Old Dec 16, 2012, 11:13 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
The DJI esc's don't need to be calibrated, right? I soldered everything last night, I guess I should take it apart and redo it.
Perhaps you can tether it and fly it and you will see what motor/esc is involved with the flip.
I have used bungee cords to hold it down fairly firmly, but allow enough elasticity to what what happens when you try different controls or in your case when you try an extended hover. If you have a Go Pro you could film it and then go frame by frame to try to find the failure.
u2builder is online now Find More Posts by u2builder
Old Dec 16, 2012, 11:21 AM
UDO999 is offline
Find More Posts by UDO999
UDO999's Avatar
United States, MN, Cottage Grove
Joined Jul 2010
I'm going to resolver everything. If it still does it I will get a vid with my gopro. Thanks for the help!
UDO999 is offline Find More Posts by UDO999
Old Dec 16, 2012, 11:22 AM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Calibration matches the ESC throttle end points to the TX so ALL ESC's need calibration.
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Dec 16, 2012, 11:49 AM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
Really? I've read that the DJI esc's don't need calibration.
Old Dec 16, 2012, 12:03 PM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Really? I've read that the DJI esc don't need calibration.
This is what I understand also!. I have lots of extra DJI ESCs and all that I have installed have been plug and play 100%
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Dec 16, 2012, 12:04 PM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
I bought several ESC's from RCDude (SimonK flashed) and had a similar issue. After taking them one by one and performing a Tx cal on them they worked fine and the problem was solved. Before that they all looked good through Assistant, but at least one of them was off.
bobthenuke is offline Find More Posts by bobthenuke
Old Dec 16, 2012, 12:17 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
After resoldering, same thing. Guess I need to get a video.
Old Dec 16, 2012, 12:48 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
My Project (1 min 17 sec)
Here's a YouTube link to what it does. Notice when I start pulsing the throttle it flips. Kinda hard to watch. Any ideas?
Old Dec 16, 2012, 01:01 PM
Mrtarango32 is offline
Find More Posts by Mrtarango32
Mrtarango32's Avatar
United States, CA, Glendora
Joined Oct 2012
Videos private
Mrtarango32 is offline Find More Posts by Mrtarango32
Old Dec 16, 2012, 01:14 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
Sorry, it's not private anymore. Thanks!
Old Dec 16, 2012, 01:22 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Have you checked your motor temps. I wonder if one is getting hot and seizing up?
I'd put it on some bungies and watch from up close; won't be as hard on it. I found a bad motor connection that way. Plus, once it starts doing it it may keep doing it if not interrupted by a crash. Just a thought.
Old Dec 16, 2012, 01:27 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I have found however I don't really need any if I really work on motor & prop balance.
+1. Actually my attempts at vibration isolation made it worse. I think the Go Pro can get an induced vibration of its own and the pad can amplify it. Of course my methods of isolation may have been at fault.
Old Dec 16, 2012, 01:28 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
OW!
It looks like the right front motor drops out. If you can afford the props, swap the ESC to the right rear and test again. If its the ESC you'll see it flip the other way then just replace it. (If you have some plastic sheeting, throw it over the snow and fly over this cause its softer!)
Also, I stand corrected, according to DJI there is no utility to calibrate these as they are matched at the factory to the Naza. This doesn't mean you don't have a bad one however...
Good luck!
Old Dec 16, 2012, 01:36 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
I have another esc, I'll give that a try first (with bungee cords).
Old Dec 16, 2012, 01:37 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
It can also be caused by the design of the frame as well. I got better at balancing because of the HT-FPV frame which has very flimsy, "vibration amplifying" arms and camera deck. Once I got the motors really well balanced (dynamically) and the props as well it smoothed out. I still had to stiffen the camera mount plate and glue the arm joints to get jello free video however. I have replaced it with a TBS Disco which has none of these problems (for me).
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
