECs are actively adjusting and regulating their output voltages, a conflict ensues as each tries to adjust for the other.
This conflict causes overheating and potential damage to the BECs.
This sounds reasonable to me, so I disconnect all red wires but one when two or more BECs are in parallel.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Dec 18, 2012, 09:30 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Its not really about them supplying different voltages. They all supply the same voltage. A switching reg uses transistors, which are voltage controlled switches. They have an input, an output, and a gate, which controls the switch. When the voltage rises above a certain threshold, the gate opens, and lets current flow, dropping the voltage, and this happens many times per sec. If that gate voltage is fluctuating, because of other BEC's in parallel, it will be switching even more than it has to as well as having to deal with current surges and peaks, which could cause it to burn up.
Most of the time the effects are probably unnoticeable, but in some cases its bad. So effectively, TJ is right.
Cervanchez is offline Find More Posts by Cervanchez
Last edited by Cervanchez; Dec 19, 2012 at 10:16 PM. Reason: clarification of gate voltage, had it backwards
Old Dec 18, 2012, 10:59 PM
Joined Feb 2012
this is probably why I havent had a problem, the BEC in the skywalker 20's is linear....
Old Dec 19, 2012, 12:20 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
You are correct.
Power the Naza ONLY through the VU.
Maybe the TBE can be used by other FC than Naza which should have one ESC connected ....
tritan is offline Find More Posts by tritan
Old Dec 19, 2012, 02:34 AM
jetstuff is offline
Find More Posts by jetstuff
United Kingdom, Norwich
Joined Jun 2004
I've been having my own fun and games getting a matched set of non DJI ESC's working..... can't understand why ESC's sold as 'multirotor' have a BEC anyway.....just pulling the red wire doesnt stop the regulator from working of course, switching or linear, so that just wastes power, and if it's a switching regulator, then that's four (at least) interference noise producing circuits whistling away as well.....
I cut the red wire where it exits the ESC to minimise 6 inches of 'aerial' radiating too......
The only use I can think of is using one (or two?) of the BEC to power the gimbal servos independant of the NAZA
http://s197.beta.photobucket.com/use...nny/story/6175
jetstuff is offline Find More Posts by jetstuff
Old Dec 19, 2012, 05:51 AM
jetstuff is offline
Joined Jun 2004
A quick qestion for you......has anyone deciphered and understood page 14 of the latest manual?? My new Axi's with RC Timers flashed ESC's won't start together unless I select high Motor Idle Speed setting....even then one of the motors doesn't run properly till nearly lift off throttle.
Also where do you all set the throttle trim position on your Tx when calibrating....low, middle or high??
THANKS!
Old Dec 19, 2012, 07:15 AM
Empire Support
Joined Feb 2009
What Are You Saying?
If I translate this correctly...
"Maybe the Toilet Bowl Effect can be used by other Flight Controllers than Naza which should have one Electronic Speed Controllers connected..."
Old Dec 19, 2012, 07:22 AM
Empire Support
Joined Feb 2009
THANKS!
Page 14 relates pulse width to throttle position with a formula based on the pulse width output of your particular transmitter.
I don't think it helps your problem.
The irregular start-up seems to just be an annoyance.
(As previously posted by several.)
Always keep your trims at zero.
The reasons why are back in the threads for your searching.
There's some stuff about trims on my blog...
Old Dec 19, 2012, 08:33 AM
tritan is offline
Joined Apr 2007
He, he ...!
Well, TBE can be confusing, To Be Expired ?
No, with TBE I was refering to the multi with that name - or similar name?
EDIT: should be TBS .........
Old Dec 19, 2012, 08:42 AM
Empire Support
Joined Feb 2009
Acronyms
He, he ...!
We throw out so many acronyms in our posts, it's a wonder newbies haven't asked for a dictionary...
Old Dec 19, 2012, 10:17 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
We could start with RTFM
Bill Glover is offline Find More Posts by Bill Glover
Old Dec 19, 2012, 10:21 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Huh?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Dec 19, 2012, 10:43 AM
Empire Support
Joined Feb 2009
Rtfm
You mean "Read The Fantastic Manual"?
Old Dec 19, 2012, 10:45 AM
Joined Mar 2012
http://www.youtube.com/watch?feature...&v=sZrgxHvNNUc
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
