Old Nov 28, 2012, 04:28 PM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Originally Posted by flohio117 View Post
Hey guys I have a question. When I am just hovering with my Y6 that has a Naza on it. If I yaw any direction one of my arms will lift up and make it spin at a wierd angle which causes it to drift alot. Why doesn't it just spin flat like my quad does or is this a characteristic of a Y6? Also are my yaw gain just to high or low?
Typically a Y6 will require a higher YAW gain than the rest of the gains.
MCrites is offline Find More Posts by MCrites
Old Nov 28, 2012, 04:34 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I don't like the extended landing gear that attaches to the arms as that just puts more stress on the mounting points. I know the arms are designed to be break-away but I prefer it mounted to the frame itself.
I have the extended legs on my quad and the plate mounted gear on my hex. The plate mounted center gear on the hex is a lot more "tippy" so it takes a bit more attention to land it on uneven ground.
On the quad the legs often catch in the grass and make takeoff a bit trickier and in even a small sideways "crash" the exended legs catch and usually break one of the DJI legs. It is very easy to land however.
I'd like to see some examples of good plate mounted landing gear that I could switch my quad to. Alternative, I might switch it over to a TBS Discovery to get rid of the legs completely.
u2builder is offline Find More Posts by u2builder
Old Nov 28, 2012, 04:44 PM
3D Flash Mob Member
mark_q's Avatar
United States, WA, Kent
Joined Sep 2003
Originally Posted by Mike_Then View Post
Love the setup! That's very cool. Glad to see someone else using heli skids for landing gear. I bolted on a set of T-Rex 500e skids and it works perfectly. I'm going to raise them with standoffs - much like what you have on yours - so I have ground clearance for a longer antenna as well as the GoPro. I've been brainstorming on how to mount the GoPro and where to put it. Not sure what I'm going to do quite yet but I'm sure inspiration will strike once I get to the shop.
I've used the Align skids and they are great. I needed something taller though so I bought the LG parts for the HK H.A.L. Quad:
http://www.hobbyking.com/hobbyking/s...ame_585mm.html
Go to the parts section and you can get them all for $15. These Landing gear are strong enough for what I need and really easy to modify for any quad and any height. Check it out
mark_q is online now Find More Posts by mark_q
Latest blog entry: TESTING! 9x6 Props for Penguin
Old Nov 28, 2012, 05:01 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thanks, but of course HK is out of stock of most of the items, as usual. Looks like a nice light setup though.
Old Nov 28, 2012, 09:05 PM
Birdman4498's Avatar
Canada, ON, Ajax
Joined Jul 2011
I have this style leg on my X650 and it comes in a mounting system that is made to adapt to other frames, I put the adapted version on my X650 Spyder. I didn't need/want the extra height so I just cut them down. They work great in both applications and I would recomend Jeff from RCHeliCanada.com.
http://www.rchelicanada.com/rc-multi...prod_1841.html
Birdman4498 is offline Find More Posts by Birdman4498
Old Nov 28, 2012, 11:04 PM
dc9guy's Avatar
Joined Jun 2012
Santa came early.... Got a NAZA and GPS! LOVE LOVE LOVE IT!!. 1000 times better then the Rabbit I used to have. Here is GPS hold in 15 knot wind... Rock Solid. Failsafe is awesome too.
NAZA GPS Spidex! (0 min 33 sec)
dc9guy is offline Find More Posts by dc9guy
Old Nov 29, 2012, 06:17 AM
United States, AZ, Tucson
Joined Mar 2012
Senior Tech #1: How To Master Texting - CONAN on TBS (2 min 14 sec)
goldsworthy is offline Find More Posts by goldsworthy
Old Nov 29, 2012, 08:43 AM
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
Hi again , i have question about the manual failsafe i have set my 3 postion switch already and add the gear channel for the fail so i can use whenever i want in any mode but 3rd failsafe is on the corner of the screen and i can see the word faisafe appear so is it necessary to have the failsafe in the blue ? thanks
windfou is offline Find More Posts by windfou
Old Nov 29, 2012, 09:15 AM
The Devil Is In The Details...
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Probably Need To See Blue Too
It sounds like you are at the edge of the Failsafe range and the Assistant is not completely recognizing it.
Try adjusting your endpoint on the Failsafe switch to see if the wording "Failsafe" and the blue bar in the Failsafe range will both appear...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Nov 29, 2012, 09:35 AM
I hate waiting for parts
Mike_Then's Avatar
Rocky Mount, NC
Joined Apr 2001
What TJ said... adjust the endpoint until the slider is under the word failsafe and it turns blue. Unless it does that, it won't be active.
Just thought I'd mention too... I flew my E-Flite mQX for the first time in a long time yesterday at lunch. Wow, talk about twitchy! It took me a few minutes to get the hang of it again. I'm so used to the smooth characteristics of the Naza as well as the self-levelling properties that I was all over the place at first! I need to fly it more often to keep my thumbs and brain programmed.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: Chaos 600 ESP build
Old Nov 29, 2012, 09:49 AM
Creator of the 1st 6S HT-Flip!
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Hmm that could be the problem then lol considering my yaw gain is the lowest of the 3. But when I set it to high will it shaksomething? I also havnt even set my pitch and roll gains high enough to cause any wobble yet so I should probably see how high my gains can go.
flohio117 is offline Find More Posts by flohio117
Old Nov 29, 2012, 09:51 AM
windfou's Avatar
Joined Dec 2008
naza autolevel mode is too slow for a experienced pilot and i use manual mode 90% of the time lol i have a clone mqx ladybird and you can not crash with this little thing because the autolevel is always there so its hard to be agressive so i fly at 60% control , if you try to start to learn with lower value its not good when you have wind you can lose it very easy , at 40% i can stay there with my key chain and it wont move alot if the wind is calm .
Old Nov 29, 2012, 09:54 AM
windfou's Avatar
Joined Dec 2008
I cant that why i ask the question if you set one side the other side will disapear
even if try to split equal in % , anyway will see if can change my configuration , i am stuck since a week about this problem
Old Nov 29, 2012, 10:03 AM
Joined Feb 2009
Naza #2 Has Started Its Homecoming Trip
I communicated with UAV Products today, and the defective Naza I purchased from them has been sent back to China for warranty service.
It will be interesting to see how long this takes...
If the defective Naza had been my first one, I wonder if the experience I'm going through on the second one would have completely soured me on DJI/Naza?
I'm afraid I'd be livid...
Right now I'm amused & confused...
Old Nov 29, 2012, 10:08 AM
windfou's Avatar
Joined Dec 2008
my naza work but i hope my gps work too
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 18053 Yesterday 10:11 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
