Old Nov 18, 2012, 11:43 AM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Balancing Motors
Its easy to overlook a bent motor shaft - a couple of good bangs to a prop is all it takes.
helidex is offline Find More Posts by helidex
Old Nov 18, 2012, 11:48 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by m_beeson View Post
goldsworthy,
You have to remove the motor,
take the can off,
tap out the bearings,
and press the new ones in,
then you replace the can,
and reinstall the motor.
It is not a quick process, and 6 motors takes longer than 4, so you can count on it taking a little time, but you should be able to finish it in an evening.
FWIW:
I had a brand new set of Avroto motors, and was having issues with the bearings,
so in an effort to find a good solution I replaced them with BocaBearings porcelain bearings, and used their Lightning Lube. It was a good move.
Those motors are real smooth now.
Thanks! I plan on doing this to 2 motors. What tools do I need to remove and tap back in the berings?
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Nov 18, 2012, 11:55 AM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
Sometime the bearings are hard to get out.... This is a nice video (not mine) explaining how:
Brushless Motor Bearing Replacement (7 min 43 sec)
I used a brass (softer metal) screw cut off and sanded flat to bang them out. Getting them back in is the easy part! Also I put my motors in a big plastic bag to remove the clip so it didn't go flying too far.
glmccready is offline Find More Posts by glmccready
Old Nov 18, 2012, 12:21 PM
Joined Mar 2012
http://www.youtube.com/watch?v=Kx5gfoApQAg
THANKS! up till now when I think a bearing is starting to give me trouble I just replaced the motor with a new one. I thought I would try to just replace the bearings in 2 motors and see how it goes. Its probably better than just tossing the old motors in the trash. I have ordered the Bering's they are cheap in price. I will let ya know how it goes.
Old Nov 18, 2012, 12:34 PM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Success!
I got the new Naza (Naza #3) that I purchased from UAVP in the mail yesterday.
I got everything reconnected/setup.
I held my breath, powered the transmitter, and plugged in the Naza battery.
Naza #3 made the VU's LED flash rapid yellow (Naza #2 = rapid red).
I thought that good as there was a difference.
I plugged in the USB to the VU with the Assistant up on my computer.
---AND----
Solid bright green LED!
Naza #3 recognized by Assistant!
I'm back!
Man, it feels good to know that all that malfunctioning was a bad Naza, and not me or my computer.
Naza #2 is on it's way to UAVP. If it or a replacement finally returns, I'll have a spare.
T J Gilbert is offline Find More Posts by T J Gilbert
Old Nov 18, 2012, 12:39 PM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Glad you're back up and running TJ!
Had my F550 out for a little tweaking today ... gains now set to 330 pitch & roll, 300 yaw and 250 altitude.
Bill Glover is online now Find More Posts by Bill Glover
Old Nov 18, 2012, 12:42 PM
Joined Mar 2012
---AND----
I'm back!
See I told ya T J! money solves every problem in R C!
Old Nov 18, 2012, 01:06 PM
Gary
glmccready's Avatar
Joined Mar 2011
TJ: glad you figured it out! I had a glitch about every 8-10 flights, and had a heck of a time figuring it out, till the ESC finally failed completely. I exchanged motors, esc, and even the controller, all was fine, till it would crash.
Goldsworth: yea the Boca bearings are inexpensive and mush better than the stock that came with my RC timers, I replaced them all for $10, and an afternoon.
Old Nov 18, 2012, 01:41 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I'm back!
A struggle for sure, but ALL GOOD NOW.
u2builder is online now Find More Posts by u2builder
Old Nov 18, 2012, 02:18 PM
Empire Support
Joined Feb 2009
Struggle = Experience & Lesson Learned!
I was an unwilling guinea pig on a lot of things we tried. I'll take some knowledge away from the experience and use it to help others...
I think I know how predictable Assistant connection from Naza to Naza should be.
I also know what a defective Naza's LED flash most likely is.
Powered up a Naza with a lot of things disconnected that usually are.
Tried the F1/F2 fix and know what at least a defective Naza does when you do.
Probably a lot more that I don't recall...
Old Nov 18, 2012, 02:27 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
---AND----
I'm back!
Hooray! Glad you're back in business!!
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Nov 18, 2012, 04:34 PM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
---AND----
I'm back!
Sweet!! Spares are always good..
I was having the same issue (getting the same message) today when trying to connect, turns out that my Naza doesn't like being plugged into powered USB hubs I guess, something I got to remember before freaking out.
Connected it straight to the laptop USB and she fired right up. Just little something for others to remember too.
MTHead4u is offline Find More Posts by MTHead4u
Old Nov 18, 2012, 06:22 PM
BerndM is online now
Find More Posts by BerndM
BerndM's Avatar
Near Disneyland in Placentia, Southern California, USA
Joined Aug 2004
Is there a way to balance the motors without a cell phone and "app"? I don't have a cell phone so that method is not available to me but I would like to be able to balance the motors.
BTW, I tried several types of vibration mounting and actually get the best Go Pro pictures from a rigid mount. I did purchase a flex mount from a fellow in Israel who sells them on Ebay but haven't tried it yet.
There is a method that is REALLY subjective, using just your eyes.
I have to assume you will be balancing ONE motor at a time, PROP REMOVED, right?
If so, place your flyer on a HARD surface, get a clear glass, and 3/4 fill it with water. Set the glass on top of the arm with the motor being tested. Run the motor and observe the vibrations on the water surface. Make changes to the motor balance as needed and rerun the test and mentally compare the vibrations.
Primitive and crude but fairly functional.
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x5 Graupner Props / GoPro HD2
AUW 3S-2200mah = 1100g / 3S-4000mah = 1305g
Spektrum TX DX-7 (original) / Spektrum RX AR6200
BerndM is online now Find More Posts by BerndM
Old Nov 18, 2012, 06:25 PM
Joined Mar 2012
Regards
Bernd
Its also a lot less money than a Apple I Phone!
Old Nov 18, 2012, 11:36 PM
dslack67 is offline
Find More Posts by dslack67
dslack67's Avatar
Joined Dec 2011
Hey Bernd! Been a while, hope your doing well and having fun. That's a very good way to test, never thought of that.
I used the vibration software on my iPhone, which worked very well also. Just sit the iPhone on the arm your testing, similar to what you explain here. The only difference is the software records the "Peak" and "Average", making comparisons easier.
Hey, I just put together this travel case for a trip I'm taking to Cancun in a few weeks with the wife. Should get some good video!
Cheers.
Quadcopter Case - Pelican (2 min 13 sec)
Regards
Bernd
dslack67 is offline Find More Posts by dslack67
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
