Old Nov 13, 2012, 06:38 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Originally Posted by power View Post
Here is a question for you hexacopter flyers....
I just finished up my first homebuilt Hex, I am using Avrotos with Castle creation PH-25's (new multirotor firmware) I have been very pleased so far with the flight quality but something seems strange.
I usually always push my Basic gains up until I see oscillations on any FC I tune. The Naza being no different I slowly increased the basic gains to 225. It is very solid but I wanted to see some wobble so for grins I jacked the basic gains up to 325 and while it seemed a bit tighter it would still hover smoothly. If I tried this on my quad with the SimonK ESC's it would have jiggled itself apart.
Does anyone else see this??
Yes, I'm flying an F550 and had to put the roll/pitch gains up to 300 before I saw the slightest momentary oscillation after releasing the stick.
Bill Glover is offline Find More Posts by Bill Glover
Old Nov 13, 2012, 09:12 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Thanks Bill, can I ask which ESC's you are using??
I wonder if this is just the way the Hexacopter firmware works. There is no way I would get the gains this high with my quad.
power is offline Find More Posts by power
Old Nov 13, 2012, 09:45 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
My video question of the day!-
VID00340 (0 min 30 sec)
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Nov 13, 2012, 09:49 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
That is my biggest pet peve with NAZA.
I can usually go out pretty quick, but then I fight the NAZA all of the way back.
I have almost had to ditch it because it faught me until the LiPos were dead.
Barely made it back.
I haven't found the answer yet.
Originally Posted by Hulksta View Post
Got a problem flying my naza in Attitude or GPS..
Im finding when flying FPV that if im holding the stick forward for constaint forward movement that it feels like its correcting itself and leveling cause after a while i can be full stick and hardly moving
Would this be a setting? I have most of the gains at 100% or just above... i also notice that if i let go of the stick and let it hover/level then its right again but works its way back to hardly moving again
m_beeson is offline Find More Posts by m_beeson
Old Nov 13, 2012, 10:01 AM
Joined Nov 2000
I'm using the DJI ESCs (I've never understood why so few people get these) with Torxpower motors. I had the same ESCs and motors (and Naza) in a quad previously, which used lower gains.
Prop RPM is a factor though. The handling of my hex. altered when I switched from slow-fly type props to Graupner E-props (which turn at higher rpm to give the same thrust). I had to increase the gains significantly - even yaw, as the nose was wandering after the prop change.
The Graupners are noisier and a bit less efficient (with my setup), BUT they track really true which reduced vibration ... my objective in swapping.
Old Nov 13, 2012, 10:02 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Naza Wiring
Originally Posted by goldsworthy View Post
Your Naza Wiring Diagram is on page 8 of the Naza Manual.
As far as which channels are which on you Frsky receiver, you'll have to consult the Frsky Manual.
FWIW, the way I understand Frsky, you are able to arbitrarily assign channels.
Maybe you'd better move over to the Frsky thread and ask.
GW, I hope you're not in over your head here...
Better be glad MCrites didn't answer you.
He'd be scolding you for not RTFM and Googleing...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Nov 13, 2012, 10:57 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Yeah... TJ saved your bacon this time. I will get you next time though... MU HA HA HAAAAA
MCrites is offline Find More Posts by MCrites
Old Nov 13, 2012, 11:00 AM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Actually he needs to check his 9x manual, thats where the channels are assigned, not in the frsky module
Cervanchez is offline Find More Posts by Cervanchez
Old Nov 13, 2012, 11:15 AM
tech69x is offline
Find More Posts by tech69x
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
I have the same setup
Ch 1 frsky to A on the Naza
Ch 2 - E
Ch 3- T
Ch 4- R
I have a mix for my 3 position on ch 6 to U on the Naza
This is a video on how to setup the mix I hope this helps
How to set up DJI Naza step by step video with transmitter setup (12 min 19 sec)
tech69x is offline Find More Posts by tech69x
Old Nov 13, 2012, 12:05 PM
Joined Mar 2012
VID00343 (0 min 13 sec)
Old Nov 13, 2012, 12:15 PM
Joined Mar 2012
I am also lookin for the firmware version 2.02 it says I ned to update
Old Nov 13, 2012, 12:19 PM
Empire Support
Joined Feb 2009
If It Wants To Update, Let It...
If Assistant is telling you to update, you should click the button letting it do so.
It will automatically install the latest firmware...
Old Nov 13, 2012, 12:30 PM
Joined Mar 2012
It wont let me!-
VID00345 (0 min 19 sec)
Old Nov 13, 2012, 12:33 PM
windfou is offline
Find More Posts by windfou
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
newbie question again for the naza , can i use a dx7 tx with this system because i want to purchase one maybe today thanks
if the answer is yes which mode i have to use to make it work ? tradition or ppm
windfou is offline Find More Posts by windfou
Old Nov 13, 2012, 12:34 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
On DJI site,
Go to Products > Naza > Downloads > Assistant v 1.8 .exe
Once new assistant installed, go to "Tools"
Update firmware.
TAKE YOUR PROPS OFF BEFORE UPGRADING!
c3d76 is offline Find More Posts by c3d76
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
