Netherlands
Joined Dec 2009
Real Electric Outboard motor 6KW
Guys,
My latest project with building an E-outboard has come to an end. ![]() ![]() ![]()
It is an Agni 95 R with a 600A peak power Kelly controller with some HK 6s 5ah Lipo packs. But it makes some noise and it looks like an gasoline outboard, so every neighboor thinks that it is ilegal, ( only electric allowed at the lake ) So I want to go more silent and stealthy so I have a new idea and would like to hear what you people think about it. ![]() http://continuouswave.com/cgi-bin/propcalc.pl I use this calculator and add 20% slip ( not sure if that is right ) So I want to put one shaft through 2 Turnigy motors and rewind them for 51 RPM/Volt, I believe some people at the forum have done this successfully. Each motor will get it's own controller, with my Agni 95 R outboard I draw 6000 watt to go 27 km/h which is fine for me, but that was with a gearing and imbalance, so a directdrive should be more efficient right ? Any thoughts ? Maybe not an Turnigy RC motor but a stock motor that can handle these powers ? It needs to be a small size diameter motor, the Agni motor is a pancake size and it to wide to put it under water. I originally posted this at the ES forum, but also would like to share with RC groups since I now want to build it with RC motors, so I was hoping that someone can help me out a bit. I was think of adding some sort of gearbox to the Turnigy motor to get the prop running at 51 rpm/volt, I can imagine that there are small gearboxes for RC planes and boats, but I need one that can handle more power. If anyone has some info or an idea please let me know. Thanks ! |
| Thread Tools | |
| Discussion 90mm fan/motor combo 3.6kw capable....... $80. Video post #33 | Knife Liddle | Electric Ducted Fan Jet Talk | 48 | May 03, 2012 09:00 AM |
| Found WTB Fast Electric Outboard Setup. (motor & leg) | Rondog | Boats (FS/W) | 5 | Apr 20, 2011 10:26 AM |
| Discussion 5-6kw motor for Graupner Taxi | authomassen | Giant Electric Planes | 10 | May 24, 2008 05:19 AM |
| Wanted Electric outboard motor | flyerbob | Boats (FS/W) | 8 | Feb 06, 2007 10:36 PM |
| Where Can I Find An Electric Outboard Motor Cover!!! | telecom tech | Racing Boats - Electric | 1 | Sep 24, 2004 03:49 AM |
