Old Nov 08, 2012, 08:21 PM
T J Gilbert is online now
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
USB Problems
Well, I've got problems for a change.
I'm trying to program my new Naza FC that I've installed on a F550 frame.
To make sure that everything with the Assistant was working, I connected my F450 rig up to the computer and everything was recognized correctly.
I then switched my transmitter model to the new F550, and powered it and then the Naza up.
I got the startup tones and rapid red flashes like a battery warning.
I then plugged the usb in and got a few green flashes and then no lights whatsoever.
The attached screenshot is what came up at the bottom of my screen.
It says:
USB Device Not Recognized
One of the USB devices attached to this computer has
malfunctioned, and Windows does not recognize it.
For assistance in solving this problem, click this
message.
Anyone know what's going on?
T J Gilbert is online now Find More Posts by T J Gilbert
Old Nov 08, 2012, 08:43 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
It says:
message.
Your connection sequence seems odd (or I am comfused). I do this:
1. Plug USB in
2. Power up TX
3. Power up Naza (& ESC'S)
I don't plug the usb in last, (after the ESC's). Have you always used the above sequence?
mark_q is online now Find More Posts by mark_q
Old Nov 08, 2012, 08:46 PM
edugimeno is offline
Find More Posts by edugimeno
United States, MI, Rochester Hills
Joined Aug 2012
For me the order I plug it all never minds. No matter the order I switch everything on or plug the usb in, sooner or later I get the assistant to connect to it, so the order shouldn't affect much
Sometimes the drivers get "stuck", when I get that message I usually switch to a different USB port and works. It may take 5 secs to install the driver on that port if you never plugged it into that one, but it should work
edugimeno is offline Find More Posts by edugimeno
Old Nov 08, 2012, 08:47 PM
rcroadtrain is offline
Find More Posts by rcroadtrain
rcroadtrain's Avatar
Australia, NSW, Marsfield
Joined Feb 2012
my sequence:
Tx on first
then usb into Naza, start assistant software
power up naza.
Red flashes from the naza happen when there's no radio link..
Green flashes are when the naza is doing its self check before flight
usb in and recognised should give constant green light.
if it doesnt tie in properly, close the assistant and restart it.
rcroadtrain is offline Find More Posts by rcroadtrain
Old Nov 08, 2012, 08:49 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
You can do it either way. But I would power cycle the Naza and restart Assistant be for you plug it in again. It sounds like the Assistant got confused. You may have to restart your computer before you do the above just to make sure the USB driver is restarted ok.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Nov 08, 2012, 09:06 PM
joeb56 is offline
Find More Posts by joeb56
Australia, NSW, Mt Hutton
Joined Jul 2007
Windows technical problem solver = reboot
Sounds like your USB driver failed to load
any way reboot is my friend solves most problems
joeb56 is offline Find More Posts by joeb56
Old Nov 08, 2012, 09:29 PM
Empire Support
Joined Feb 2009
No Luck!
Okay, here's what I've tried with the new Naza on the F550:
rebooted before each attempt
1. Connect USB/power trans/power Naza = device not recognized (dnr)
2. Power trans/power Naza/connect USB = dnr
1 and 2 done with Assistant on and off also = dnr
As a control, I switched models on the trans.
Then I tried all of the above with my other Naza rig (F450)
ALL variations worked and I got a bright green LED.
A little more help would really be appreciated.
Old Nov 08, 2012, 09:34 PM
Joined Aug 2012
Just my 2 cents... Don't waste a minute with setting in the Tx with models... Even your Tx doesn't have to be on for the laptop to recognize the Naza. It's a matter of hardware (both sides, laptop and VU-Unit) and drivers.
I would start reinstalling the USB drivers.
Steady green LED on the VU means the VU sees the USB connection so I would still say "problem in drivers". Go to Device Manager, delete the usb device, download the latest driver from DJI site, install it and reboot.
Old Nov 08, 2012, 09:41 PM
Empire Support
Joined Feb 2009
What about the F450?
If it's a driver problem, wouldn't the F450 also not connect?
I'm connecting both Naza FCs to the same computer with the same driver and Assistant loaded.
One connects and the other doesn't.
Old Nov 08, 2012, 09:43 PM
Joined Aug 2012
ah ok I missed that... So could be a Vu unit, did you try swapping the VU unit from one to the other?
Old Nov 08, 2012, 09:49 PM
Empire Support
Joined Feb 2009
I've got them soldered to the lower plates on the frame like we all advise each other to do to eliminate connector problems
I guess I've got a rebuild ahead of me.
Old Nov 08, 2012, 09:52 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I could be a bad VU or a bad Naza. Have you reconfirmed that the F450 is still being recognized?
Site Sponsor
Old Nov 08, 2012, 09:54 PM
Empire Support
Joined Feb 2009
Yes it is.
DJI support wants me to try it on another computer.
I've got to set my laptop up with Assistant and drivers to do that.
I'll let you guys know.
FWIW, this sucks!
Joined Aug 2012
Ok you can still try it. If the length of the wires allow it, remove both the X3 and LED plugs from the one VU unit and route them to the Naza in the other craft. Place a LiPO in the first craft (the one whose VU you are testing). If it still doesn't work and doing the opposite works, one VU unit seems to be broken
Old Nov 08, 2012, 11:02 PM
Empire Support
Joined Feb 2009
Good Thinking
That is pretty good out of the box thinking!
I'll still have to do some dismantling of frames to try it.
It's getting late, and I'm stressed.
Probably try some more over the next few days.
The damn laptop has Vista running on it and the drivers don't want to behave.
Probably won't be able to test with it...
Got to get some sleep because tomorrow's a work day.
I'm almost too tired now to be PO'd.
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20265 Jan 01, 2016 08:39 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
