Old Nov 08, 2011, 06:42 PM
rmmoorejr is offline
Find More Posts by rmmoorejr
So that's how you throw a DLG!
USA, NC, Sugar Grove
Joined Dec 2009
problem with 8FG SOLVED
My transmitter will not format an sd card. It does not even know that one has been installed. Anyone else have a problem like this?
rmmoorejr is offline Find More Posts by rmmoorejr
Old Nov 08, 2011, 07:04 PM
DougV is online now
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
What size card are you using.
Doug.
DougV is online now Find More Posts by DougV
Old Nov 08, 2011, 07:51 PM
Joined Dec 2009
I have tried cards from 2,4, & 16 GB
Old Nov 08, 2011, 11:38 PM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
Ok you need a 2Gb cardmax, Usually a Scandisk works.
There are some brands of card that do not work in the card reader.
TimBle is offline Find More Posts by TimBle
Old Nov 09, 2011, 08:23 PM
Joined Dec 2009
TimBle
You may have hit it. I miss read the manual and I thought it said a card between 32 and 2 GB. What it says is between 32MB and 2GB.
Thanks so much
Old Nov 09, 2011, 08:30 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Make sure that it's a regular SD card too; not an SDHC. (Actually, SDHC cards might only start at 4GB anyway.)
But yeah, I use a regular 2GB SanDisk SD card in mine.
Wrend is offline Find More Posts by Wrend
Old Nov 10, 2011, 02:01 AM
TimBle is offline
Joined Dec 2009
Coolio, glad I could help. Once you have it sorted could you change the title of the thread to "8FG Problem Solved".
Just so we close it and don't attract the other brand fanboys who feel the need to jump in offer assurances that their brand can do this and that and before you know it we have another 100 page brand debate. Plenty of those around.
NB, also be careful of the orientation of the card when you insert it into the card holder. The shiny contacts on the card have to face up if the face of the radio is looking back at you. SLide it in till it clicks in place. The formet instructions are in the manual. I think its a simple power up procedure and the Tx detects the unformatted card and asks if you want to format it. Follow the instructions and you're good to go.
Old Nov 10, 2011, 03:53 AM
HallaBalla is offline
Find More Posts by HallaBalla
Foam shredder
HallaBalla's Avatar
The land of fjords
Joined Sep 2010
Start of 100 page brand debate (fanboys only, please):
Ha! In your face, Futaba! Spektrum DX8 rules!
From http://www.rcgroups.com/forums/showthread.php?t=1383952
Andy Kunz: "The SD interface has been tested with a bunch of different cards from different vendors ranging from 16M to 32G. Basically, ANY MMC or SD or SDHC or Micro SD or Mini SD should work."
(Sorry, couldn't resist ...)
HallaBalla is offline Find More Posts by HallaBalla
Old Nov 10, 2011, 03:57 AM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
What about SDXC?
Old Nov 10, 2011, 04:04 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
LOL, who cares?? At least the futaba radio works all the time!
JK,
Doug
Old Nov 10, 2011, 05:09 AM
TimBle is offline
Joined Dec 2009
"should" is a lovely get out of jail free ard isn't it...
Old Nov 10, 2011, 05:19 AM
Joined Dec 2009
I installed a 1gb card and it did format but when I tried to send the update to the card I get a message saying that there is not enough space on the card. I checked the card and there is nothing on it. I stopped at Wal Mart this morning and they didd not have any small size cards except for a 2GB PYN brand and I have tried this brand and it wont format.
Old Nov 10, 2011, 05:55 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
That's probably Windows, try this: Format that 1gb card first in windows then go back to you radio and format the card there, now try it and see if it works.
Doug.
Old Nov 10, 2011, 06:18 AM
TimBle is offline
Joined Dec 2009
is the card unlocked? check the write protect tab on the side
Old Nov 10, 2011, 06:48 AM
Joined Dec 2009
card is unlocked. I will try the format, reformat idea that Doug posted.
Discussion Futaba 8FG problem earp Radios 15 Jul 21, 2011 05:17 PM
Discussion Senior Citizen with Futaba 8fg programing problem Tez Beginner Training Area (Fuel) 2 Mar 19, 2011 10:31 PM
Discussion Futaba 8FG charger problem Hewey19 Radios 1 Mar 03, 2011 08:09 PM
Found Futaba 8FG and Futaba Rx(s) burke757 Aircraft - General - Radio Equipment (FS/W) 0 Feb 01, 2011 10:15 AM
Help! Futaba 8FG linking problem? HogCrewChief Radios 4 Mar 14, 2010 12:27 PM
