Old Nov 12, 2012, 04:22 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Couple setting adjustments and it will be perfect! Welcome to the dark side!
MCrites is offline Find More Posts by MCrites
Old Nov 12, 2012, 04:44 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I was all Multiwii before...so had to learn how it work.
Where should I start to tune?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Nov 12, 2012, 04:52 PM
MCrites is offline
Joined Jan 2012
Didn't see GPS so the wobble is coming from your gains. If you can I would program your Basic Gains to X1 and put it on a knob/slider and your ATTI Gains to X2 and put it on a knob/slider. Then when you are flying you can adjust the gains to see what is causing the wobble. If you don't have the extra channels/capability I would lower you Basic gains 10% and see if the wobble gets better or worse... worse then got 10% up from the original settings.
Old Nov 12, 2012, 04:55 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Here is a question for you hexacopter flyers....
I just finished up my first homebuilt Hex, I am using Avrotos with Castle creation PH-25's (new multirotor firmware) I have been very pleased so far with the flight quality but something seems strange.
I usually always push my Basic gains up until I see oscillations on any FC I tune. The Naza being no different I slowly increased the basic gains to 225. It is very solid but I wanted to see some wobble so for grins I jacked the basic gains up to 325 and while it seemed a bit tighter it would still hover smoothly. If I tried this on my quad with the SimonK ESC's it would have jiggled itself apart.
Does anyone else see this??
power is offline Find More Posts by power
Old Nov 12, 2012, 04:57 PM
MCrites is offline
Joined Jan 2012
Different ESC = different way it handles power. The CC's just might handle the updates from the FC better
Old Nov 12, 2012, 05:12 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Good idea
Will do that
Old Nov 12, 2012, 05:32 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
I have a strange thing with my 550 sometimes yawing left by itself on descent. Puting yaw gains a lot higher (200) seems to have fixed that, but there is something wierd going on. It did that with stock motors and now with Avrotos and 10x5 Graupner props
I have put Yaw gain back down and set idle speed higher for the next test flights to see if it helps.
Any ideas?
c3d76 is offline Find More Posts by c3d76
Old Nov 12, 2012, 05:41 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Did you change the idle speed to High in the assistant?
No I didn't ill try that next. It flies but its not very stable in manual mode. And when I yaw one side will lift uft and turn its not flying that great
flohio117 is offline Find More Posts by flohio117
Old Nov 12, 2012, 05:50 PM
MCrites is offline
Joined Jan 2012
Any ideas?
I too had to raise my yaw gains. Some people have also had to put tape on the side of their Naza because the barometer is sensitive to light.
You really can't blame the Naza. You need to calibrate all of your escs equally and figure out the other setup issues before judging. Is your craft balanced? Naza centered, level, and near the COG? Props balanced? Vibrations can cause poor flight.
Old Nov 12, 2012, 06:01 PM
c3d76 is offline
Joined Mar 2012
Interesting, I remember reading about that somewhere. So best thing is to cover both sides with dark tape or? Anyway, I'll look into it...
I'll still try with higher idle speed, I somehow think some motors might be slowing down too much on descent causing the yaw. It never does it during climb, hover or flight, so I'm not sure it is due to light sensitivity.
Thanks for the reply!
Old Nov 12, 2012, 06:15 PM
MCrites is offline
Joined Jan 2012
Descents = dirty air = more tilting and wobble = motors need to react faster to keep level
If gains are too low the motors are reacting slower on purpose combined with tilting = yaw.
Dirty air from descents or the ground is hard for most FC to understand and correct for. Sorry this is typed weird.. On my phone and thumbs are wearing out
Old Nov 12, 2012, 06:40 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
You really can't blame the Naza. You need to calibrate all of your escs equally and figure out the other setup issues before judging. Is your craft balanced? Naza centered, level, and near the COG? Props balanced? Vibrations can cause poor flight.[/QUOTE]
I'm not trying to blame the naza. I'm trying to figure out why my 2 motors won't spin ill try setting the idle speed higher tommorow and yes everything is balanced. And naza is on cog.
Old Nov 13, 2012, 12:42 AM
Suomineiti is offline
Find More Posts by Suomineiti
Joined Sep 2012
Hello,
Question:
Can I put my receiver between camera stabilitation and gimbal that I can turn the camera with transmitter?
Regards,
Juha
Suomineiti is offline Find More Posts by Suomineiti
Old Nov 13, 2012, 02:40 AM
Hulksta is offline
Find More Posts by Hulksta
Hulksta's Avatar
Australia, NSW, Newcastle
Joined Mar 2012
Got a problem flying my naza in Attitude or GPS..
Im finding when flying FPV that if im holding the stick forward for constaint forward movement that it feels like its correcting itself and leveling cause after a while i can be full stick and hardly moving
Would this be a setting? I have most of the gains at 100% or just above... i also notice that if i let go of the stick and let it hover/level then its right again but works its way back to hardly moving again
Hulksta is offline Find More Posts by Hulksta
Old Nov 13, 2012, 04:48 AM
Hkubota is offline
Find More Posts by Hkubota
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
Known problem. Naza assumes and works best when hovering a lot and the sticks are thus centered once in a while.
At least this is my impression.
Hkubota is offline Find More Posts by Hkubota
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
