Old Oct 29, 2012, 08:35 AM
goldsworthy is offline
Find More Posts by goldsworthy
United States, AZ, Tucson
Joined Mar 2012
Originally Posted by Tahoe Ed View Post
I got on of these and it works really well. The alarm will wake the dead.
http://www.rcdude.com/servlet/the-24...Voltage/Detail
I have 3 of those alarms and they are LOUD! someone called the cops on me when mine went off and I got a Disturbing the peace fine!
goldsworthy is offline Find More Posts by goldsworthy
Reply With Quote  (Disabled)
Old Oct 29, 2012, 08:39 AM
T J Gilbert is offline
Find More Posts by T J Gilbert
Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
Motor Voltages
Originally Posted by seadog1967 View Post
Just to let you know those 980 of sunnysky like I got are suppose to be only 3s which I run but my friend in AZ is running them on 4s with no issues. He also prior to the sunnysky ran $40+ motors. Says he likes these. No heat issue etc. Japan bearing and kawasaki stators so I think are ok. Was running a 1700g quad with them no issues.
I've been trying to educate myself on adhering to recommended voltages, vs. running a 3S motor on 4S, for example.
From what I can see, this is where the power calculators come into play.
As long as you don't overload your 3S motor & ESC with 4S (and the other parameters such as prop, AUW, etc. are within the limits a power calculator sets), you can proceed with care.
Actually the determining factor is the watts that your motor can handle.
That "magic" number is ~ 3W/g.
And P=ie.
Go over that and the heat demon comes calling...
T J Gilbert is offline Find More Posts by T J Gilbert
Old Oct 29, 2012, 08:44 AM
Joined Mar 2012
And P=ie.
I have ran 4s on my F450 now for some time with no trouble. The motors stay cool and responce is much quicker with the 4 cell than the 3
Old Oct 29, 2012, 09:52 AM
Empire Support
Joined Feb 2009
Fwiw
I started out with 4S, and have never considered 3S...
Old Oct 29, 2012, 10:22 AM
Empire Support
Joined Feb 2009
I Did Something Stupid...
I'm putting LEDs on the airframe of the F550 I'm assembling.
As you probably know, the LEDs are clear, and unmarked as to color.
To see what color one was, I forgot and hooked it to 4.8v without a resistor in series.
Blew it out straight away.
I must really be getting old!
Didn't have but one in that color, so now I have to wait for a replacement...
Lesson for TJ: Order more than one of things that are cheap to prevent a dime holding up a dollar..
I can hear GW laughing...
Old Oct 29, 2012, 10:39 AM
Joined Mar 2012
So, what color was it?
Old Oct 29, 2012, 10:43 AM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I am running 3S on both 450 and 550 because that is what I have. My machines are pretty much at the upper weight limit. Both have more than enough "performance". The motors all usually run around 80F when I land either machine, plus or minus a few degrees. Personally I like the "look" of bigger props and I also like the fact that they are turning at a lower RPM.
u2builder is online now Find More Posts by u2builder
Old Oct 29, 2012, 10:44 AM
Empire Support
Joined Feb 2009
And The Color Is...
so, what color was it?
red
Joined Mar 2012
red
I am glad we got that cleared up!
Old Oct 29, 2012, 11:04 AM
Empire Support
Joined Feb 2009
Red = Most Sensitive
It turns out that the red LED is the most sensitive to burnout without a current reducing resistor.
Just my luck.
A quick connection straight to a battery didn't hurt the green and white LEDs...
Maybe someone else will benefit from my carelessness...
Old Oct 29, 2012, 11:57 AM
Joined Mar 2012
Just my luck.
These are the strips I am adding to my F450 some of them have RGB controllers installed- http://www.youtube.com/watch?v=X92-p...2&feature=plcp I have a large box FULL of these LED packs
Old Oct 29, 2012, 12:37 PM
Empire Support
Joined Feb 2009
LED Strips
I remember us discussing them.
I have some of those on an old quad.
The good thing about them is that they have a resistor built into the strip to protect you from what I did...
I'm presently working on some really bright, individual LEDs...
Old Oct 29, 2012, 12:42 PM
Joined Mar 2012
I am going to try and fit 40-50 of theseLEDs on my 450. I wish to power the strips from a seperate battery. at 11.5 volt rating what model lippo would be smallest and lightest in size (3 cell) to be able to run these strips at full brightness for at least 1 hour?
Old Oct 29, 2012, 01:00 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
You need to know the current they pull. Whatever that is, thats the size in mAh you need. Example: if they pull say .02 amps each, and you have 50, that's 1000 mA, so you would need that size battery to run them for an hour.
Cervanchez is offline Find More Posts by Cervanchez
Old Oct 29, 2012, 01:22 PM
Joined Mar 2012
So I have this battery brand new I never got around to useing for anything. It is only a 1C rated lippo but it could be enough?-http://www.hobbyking.com/hobbyking/s...idProduct=9787 I realy dont know what the strips take other than they are rated at 11.5 volts
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20279 Aug 21, 2016 06:18 AM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Talk 707 Jan 01, 2013 08:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 06:48 AM
