Old Nov 08, 2011, 09:11 PM
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Build Log
PLD-PGMS8: 4 channel programmable LED/strobe
The PGMS8 is an expansion from the original PLD-PGMS which was around for quite a few years (it's now open-source hardware/firmware if you're interested).
The PGMS8 has 4 channels and I'm looking to see if I can incorporate fade in/out options to the strobing. The MOSFETs built in to the PGMS8 will handle 1A constant without any troubles. There is also an option to use internal (RX/BEC) power, rather than requiring an external power source - obviously it is up to the user to determine the safe maximum current limit to prevent overloading the BEC/RXsupply.
Overall the board is a little larger than the original PGMS.
You can use the existing programming interface to program the new PGMS8.
PLD is offline Find More Posts by PLD
Old Nov 13, 2011, 10:20 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Boards have been shipped; arrival in ~2wks.
Old Nov 24, 2011, 08:36 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Circuit boards arrived, that was a little bit quicker than anticipated (10 days), so an early christmas perhaps for some
Now the trick is to get the firmware running
Not quite as tiny as the original PGMS but still very small - and it has more features and the extra channel.
Old Nov 24, 2011, 11:43 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
So here it is, PLD-PGMS8 ... Serial #1 off the production line. I still obviously need to do the firmware but I'm hoping that'll all be done by Monday.
Anyone interested in one... or two ?
Old Nov 25, 2011, 11:01 AM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Strobe unit is working great I unfortunately did blow up some things when I connected a cable backwards (yes, I can still make mistakes like that when doing these developments) - destroyed my long loved servo testing board; guess I'll just have to make another one tomorrow.
The serial interface is a lot more verbose this time around, because I have a lot more FLASH space on the microcontroller to stretch my arms.
Code:
  PLD-PGMS8 Programmable Strobe v3
cX-on,off,...on,off: to set channel X pulses
T: listen for transmitter, t: ignore transmitter
d: dump channel information
q: quit.
> d
c1-600,600,100,100,100,100,0,
c2-50,100,150,200,250,300,400,500,600,700,0,
c3-16000,16000,0,
c4-100,100,20,20,20,20,0,
Old Nov 29, 2011, 01:09 PM
Joined Feb 2006
So the main changes are: One output more (4 vs 3),+ and fade in out, right?. What value has the output voltage?
elossam is offline Find More Posts by elossam
Old Nov 29, 2011, 06:41 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Elossam, haven't been able to create a fade facility (yet). The output voltage on the pins depends on what you plug into the power port, or if you use the RX power. You can put up to 16V on the power.
Old Nov 29, 2011, 11:22 PM
Tony Finn's Avatar
Weipa Queensland
Joined Jul 2007
I reckon that first one should head up my way, have you got a price worked out yet.
Tony
Tony Finn is offline Find More Posts by Tony Finn
Old Nov 29, 2011, 11:31 PM
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Tony,
http://nqrc.com/?vp=PLD-PGMS8 $29 AUD
I should send it up with a couple of other things that I've been meaning to send you as well.
Paul.
Build Log PLD-POWERBUS-A4; 4 channel independently regulated servo isolator board PLD NQRC / PLDaniels Electronics 16 Nov 27, 2011 10:00 PM
Discussion very bright (3W LED) navigation strobe light tom_rc Night Flying 0 Nov 08, 2011 06:24 PM
Help! 4-channel receiver has red blinking LED and won't respond justin144 Power Systems 5 Sep 14, 2011 02:32 PM
Discussion OpenHardware - Programmable strobe by PLDaniels/NQRC - Atmel ATTINY2313 PLD DIY Electronics 1 May 18, 2011 08:14 PM
New Product Programmable LED Strobe system PLD Night Flying 0 Apr 22, 2008 10:16 AM
