Hello GW!
They're going to scold us again for using this thread as social media, but so what...
Glad you're out there listening... ![]() Had to use "so what" because RCG wouldn't let me use my first choice... ![]() I don't think I've ever said it, because I tread lightly and try not to offend, but why can posters use RTFM? |
Hey everyone here's the vid of my problem please help.
Northern Minnesota
Joined Oct 2001
It seems a new VU unit didn't help so that leaves the Naza. To check it simply replace the old Naza on your 450 with the new one and see if you get anywhere. You just need to make the connections temporarily. You don't have to really mount it. Should only take a few minutes to check. |
Start-up =/=
If you have, and you still have motors failing to start simultaneously, you need to consider the variables that you have introduced into your Naza situation: 1. You are using ESCs that are not OEM as far as DJI is concerned. That could mean that your motors will never start up simultaneously. I know many pilots want something more, but FWIW, the DJI ESCs are not that bad. (If you were talking to DJI, I bet they'd say, "Use our ESCs and your motors will behave.") 2. You proved with your video that the airframe still flies pretty well in spite of a non-simultaneous motor start-up. (BTW, that's the best indoor hovering I've seen with a Naza FC). So, maybe, you've reached the best case scenario for your configuratiuon... |
I understand that I could easily take the working Naza, put it on the F550 frame, and see if everything works. And I suspect it would. Yes, that would prove that the non-working Naza is the culprit. But (and this is a BIG BUT) I might be sacrificing the working Naza to some driver flaws/errors that only a coder can deal with. And I still suspect that I have two perfectly good Nazas and there is some driver loading/sharing error looming here. I'm content to maintain that one Naza working is better than two Nazas not working. And, I'll leave that Naza on my trusty F450 AV platform, thank-you. All the bugs are not out of this FC yet, and we are still all beta testers. Read the threads if you don't believe me. The DJI customer service/dealers will quickly tell you that what I'm experiencing is not supposed to happen. That means I have an unusual/out-of-the-ordinary case and logic is out the window until an experienced IT/coder person steps in and says "this is the way things are". Much of this is the way DJI chooses to deal with its proprietary algorithms and troubleshooting. Look at how vague they are w.r.t. the F1 to F2 reset. No one knows the exact procedure. DJI has just said "try this". I'm forced to work on their playing field, so I choose to not be forthcoming in sacrificing perfectly good FCs. Sorry, but "been there, done that"... I have gone way beyond what should be expected in troubleshooting an FC. Most posters (like many I assist every day) would have cried "warranty!" long before I have. Let's just all wait and see how UAVP and DJI choose to deal with this. Check my posting record. I'll report back with the facts. |
TJ, maybe it's better unplug the cables from the good Naza, connect them to the new Naza, so now you have a F450 with F450 motors/ESCs, with a known working F450 VU, and only thing that is new is the new Naza. This way the old Naza (good one), will not even leave it's position from the lower plate on the F450.
The whole switch is quite easy, since you will just unplug and re-plug the servo extension cables between the two Nazas. The new one doesn't need to be mounted at all. This can tell you is your new Naza good or bad. This way chanses to screw something up are close to null. Going the other way around is more trickier, and I would also not recommend it. Quote:
| Thread Tools | |
| New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Electronics | 18046 | Today 01:58 PM |
| New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC | JussiH | Multirotor Talk | 707 | Jan 01, 2013 08:54 AM |
| Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
| New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. | JawaSnack | Hot Online Deals | 9 | Jul 17, 2007 10:31 AM |
| Futaba FC-18 teacher to FC-16 pupil problem . | jmquetin | Radios | 5 | Nov 02, 2004 06:48 AM |
