Old Nov 19, 2012, 02:28 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Originally Posted by T J Gilbert View Post
Still off topic, but relevant...
Will a laptop battery "burn" like one of our high discharge packs?
I don't think I recall hearing of that type lipo fire...
I remember the laptop fires from a few years ago. They still have the fire risk but laptop batteries are not as "fragile" (for lack of a better word) than our LiPos. It's a more stable chemistry and can tolerate being operated outside its operating parameters, unlike our LiPos which are NOT happy about being overcharged and overdischarged. I also think our LiPos are a lot more energy-dense than a laptop battery, most likely due to the different chemistry (Li-Ion vs. LiCoO2).
Mike_Then is online now Find More Posts by Mike_Then
Old Nov 19, 2012, 02:36 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Lithium Anything = Caution
I think I'm going to start being more careful with laptops.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Nov 19, 2012, 02:48 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Take the cell phone out of your pocket... awful close to sensitive bits.
MCrites is offline Find More Posts by MCrites
Old Nov 19, 2012, 03:09 PM
Empire Support
Joined Feb 2009
I use a holster...
Darned iPhone is so big, I can't sit down when it's in my pocket!
If it catches fire, I'll do a quick-draw...
Old Nov 19, 2012, 03:52 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
I had thought the difference between Lipos and Laptop batteries was discharge rates. But a quick wiki search found this:
Safety requirements
If overheated or overcharged, Li-ion batteries may suffer thermal runaway and cell rupture.[56] In extreme cases this can lead to combustion. Deep discharge may short-circuit the cell, in which case recharging would be unsafe.[57] To reduce these risks, Lithium-ion battery packs contain fail-safe circuitry that shuts down the battery when its voltage is outside the safe range of 3–4.2 V per cell.[35][45] When stored for long periods the small current draw of the protection circuitry itself may drain the battery below its shut down voltage; normal chargers are then ineffective. Many types of lithium-ion cell cannot be charged safely below 0°C.[58]
Other safety features are required in each cell:[35]
Shut-down separator (for overtemperature)
Tear-away tab (for internal pressure)
Vent (pressure relief)
Thermal interrupt (overcurrent/overcharging)
These devices occupy useful space inside the cells, add additional points of failure and irreversibly disable the cell when activated. They are required because the anode produces heat during use, while the cathode may produce oxygen. These devices and improved electrode designs reduce/eliminate the risk of fire or explosion.
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 19, 2012, 05:54 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Funny how things work out; my project for the day was to make a new Lipo charging station since these DJI copters have me back into electric big time. So it was good reading all this. I have my best charging set up ever located on a metal shelf.
u2builder is offline Find More Posts by u2builder
Old Nov 19, 2012, 06:19 PM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
Just don't ever hit start on the charger and forget to plug in the pack, I did that once on my titanium topped workbench. Poof went the charger..
I guess the charger read the pack through the balance port and tried to supply 5amps to my table..
MTHead4u is offline Find More Posts by MTHead4u
Old Nov 19, 2012, 08:13 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
anybody have a god starter settings for my y6? the fc is in the exact middle and everything is balanced. im just wondering where some of your guys gains are around?
flohio117 is offline Find More Posts by flohio117
Old Nov 19, 2012, 09:54 PM
dslack67 is offline
Find More Posts by dslack67
dslack67's Avatar
Joined Dec 2011
Thanks everyone. Yes, I did review Delta Airlines website and the FAA.Gov site and will be securing the leads with caps and each will be in it's own Lipo bag. I'll be taking them with me in my carry on and placing them separately through the screening bin, along with a copy of the "regulations".
Should be all good to go!!
Cheers guys!
Originally Posted by kc10kevin View Post
It doesn't. Max cabin pressure is always below 10K. I've flown several times with Lipos on commercial aircraft. Tape up the leads, put them in a plastic bag and ALWAYS carry them on. Don;t try to hide them in your carry ons. Show them ahead of time and let the TSA folks know what they are and the FAA approves them for flight in the cabin as long as the leads cannot touch each other.
From FAA.gov:
Lithium ion batteries (a.k.a.: rechargeable lithium, lithium polymer, LIPO, secondary lithium).
Passengers may carry consumer-sized lithium ion batteries [no more than 8 grams of equivalent
lithium content or 100 watt hours (wh) per battery]. This size covers AA, AAA, 9-volt, cell
phone, PDA, camera, camcorder, Gameboy, and standard laptop computer batteries.
Passengers can also bring two (2) larger lithium ion batteries (more than 8 grams, up to 25
grams of equivalent lithium content per battery) in their carry-on. This size covers larger
extended-life laptop batteries. Most consumer lithium ion batteries are below this size.
What does “protected from short circuit” mean?
A. Protected from short circuit means that a battery’s terminals are protected from being touched
by metal. When metal such as keys, coins, or other batteries come in contact with both
terminals of a battery, it can create a “circuit” or path for electricity to flow through. This can
cause extreme heat and sparks and even start a fire. To prevent short circuits, keep spare
batteries in their original packaging, a battery case, or separate pouch or pocket. Make sure
loose batteries can’t move around. Placing tape over the terminals of unpackaged batteries also
helps to insulate them from short circuit.
dslack67 is offline Find More Posts by dslack67
Old Nov 20, 2012, 08:48 AM
Cervanchez's Avatar
Joined Dec 2011
Hi guys,
I found a new flying site and had a blast over the weekend. Other than one minor crash (when i lost video for some reason) it was a good day, I went through like 8 or 9 packs.
New Park Adventures (3 min 30 sec)
Old Nov 20, 2012, 10:06 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by wazzer View Post
also removing the stickers on your motors helps allot.
just remeber to mark on them with a marker pen or engraver what the motor specs are!
But I like the cool stickers!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Nov 20, 2012, 11:03 AM
Empire Support
Joined Feb 2009
DJI Motors
The DJI motor sticker wraps almost completely around the motor can.
They probably did that to prevent the sticker from causing imbalance.
I leave mine on...
I'm going from memory here. I'm not at home where I can check. Since I could be wrong (I've got dozens of out-runner motors), let me check when I get home tonight. I'll confirm or retract my statement...
Sorry...
I have checked, and I was wrong. My DJI motor labels go around just 45% to 50% of the can diameter. Not sure which motor I was thinking of, but the labels are still on the DJIs and the balance is acceptable. FWIW the new DJI motors have a laser etched label...
Old Nov 20, 2012, 11:07 AM
MCrites is offline
Joined Jan 2012
I leave mine on...
My stickers didn't even go around half of the can if I remember correctly.
Old Nov 20, 2012, 11:40 AM
Joined Mar 2012
HEY T J! check your messages! I think I may have had a break through!
Old Nov 20, 2012, 03:01 PM
BerndM is offline
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
I like to hover around the nudest colony that is 3 blocks from my home! They should have planted more trees over there.
Without corroborating HD video, it didn't happen
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x5 Graupner Props / GoPro HD2
AUW 3S-2200mah = 1100g / 3S-4000mah = 1305g
Spektrum TX DX-7 (original) / Spektrum RX AR6200
BerndM is offline Find More Posts by BerndM
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 09:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 12:43 PM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 11:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
